<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Nothing showing but app is running]]></title><description><![CDATA[<p dir="auto">Hi,</p>
<p dir="auto">I have just installed MagicMirror with all the guides. Also installed PM2 and fixed the scrips. Anyway. When I am trying to start MagicMirror nothing happens. It says it is running but nothing is showing on the screen. The only thing that happens is that the CPU goes from 0-3% CPU load to 25%. So I guess the app is actually running but not showing anything.</p>
<p dir="auto">What could be the cause? I have tried both my 7" LCD-screen and my TV through HDMI.</p>
<p dir="auto">Best regards<br />
Fiskaren</p>
]]></description><link>https://forum.magicmirror.builders/topic/2010/nothing-showing-but-app-is-running</link><generator>RSS for Node</generator><lastBuildDate>Fri, 15 May 2026 08:01:23 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/2010.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 08 Mar 2017 00:04:44 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Nothing showing but app is running on Thu, 19 Oct 2017 11:16:07 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/fix-not-found" aria-label="Profile: Fix-Not-Found">@<bdi>Fix-Not-Found</bdi></a> said in <a href="/post/29794">Nothing showing but app is running</a>:</p>
<p dir="auto">how would I go about that?</p>
<p dir="auto">I don’t know that formatting is necessary. However, you could try this and know if you were successful in less than an hour.</p>
<p dir="auto"><a href="https://forum.magicmirror.builders/topic/5274/how-to-manually-install-mm-on-your-pi-for-absolute-beginners">https://forum.magicmirror.builders/topic/5274/how-to-manually-install-mm-on-your-pi-for-absolute-beginners</a></p>
]]></description><link>https://forum.magicmirror.builders/post/29807</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/29807</guid><dc:creator><![CDATA[Mykle1]]></dc:creator><pubDate>Thu, 19 Oct 2017 11:16:07 GMT</pubDate></item><item><title><![CDATA[Reply to Nothing showing but app is running on Thu, 19 Oct 2017 03:29:12 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/fiskaren" aria-label="Profile: fiskaren">@<bdi>fiskaren</bdi></a> I’m going to attempt the above comment next class, but in the meantime, how would I go about that?</p>
]]></description><link>https://forum.magicmirror.builders/post/29794</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/29794</guid><dc:creator><![CDATA[Fix Not Found]]></dc:creator><pubDate>Thu, 19 Oct 2017 03:29:12 GMT</pubDate></item><item><title><![CDATA[Reply to Nothing showing but app is running on Thu, 19 Oct 2017 01:02:24 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/fiskaren" aria-label="Profile: fiskaren">@<bdi>fiskaren</bdi></a></p>
<p dir="auto">All’s well that ends well.</p>
]]></description><link>https://forum.magicmirror.builders/post/29792</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/29792</guid><dc:creator><![CDATA[Mykle1]]></dc:creator><pubDate>Thu, 19 Oct 2017 01:02:24 GMT</pubDate></item><item><title><![CDATA[Reply to Nothing showing but app is running on Thu, 19 Oct 2017 00:59:31 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/fix-not-found" aria-label="Profile: Fix-Not-Found">@<bdi>Fix-Not-Found</bdi></a> I did not. But after formating and reinstalling it worked just fine. No idea what the problem was!</p>
]]></description><link>https://forum.magicmirror.builders/post/29791</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/29791</guid><dc:creator><![CDATA[fiskaren]]></dc:creator><pubDate>Thu, 19 Oct 2017 00:59:31 GMT</pubDate></item><item><title><![CDATA[Reply to Nothing showing but app is running on Thu, 19 Oct 2017 00:03:53 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/fix-not-found" aria-label="Profile: Fix-Not-Found">@<bdi>Fix-Not-Found</bdi></a> said in <a href="/post/29756">Nothing showing but app is running</a>:</p>
<p dir="auto">having this issue for a school project right now. Did you two ever have any sucess fixing it?</p>
<p dir="auto">Are there any errors being reported in your terminal or dev console? If so, post them here</p>
]]></description><link>https://forum.magicmirror.builders/post/29789</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/29789</guid><dc:creator><![CDATA[Mykle1]]></dc:creator><pubDate>Thu, 19 Oct 2017 00:03:53 GMT</pubDate></item><item><title><![CDATA[Reply to Nothing showing but app is running on Wed, 18 Oct 2017 21:48:18 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/fix-not-found" aria-label="Profile: Fix-Not-Found">@<bdi>Fix-Not-Found</bdi></a> I’ve got everything on a pi3 now not sure how I fixed this back then.</p>
]]></description><link>https://forum.magicmirror.builders/post/29772</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/29772</guid><dc:creator><![CDATA[d3r]]></dc:creator><pubDate>Wed, 18 Oct 2017 21:48:18 GMT</pubDate></item><item><title><![CDATA[Reply to Nothing showing but app is running on Wed, 18 Oct 2017 16:29:32 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/d3r" aria-label="Profile: d3r">@<bdi>d3r</bdi></a> <a class="plugin-mentions-user plugin-mentions-a" href="/user/fiskaren" aria-label="Profile: fiskaren">@<bdi>fiskaren</bdi></a> having this issue for a school project right now. Did you two ever have any sucess fixing it?</p>
]]></description><link>https://forum.magicmirror.builders/post/29756</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/29756</guid><dc:creator><![CDATA[Fix Not Found]]></dc:creator><pubDate>Wed, 18 Oct 2017 16:29:32 GMT</pubDate></item><item><title><![CDATA[Reply to Nothing showing but app is running on Mon, 03 Apr 2017 16:45:53 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/dikkedimi" aria-label="Profile: dikkedimi">@<bdi>dikkedimi</bdi></a> said in <a href="/post/18692">Nothing showing but app is running</a>:</p>
<p dir="auto">updated today and now I have a similar issue. App is running but the screen is black. Ran apt-get update &amp; apt-get upgrade in the hopes it would fix itself, but nope :)</p>
<pre><code>pi@jarvis:~ $ pm2 log
[TAILING] Tailing last 15 lines for [all] processes (change the value with --lines option)
/home/pi/.pm2/pm2.log last 15 lines:
PM2        | 2017-04-02 18:19:27: PM2 PID file         : /home/pi/.pm2/pm2.pid
PM2        | 2017-04-02 18:19:27: RPC socket file      : /home/pi/.pm2/rpc.sock
PM2        | 2017-04-02 18:19:27: BUS socket file      : /home/pi/.pm2/pub.sock
PM2        | 2017-04-02 18:19:27: Application log path : /home/pi/.pm2/logs
PM2        | 2017-04-02 18:19:27: Process dump file    : /home/pi/.pm2/dump.pm2
PM2        | 2017-04-02 18:19:27: Concurrent actions   : 2
PM2        | 2017-04-02 18:19:27: SIGTERM timeout      : 1600
PM2        | 2017-04-02 18:19:27: ===============================================================================
PM2        | 2017-04-02 18:19:27: Starting execution sequence in -fork mode- for app name:mm id:0
PM2        | 2017-04-02 18:19:27: App name:mm id:0 online
PM2        | 2017-04-02 18:21:20: Stopping app:mm id:0
PM2        | 2017-04-02 18:21:20: App [mm] with id [0] and pid [1474], exited with code [0] via signal [SIGINT]
PM2        | 2017-04-02 18:21:20: pid=1474 msg=process killed
PM2        | 2017-04-02 18:26:49: Starting execution sequence in -fork mode- for app name:mm id:0
PM2        | 2017-04-02 18:26:49: App name:mm id:0 online
/home/pi/.pm2/logs/mm-error-0.log last 15 lines:
0|mm       |
0|mm       |
0|mm       | error: cannot open .git/FETCH_HEAD: Permission denied
0|mm       |
0|mm       |
0|mm       | [29012:0402/175739.310033:FATAL:bus.cc(1197)] D-Bus connection was disconnected. Aborting.
0|mm       | #0 0x0000011cf88c
0|mm       | #1 0x0000011bbc1a
0|mm       | #2 0x000001e9a6b6
0|mm       |
0|mm       | [1665:0402/181857.627309:FATAL:bus.cc(1197)] D-Bus connection was disconnected. Aborting.
0|mm       |
/home/pi/.pm2/logs/mm-out-0.log last 15 lines:
0|mm       | Initializing new module helper ...
0|mm       | Module helper loaded: calendar
0|mm       | No helper found for module: currentweather.
0|mm       | No helper found for module: airquality.
0|mm       | No helper found for module: weatherforecast.
0|mm       | No helper found for module: MMM-Hue.
0|mm       | All module helpers loaded.
0|mm       | Starting server on port 8666 ...
0|mm       | Starting server op port 8666 ...
0|mm       | Server started ...
0|mm       | Connecting socket for: updatenotification
0|mm       | Connecting socket for: calendar
0|mm       | Starting node helper for: calendar
0|mm       | Sockets connected &amp; modules started ...
0|mm       | Launching application.
[STREAMING] Now streaming realtime logs for [all] processes
pi@jarvis:~ $ tail -f /home/pi/.pm2/logs/mm-error-0.log
#0 0x0000011cf88c
#1 0x0000011bbc1a
#2 0x000001e9a6b6
#0 0x0000011cf88c
#1 0x0000011bbc1a
#2 0x000001e9a6b6
<p dir="auto">I have the same problem as you. I run the server on a pi zero and the the display is on a pi3 on the same network. It loads fine without any erros on the pi zero but when I go to the website I only get a black screen.</p>
]]></description><link>https://forum.magicmirror.builders/post/18834</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/18834</guid><dc:creator><![CDATA[d3r]]></dc:creator><pubDate>Mon, 03 Apr 2017 16:45:53 GMT</pubDate></item><item><title><![CDATA[Reply to Nothing showing but app is running on Sun, 02 Apr 2017 16:35:48 GMT]]></title><description><![CDATA[<p dir="auto">updated today and now I have a similar issue. App is running but the screen is black. Ran apt-get update &amp; apt-get upgrade in the hopes it would fix itself, but nope :)</p>
0|mm       |
0|mm       |
0|mm       |
0|mm       |
0|mm       |
0|mm       |
#0 0x0000011cf88c
#1 0x0000011bbc1a
#2 0x000001e9a6b6
#0 0x0000011cf88c
#1 0x0000011bbc1a
#2 0x000001e9a6b6
]]></description><link>https://forum.magicmirror.builders/post/18692</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/18692</guid><dc:creator><![CDATA[dikkedimi]]></dc:creator><pubDate>Sun, 02 Apr 2017 16:35:48 GMT</pubDate></item><item><title><![CDATA[Reply to Nothing showing but app is running on Wed, 08 Mar 2017 13:34:53 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/fiskaren" aria-label="Profile: fiskaren">@<bdi>fiskaren</bdi></a> Then i dont know what could be wrong. Perhaps someone else will see this post and can point you in the right direction.<br />
Your solution will start MM each time the computer is started, where pm2 will only start MM, if it was running when the reboot was initiated. But if it works for you.</p>
]]></description><link>https://forum.magicmirror.builders/post/16831</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/16831</guid><dc:creator><![CDATA[mortenbirkelund]]></dc:creator><pubDate>Wed, 08 Mar 2017 13:34:53 GMT</pubDate></item><item><title><![CDATA[Reply to Nothing showing but app is running on Wed, 08 Mar 2017 13:28:25 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mortenbirkelund" aria-label="Profile: mortenbirkelund">@<bdi>mortenbirkelund</bdi></a> Actually I have. Still doesn’t work. The only way I made it finally work was to add “@pm2 start <a href="http://mm.sh" target="_blank" rel="noopener noreferrer nofollow ugc">mm.sh</a>” in "/home/pi/.config/lxsession/LXDE/autostart "</p>
<p dir="auto">I guess that is a OK solution?</p>
]]></description><link>https://forum.magicmirror.builders/post/16830</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/16830</guid><dc:creator><![CDATA[fiskaren]]></dc:creator><pubDate>Wed, 08 Mar 2017 13:28:25 GMT</pubDate></item><item><title><![CDATA[Reply to Nothing showing but app is running on Wed, 08 Mar 2017 13:08:48 GMT]]></title><description><![CDATA[<p dir="auto">Have you saved the current state of the PM2?</p>
<p dir="auto">Run</p>
<pre><code>pm2 start mm.sh
pm2 save
sudo reboot
]]></description><link>https://forum.magicmirror.builders/post/16829</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/16829</guid><dc:creator><![CDATA[mortenbirkelund]]></dc:creator><pubDate>Wed, 08 Mar 2017 13:08:48 GMT</pubDate></item><item><title><![CDATA[Reply to Nothing showing but app is running on Wed, 08 Mar 2017 12:23:16 GMT]]></title><description><![CDATA[<p dir="auto">And I have of couse done the autostart part of the installation. Here is the code for that, if that could be intresting:</p>
<pre><code>pi@raspberrypi:~ $ pm2 startup
[PM2] Init System found: systemd
[PM2] You have to run this command as root. Execute the following command:
sudo env PATH=$PATH:/usr/bin /usr/lib/node_modules/pm2/bin/pm2 startup systemd -u pi --hp /home/pi
pi@raspberrypi:~ $ sudo env PATH=$PATH:/usr/bin /usr/lib/node_modules/pm2/bin/pm2 startup systemd -u pi --hp /home/pi
Platform systemd
Template
[Unit]
Description=PM2 process manager
Documentation=https://pm2.keymetrics.io/
After=network.target
[Service]
Type=forking
User=pi
LimitNOFILE=infinity
LimitNPROC=infinity
LimitCORE=infinity
TimeoutStartSec=8
Environment=PATH=/usr/bin:/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin
Environment=PM2_HOME=/home/pi/.pm2
PIDFile=/home/pi/.pm2/pm2.pid
ExecStart=/usr/lib/node_modules/pm2/bin/pm2 resurrect
ExecReload=/usr/lib/node_modules/pm2/bin/pm2 reload all
ExecStop=/usr/lib/node_modules/pm2/bin/pm2 kill
[Install]
WantedBy=multi-user.target
Target path
/etc/systemd/system/pm2-pi.service
Command list
[ 'chmod +x /etc/systemd/system/pm2-pi.service',
  'systemctl enable pm2-pi',
  'systemctl start pm2-pi',
  'systemctl daemon-reload',
  'systemctl status pm2-pi' ]
[PM2] Writing init configuration in /etc/systemd/system/pm2-pi.service
[PM2] Making script booting at startup...
&gt;&gt;&gt; Executing chmod +x /etc/systemd/system/pm2-pi.service
[DONE]
&gt;&gt;&gt; Executing systemctl enable pm2-pi
[DONE]
&gt;&gt;&gt; Executing systemctl start pm2-pi
[DONE]
&gt;&gt;&gt; Executing systemctl daemon-reload
[DONE]
&gt;&gt;&gt; Executing systemctl status pm2-pi
● pm2-pi.service - PM2 process manager
   Loaded: loaded (/etc/systemd/system/pm2-pi.service; enabled)
   Active: active (running) since Wed 2017-03-08 12:21:50 UTC; 176ms ago
     Docs: https://pm2.keymetrics.io/
 Main PID: 1011 (PM2 v2.4.2: God)
   CGroup: /system.slice/pm2-pi.service
           ‣ 1011 PM2 v2.4.2: God Daemon (/home/pi/.pm2)
Mar 08 12:21:50 raspberrypi pm2[1239]: [PM2] Resurrecting
Mar 08 12:21:50 raspberrypi pm2[1239]: [PM2] Restoring processes located in /home/pi/.pm2/dump.pm2
Mar 08 12:21:50 raspberrypi pm2[1239]: ┌──────────┬────┬──────┬──────┬────────┬─────────┬────────┬─────┬──────────┬──────────┐
Mar 08 12:21:50 raspberrypi pm2[1239]: │ App name │ id │ mode │ pid  │ status │ restart │ uptime │ cpu │ mem      │ watching │
Mar 08 12:21:50 raspberrypi pm2[1239]: ├──────────┼────┼──────┼──────┼────────┼─────────┼────────┼─────┼──────────┼──────────┤
Mar 08 12:21:50 raspberrypi pm2[1239]: │ mm       │ 0  │ fork │ 1021 │ online │ 0       │ 7m     │ 0%  │ 2.3 MB   │ disabled │
Mar 08 12:21:50 raspberrypi pm2[1239]: └──────────┴────┴──────┴──────┴────────┴─────────┴────────┴─────┴──────────┴──────────┘
Mar 08 12:21:50 raspberrypi pm2[1239]: Use `pm2 show ` to get more details about an app
Mar 08 12:21:50 raspberrypi systemd[1]: Started PM2 process manager.
[DONE]
[PM2] Freeze a process list on reboot via:
$ pm2 save
[PM2] Remove init script via:
$ pm2 unstartup systemd
]]></description><link>https://forum.magicmirror.builders/post/16821</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/16821</guid><dc:creator><![CDATA[fiskaren]]></dc:creator><pubDate>Wed, 08 Mar 2017 12:23:16 GMT</pubDate></item><item><title><![CDATA[Reply to Nothing showing but app is running on Wed, 08 Mar 2017 12:20:24 GMT]]></title><description><![CDATA[<p dir="auto">Well, I did a reinstall and now the mirror starts when executing command. It does NOT start on boot tho, so main problem gone but we got a new one…</p>
<p dir="auto">I guess I use VNC? SSH on Putty!</p>
<p dir="auto">pm2 start <a href="http://mm.sh" target="_blank" rel="noopener noreferrer nofollow ugc">mm.sh</a> response:</p>
<pre><code>//[PM2] Spawning PM2 daemon with pm2_home=/home/pi/.pm2
[PM2] PM2 Successfully daemonized
[PM2] Starting /home/pi/mm.sh in fork_mode (1 instance)
[PM2] Done.
│ Name │ mode │ status │ ↺ │ cpu │ memory   │
│ mm   │ fork │ online │ 0 │ 0%  │ 2.3 MB   │
<p dir="auto">pm2 logs mm</p>
<pre><code>[TAILING] Tailing last 15 lines for [mm] process (change the value with --lines option)
0|mm       | [5113:0308/120902.949357:FATAL:bus.cc(1197)] D-Bus connection was disconnected. Aborting.
0|mm       |
0|mm       | Starting server op port 8080 ...
0|mm       | Connecting socket for: newsfeed
0|mm       | Starting module: newsfeed
0|mm       | Create new calendar fetcher for url: http://www.calendarlabs.com/templates/ical/US-Holidays.ics - Interval: 300000
0|mm       | Create new news fetcher for url: http://www.nytimes.com/services/xml/rss/nyt/HomePage.xml - Interval: 300000
[STREAMING] Now streaming realtime logs for [mm] process
<p dir="auto">pm2 logs mm --lines 50</p>
<pre><code>[TAILING] Tailing last 50 lines for [mm] process (change the value with --lines option)
/home/pi/.pm2/logs/mm-error-0.log last 50 lines:
0|mm       |
/home/pi/.pm2/logs/mm-out-0.log last 50 lines:
0|mm       | Starting MagicMirror: v2.1.0
0|mm       | Loading config ...
0|mm       | Loading module helpers ...
0|mm       | No helper found for module: alert.
0|mm       | No helper found for module: clock.
0|mm       | No helper found for module: compliments.
0|mm       |
0|mm       | &gt; magicmirror@2.1.0 start /home/pi/MagicMirror
0|mm       | &gt; electron js/electron.js
0|mm       |
]]></description><link>https://forum.magicmirror.builders/post/16820</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/16820</guid><dc:creator><![CDATA[fiskaren]]></dc:creator><pubDate>Wed, 08 Mar 2017 12:20:24 GMT</pubDate></item><item><title><![CDATA[Reply to Nothing showing but app is running on Wed, 08 Mar 2017 08:35:20 GMT]]></title><description><![CDATA[<p dir="auto">Can we see the content of your <a href="http://mm.sh" target="_blank" rel="noopener noreferrer nofollow ugc">mm.sh</a> script?<br />
What is the response when you start the <a href="http://mm.sh" target="_blank" rel="noopener noreferrer nofollow ugc">mm.sh</a> script ? (pm2 start <a href="http://mm.sh" target="_blank" rel="noopener noreferrer nofollow ugc">mm.sh</a>).</p>
<p dir="auto">Are you connecting using VNC?</p>
]]></description><link>https://forum.magicmirror.builders/post/16795</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/16795</guid><dc:creator><![CDATA[mortenbirkelund]]></dc:creator><pubDate>Wed, 08 Mar 2017 08:35:20 GMT</pubDate></item></channel></rss>
