<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[MMM-AtomVisualizer language]]></title><description><![CDATA[<p dir="auto">Hello <a class="plugin-mentions-user plugin-mentions-a" href="/user/kristjanesperanto" aria-label="Profile: kristjanesperanto">@<bdi>kristjanesperanto</bdi></a>, I saw you are AtomVisualizer module’s developer.<br />
Kindly, I need to ask where do I have to go to select the language.<br />
I saw something about “getTranslation” inside MMM-AtomVisualizer.js but I didn’t understand where do I have to act to have an EN translation.<br />
Thanks in advance, I’m sure I am the problem but I’m not very skilled on these configurations.<br />
In the config option parameter I don’t see anything about language.<br />
Thanks again</p>
]]></description><link>https://forum.magicmirror.builders/topic/20178/mmm-atomvisualizer-language</link><generator>RSS for Node</generator><lastBuildDate>Fri, 04 Sep 2026 17:11:19 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/20178.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 25 Mar 2026 23:01:53 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to MMM-AtomVisualizer language on Mon, 30 Mar 2026 21:09:15 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/kristjanesperanto" aria-label="Profile: KristjanESPERANTO">@<bdi>KristjanESPERANTO</bdi></a><br />
Nice!<br />
Thank you</p>
]]></description><link>https://forum.magicmirror.builders/post/130540</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/130540</guid><dc:creator><![CDATA[nowayto]]></dc:creator><pubDate>Mon, 30 Mar 2026 21:09:15 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-AtomVisualizer language on Mon, 30 Mar 2026 20:23:11 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/nowayto" aria-label="Profile: nowayto">@<bdi>nowayto</bdi></a> <a href="/post/130534">said</a>:</p>
<p dir="auto">what should I write inside the [] parenthesis to cycle through all the elements?</p>
<p dir="auto">I just released version 0.1.5. With this update, all elements are used when the array is empty 🙂</p>
]]></description><link>https://forum.magicmirror.builders/post/130539</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/130539</guid><dc:creator><![CDATA[KristjanESPERANTO]]></dc:creator><pubDate>Mon, 30 Mar 2026 20:23:11 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-AtomVisualizer language on Sun, 29 Mar 2026 21:04:11 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/nowayto" aria-label="Profile: nowayto">@<bdi>nowayto</bdi></a> <a class="plugin-mentions-user plugin-mentions-a" href="/user/kristjanesperanto" aria-label="Profile: kristjanesperanto">@<bdi>kristjanesperanto</bdi></a> will have to answer that.</p>
]]></description><link>https://forum.magicmirror.builders/post/130537</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/130537</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sun, 29 Mar 2026 21:04:11 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-AtomVisualizer language on Sun, 29 Mar 2026 20:45:08 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> I know the elements abbreviations.<br />
I was just thinking if there was a way to “cycle all elements” instead of writing 110/120 elements inside the config</p>
]]></description><link>https://forum.magicmirror.builders/post/130536</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/130536</guid><dc:creator><![CDATA[nowayto]]></dc:creator><pubDate>Sun, 29 Mar 2026 20:45:08 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-AtomVisualizer language on Sun, 29 Mar 2026 20:34:13 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/nowayto" aria-label="Profile: nowayto">@<bdi>nowayto</bdi></a> see<br />
<a href="https://www.thoughtco.com/element-symbols-list-606530" target="_blank" rel="noopener noreferrer nofollow ugc">https://www.thoughtco.com/element-symbols-list-606530</a></p>
]]></description><link>https://forum.magicmirror.builders/post/130535</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/130535</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sun, 29 Mar 2026 20:34:13 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-AtomVisualizer language on Sun, 29 Mar 2026 20:24:35 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> Yeah, I will do that, I just wanna say it worked.</p>
<p dir="auto">Another detail, default configuration has this line:</p>
<p dir="auto">elements: [“H”, “He”, “Li”, “C”, “N”, “O”, “Ne”, “Na”, “Fe”, “Cu”, “Ag”, “Xe”],</p>
]]></description><link>https://forum.magicmirror.builders/post/130534</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/130534</guid><dc:creator><![CDATA[nowayto]]></dc:creator><pubDate>Sun, 29 Mar 2026 20:24:35 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-AtomVisualizer language on Sun, 29 Mar 2026 15:07:11 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/nowayto" aria-label="Profile: nowayto">@<bdi>nowayto</bdi></a> he also uploaded a fix, so you could have used that.<br />
to get it do</p>
<pre><code class="language-bash">cd ~/MagicMirror/modules/MMM-AtomVisualizer
git checkout MMM-AtomVisualizer.js
git pull
<p dir="auto">then restart MagicMirror</p>
<p dir="auto">this restores the file to the last local repo version<br />
then updates with the new</p>
<p dir="auto">I wasn’t suggesting KEEPING the locally modified, it was only for testing.<br />
til a fix… and there is one now</p>
]]></description><link>https://forum.magicmirror.builders/post/130532</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/130532</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sun, 29 Mar 2026 15:07:11 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-AtomVisualizer language on Sun, 29 Mar 2026 08:34:22 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/kristjanesperanto" aria-label="Profile: kristjanesperanto">@<bdi>kristjanesperanto</bdi></a> thanks for your answer.<br />
I solved like <a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> said, simply changing the order  inside AtomVisualizer config and it worked.<br />
Usually my rule is to never modify items inside modules folders so I though there was a way to set it from the config.js like other modules but might be I didn’t understand it, that’s why I asked here :)<br />
It’s a nice module, I like it!<br />
Thanks again for your support guys.</p>
]]></description><link>https://forum.magicmirror.builders/post/130530</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/130530</guid><dc:creator><![CDATA[nowayto]]></dc:creator><pubDate>Sun, 29 Mar 2026 08:34:22 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-AtomVisualizer language on Thu, 26 Mar 2026 13:23:36 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> Ok, in the past I think I set up the system in Italian.<br />
So I’ll try to switch the order and, eventually, I’ll switch the language. Thanks</p>
]]></description><link>https://forum.magicmirror.builders/post/130519</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/130519</guid><dc:creator><![CDATA[nowayto]]></dc:creator><pubDate>Thu, 26 Mar 2026 13:23:36 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-AtomVisualizer language on Thu, 26 Mar 2026 03:28:04 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/kristjanesperanto" aria-label="Profile: KristjanESPERANTO">@<bdi>KristjanESPERANTO</bdi></a>  yeh I think this is a general bug.</p>
<p dir="auto">Even if you had a parm, could change the order. It’s called before start.</p>
<p dir="auto">even so, I was wrong, this.config points the the proper module config at the time of getTranslations()<br />
so it could customize the returned language list</p>
]]></description><link>https://forum.magicmirror.builders/post/130517</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/130517</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Thu, 26 Mar 2026 03:28:04 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-AtomVisualizer language on Thu, 26 Mar 2026 00:03:01 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> <a href="/post/130515">said</a>:</p>
<p dir="auto">I think the first in the getTranslations list is the default.</p>
<p dir="auto">Ah, yes the first is used as the fallback language. It was German, which is not the best choice :-)</p>
<p dir="auto">I changed it to English and released a new version.</p>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/nowayto" aria-label="Profile: nowayto">@<bdi>nowayto</bdi></a> Please update and check 🙂</p>
]]></description><link>https://forum.magicmirror.builders/post/130516</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/130516</guid><dc:creator><![CDATA[KristjanESPERANTO]]></dc:creator><pubDate>Thu, 26 Mar 2026 00:03:01 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-AtomVisualizer language on Wed, 25 Mar 2026 23:35:28 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/nowayto" aria-label="Profile: nowayto">@<bdi>nowayto</bdi></a> it should just work if your system is set to English<br />
If not set to English, then I think the first in the getTranslations list is the default.</p>
<p dir="auto">So if you change the order it should work</p>
]]></description><link>https://forum.magicmirror.builders/post/130515</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/130515</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Wed, 25 Mar 2026 23:35:28 GMT</pubDate></item></channel></rss>
