<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[OpenWeatherMapForecast stopped working]]></title><description><![CDATA[<p dir="auto">Hi,<br />
The OpenWeatherMapForecast stopped working as of this morning.<br />
MM has been running for a few months without any problem, but now no wheater data is displayed.</p>
<p dir="auto">I use this code in the config file:</p>
<p dir="auto">module: “weather”,<br />
position: “top_right”,<br />
header: “Current:”,<br />
config: {<br />
weatherProvider: “openmeteo”,<br />
type: “current”,<br />
lat: xxxxxxxx,<br />
lon: xxxxxxxx,<br />
tempUnits: “metric”,<br />
showSun: true,<br />
showWindDirection: false,<br />
showWindDirAsArrow: false,<br />
showHumidity: true,<br />
degreeLabel: true,<br />
showUVIndex: false,<br />
showIndoorTemperature: true,<br />
showIndoorHumidity: true,<br />
showPrecipitationAmount: false,<br />
showPrecipitationProbability: false,<br />
onlyTemp: false,<br />
hideCredits: true,<br />
}</p>
<p dir="auto">When I look in the MM log file I see this error:<br />
0|mm       | [2026-04-07 08:46:28.496] [ERROR] [http_fetcher] [weatherprovider.openmeteo] Server error (502). Retry #1 in 20 minutes</p>
<p dir="auto">Could someone help me solving this.</p>
]]></description><link>https://forum.magicmirror.builders/topic/20203/openweathermapforecast-stopped-working</link><generator>RSS for Node</generator><lastBuildDate>Tue, 07 Apr 2026 23:07:31 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/20203.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 07 Apr 2026 07:00:08 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to OpenWeatherMapForecast stopped working on Tue, 07 Apr 2026 13:35:48 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/vpeter" aria-label="Profile: VPeter">@<bdi>VPeter</bdi></a> custom.css should only be in the config folder on version. 2.35</p>
]]></description><link>https://forum.magicmirror.builders/post/130699</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/130699</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Tue, 07 Apr 2026 13:35:48 GMT</pubDate></item><item><title><![CDATA[Reply to OpenWeatherMapForecast stopped working on Tue, 07 Apr 2026 13:09:57 GMT]]></title><description><![CDATA[<p dir="auto">Thank you everyone. The custom.css was moved to the config folder. I made a copy in the css folder and now everything is working.</p>
]]></description><link>https://forum.magicmirror.builders/post/130698</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/130698</guid><dc:creator><![CDATA[VPeter]]></dc:creator><pubDate>Tue, 07 Apr 2026 13:09:57 GMT</pubDate></item><item><title><![CDATA[Reply to OpenWeatherMapForecast stopped working on Tue, 07 Apr 2026 12:56:25 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mrpringless" aria-label="Profile: MrPringless">@<bdi>MrPringless</bdi></a> thx. Was interested in HOW you upgraded MagicMirror</p>
<p dir="auto">git pull , aka manual<br />
Or<br />
My upgrade script?</p>
<p dir="auto">Trying to find the cause of the lost<br />
Custom.css</p>
]]></description><link>https://forum.magicmirror.builders/post/130697</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/130697</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Tue, 07 Apr 2026 12:56:25 GMT</pubDate></item><item><title><![CDATA[Reply to OpenWeatherMapForecast stopped working on Tue, 07 Apr 2026 12:17:31 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a><br />
Before the MM-Update i copy all MagicMirror folders in an Backup folder.  MM write in the backup guide:<br />
Upgrade Guide<br />
WARNING</p>
<p dir="auto">Always backup your config.js, custom.css and modules folder before you start the upgrade process!</p>
<ol>
<li>Stop MM</li>
<li>Copy my Backuped custom.css back in CSS folder</li>
<li>open with Geany  save and Close</li>
<li>Start MM and it Works</li>
<li>I Rebootet mi Pi for testing and it continues Working.</li>
</ol>
<p dir="auto">Sorry for my English</p>
]]></description><link>https://forum.magicmirror.builders/post/130696</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/130696</guid><dc:creator><![CDATA[MrPringless]]></dc:creator><pubDate>Tue, 07 Apr 2026 12:17:31 GMT</pubDate></item><item><title><![CDATA[Reply to OpenWeatherMapForecast stopped working on Tue, 07 Apr 2026 12:05:50 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mrpringless" aria-label="Profile: MrPringless">@<bdi>MrPringless</bdi></a> how did you update?<br />
custom.css should have been moved to the config folder</p>
]]></description><link>https://forum.magicmirror.builders/post/130695</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/130695</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Tue, 07 Apr 2026 12:05:50 GMT</pubDate></item><item><title><![CDATA[Reply to OpenWeatherMapForecast stopped working on Tue, 07 Apr 2026 12:04:31 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/vpeter" aria-label="Profile: vpeter">@<bdi>vpeter</bdi></a><br />
Hi,<br />
i have the same issue.  After rebooting the  Weather leave blank. Do you have  a custom.css  file before the MM-Update?  The update erase this file. I recopy mi backuped custom.css and now it Works fine how bevore.</p>
]]></description><link>https://forum.magicmirror.builders/post/130694</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/130694</guid><dc:creator><![CDATA[MrPringless]]></dc:creator><pubDate>Tue, 07 Apr 2026 12:04:31 GMT</pubDate></item><item><title><![CDATA[Reply to OpenWeatherMapForecast stopped working on Tue, 07 Apr 2026 11:49:45 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/vpeter" aria-label="Profile: VPeter">@<bdi>VPeter</bdi></a> looks like the openmeteo server is having trouble</p>
]]></description><link>https://forum.magicmirror.builders/post/130692</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/130692</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Tue, 07 Apr 2026 11:49:45 GMT</pubDate></item></channel></rss>
