<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Using an Old (2 years old) windows Laptop in place of raspberry pi.]]></title><description><![CDATA[<p dir="auto">I’ve only just discovered magic mirror and i would like to build one, I have an old laptop that I don’t use anymore, i switched to OSX, and was wondering if/how I could use the laptop instead of buying a new system, I have all the parts to build one already, I’m just unable to find a guide where I could find a way to use the pc instead.</p>
]]></description><link>https://forum.magicmirror.builders/topic/2006/using-an-old-2-years-old-windows-laptop-in-place-of-raspberry-pi</link><generator>RSS for Node</generator><lastBuildDate>Wed, 13 May 2026 16:00:44 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/2006.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 07 Mar 2017 16:53:20 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Using an Old (2 years old) windows Laptop in place of raspberry pi. on Wed, 08 Mar 2017 11:42:49 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/johnnyboy" aria-label="Profile: johnnyboy">@<bdi>johnnyboy</bdi></a> said in <a href="/post/16803">Using an Old (2 years old) windows Laptop in place of raspberry pi.</a>:</p>
<p dir="auto">Im confused…</p>
<p dir="auto">I know. :stuck_out_tongue_winking_eye:</p>
<p dir="auto">I, too, started with a Windows machine, but it is possible to install MM and get it running, just in a roundabout way.</p>
<p dir="auto">Then I installed uBuntu on a laptop and installed MM and that went quite smoothly.</p>
<p dir="auto">You want the best of both worlds? When you install uBuntu on a PC or laptop there is an option to install it alongside of Windows, making it a dual boot machine.</p>
]]></description><link>https://forum.magicmirror.builders/post/16812</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/16812</guid><dc:creator><![CDATA[Mykle1]]></dc:creator><pubDate>Wed, 08 Mar 2017 11:42:49 GMT</pubDate></item><item><title><![CDATA[Reply to Using an Old (2 years old) windows Laptop in place of raspberry pi. on Wed, 08 Mar 2017 10:31:54 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/johnnyboy" aria-label="Profile: johnnyboy">@<bdi>johnnyboy</bdi></a> missing something.<br />
I’ve tried it on a Linux laptop and a Windows laptop.<br />
On Linux it worked good, but on the windows machine partially worked, as I am limited by the fact that some of the programs that are needed can’t be installed as they only works on Linux.</p>
]]></description><link>https://forum.magicmirror.builders/post/16804</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/16804</guid><dc:creator><![CDATA[mortenbirkelund]]></dc:creator><pubDate>Wed, 08 Mar 2017 10:31:54 GMT</pubDate></item><item><title><![CDATA[Reply to Using an Old (2 years old) windows Laptop in place of raspberry pi. on Wed, 08 Mar 2017 09:21:41 GMT]]></title><description><![CDATA[<p dir="auto">Install linux on the laptop, and then install magicmirror using the manuall installation as found here.<br />
<a href="https://github.com/MichMich/MagicMirror" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/MichMich/MagicMirror</a><br />
Perhaps there will be some glitches because MagicMirror was designed for raspberry pi but I did it with an old laptop for testing purpose and it worked fine. Currently I am working with magicmirror on a windows machine, and here i get a lot more glitches because i cant install the same programs (“sudo apt-get” doesnt exist ;)</p>
]]></description><link>https://forum.magicmirror.builders/post/16800</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/16800</guid><dc:creator><![CDATA[mortenbirkelund]]></dc:creator><pubDate>Wed, 08 Mar 2017 09:21:41 GMT</pubDate></item></channel></rss>
