<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[New Install]]></title><description><![CDATA[<p dir="auto">I had been using MM for over a year before the MM2 came out and had issues with updates, so turned it off for good.</p>
<p dir="auto">I’ve decided to give it another go, but wondering the simplest install, that will give auto updates?</p>
<p dir="auto">Thanks</p>
]]></description><link>https://forum.magicmirror.builders/topic/20187/new-install</link><generator>RSS for Node</generator><lastBuildDate>Tue, 09 Jun 2026 14:52:29 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/20187.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 01 Apr 2026 18:04:16 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to New Install on Wed, 01 Apr 2026 19:53:08 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/bungle68" aria-label="Profile: Bungle68">@<bdi>Bungle68</bdi></a> there is no auto update.</p>
<p dir="auto">You can go the manual install/update or use the scripted install/update. For the base. See the doc, alternative install<br />
My script are first there</p>
<p dir="auto">There are various mechanisms for modules</p>
]]></description><link>https://forum.magicmirror.builders/post/130563</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/130563</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Wed, 01 Apr 2026 19:53:08 GMT</pubDate></item><item><title><![CDATA[Reply to New Install on Wed, 01 Apr 2026 18:19:55 GMT]]></title><description><![CDATA[<p dir="auto">I’m running a Pi 3B+ and have a clean install of the Pi OS too</p>
]]></description><link>https://forum.magicmirror.builders/post/130556</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/130556</guid><dc:creator><![CDATA[Bungle68]]></dc:creator><pubDate>Wed, 01 Apr 2026 18:19:55 GMT</pubDate></item></channel></rss>
