<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[MMM-AlexaPi]]></title><description><![CDATA[<p dir="auto">Microphone Icon not showing up<br />
I  Installed MMM-AlexaPi in to modules, paste this in to config.js. But mic icon not showing</p>
<pre><code>modules: [
        module: 'MMM-AlexaPi',
        position: 'lower_third',
            // The config property is optional.
            // If no config is set, defualt values are used
]]></description><link>https://forum.magicmirror.builders/topic/2005/mmm-alexapi</link><generator>RSS for Node</generator><lastBuildDate>Thu, 08 Oct 2026 01:38:10 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/2005.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 07 Mar 2017 15:08:55 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to MMM-AlexaPi on Wed, 07 Jun 2017 15:11:43 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/bminer1" aria-label="Profile: bminer1">@<bdi>bminer1</bdi></a> said in <a href="/post/22421">MMM-AlexaPi</a>:</p>
<p dir="auto">/etc/opt/AlexaPi</p>
<p dir="auto">This should work</p>
<p dir="auto">pi@Clock: cd  /etc/opt/AlexaPi<br />
pi@Clock:/etc/opt/AlexaPi  ls<br />
config.yaml<br />
pi@Clock:/etc/opt/AlexaPi<br />
nano config.yaml</p>
]]></description><link>https://forum.magicmirror.builders/post/22451</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/22451</guid><dc:creator><![CDATA[michael24h]]></dc:creator><pubDate>Wed, 07 Jun 2017 15:11:43 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-AlexaPi on Tue, 06 Jun 2017 23:31:52 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mochman" aria-label="Profile: mochman">@<bdi>mochman</bdi></a> When i run<br />
sudo nano /etc/opt/AlexaPi/config.yaml<br />
i get a blank page. Any idea?</p>
]]></description><link>https://forum.magicmirror.builders/post/22421</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/22421</guid><dc:creator><![CDATA[bminer1]]></dc:creator><pubDate>Tue, 06 Jun 2017 23:31:52 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-AlexaPi on Sun, 21 May 2017 22:37:20 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/borrigan" aria-label="Profile: borrigan">@<bdi>borrigan</bdi></a><br />
yes mate, mic. icon show up after installing one of add ons</p>
]]></description><link>https://forum.magicmirror.builders/post/21902</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/21902</guid><dc:creator><![CDATA[michael24h]]></dc:creator><pubDate>Sun, 21 May 2017 22:37:20 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-AlexaPi on Sun, 21 May 2017 17:55:35 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/michael24h" aria-label="Profile: michael24h">@<bdi>michael24h</bdi></a> did you ever get the mic to show up? Same problem here.<br />
Thanks!</p>
]]></description><link>https://forum.magicmirror.builders/post/21886</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/21886</guid><dc:creator><![CDATA[borrigan]]></dc:creator><pubDate>Sun, 21 May 2017 17:55:35 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-AlexaPi on Wed, 08 Mar 2017 00:28:42 GMT]]></title><description><![CDATA[<p dir="auto">This is anything else what Should be installed in order to show up AleaxaPi microphone icon ?</p>
]]></description><link>https://forum.magicmirror.builders/post/16776</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/16776</guid><dc:creator><![CDATA[michael24h]]></dc:creator><pubDate>Wed, 08 Mar 2017 00:28:42 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-AlexaPi on Wed, 08 Mar 2017 00:23:13 GMT]]></title><description><![CDATA[<p dir="auto">I’m only missing mic. icon. Alexa works fine</p>
]]></description><link>https://forum.magicmirror.builders/post/16775</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/16775</guid><dc:creator><![CDATA[michael24h]]></dc:creator><pubDate>Wed, 08 Mar 2017 00:23:13 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-AlexaPi on Sun, 21 May 2017 19:27:16 GMT]]></title><description><![CDATA[<p dir="auto">I got this already</p>
<pre><code>platform:
  # Name of your platform, e.g. raspberrypi, orangepi, desktop
  device: "magicmirror"
]]></description><link>https://forum.magicmirror.builders/post/16774</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/16774</guid><dc:creator><![CDATA[michael24h]]></dc:creator><pubDate>Sun, 21 May 2017 19:27:16 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-AlexaPi on Wed, 08 Mar 2017 00:05:45 GMT]]></title><description><![CDATA[<p dir="auto">How did you set up your AlexaPi program?  Did you use the default raspberrypi platform?  If so, you may need to change it in your config file.</p>
<p dir="auto"><code>sudo nano /etc/opt/AlexaPi/config.yaml</code></p>
<p dir="auto">Find the area called <code>Platform:</code> and change</p>
device: "raspberrypi"
<p dir="auto">to:</p>
<p dir="auto">You may also want to scroll down further on the config file and see if your magicmirror settings are correct.</p>
<p dir="auto">Then don’t forget to restart the AlexaPi program.</p>
]]></description><link>https://forum.magicmirror.builders/post/16772</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/16772</guid><dc:creator><![CDATA[mochman]]></dc:creator><pubDate>Wed, 08 Mar 2017 00:05:45 GMT</pubDate></item></channel></rss>
