<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[MMM-CalendarExt3 - Timed events color change]]></title><description><![CDATA[<p dir="auto">Hi all,</p>
<p dir="auto">I’m running into an issue with MMM-CalendarExt3 when trying to set event colours based on the calendar name ( I have 4 different calendars displayed in CalendarExt3)</p>
<p dir="auto">What I’m trying to do:</p>
<ul>
<li>Assign different colours to events depending on which calendar they come from</li>
</ul>
<p dir="auto">The problem:</p>
<ul>
<li>The colour styling works correctly for all-day events, and will change the background bubble for the all day events.</li>
<li>However, for non all-day (timed) events, the colour does not get applied at all - it doesn’t have a bubble, nor does the front or anything change.</li>
</ul>
<p dir="auto">What I’ve checked so far:</p>
<ul>
<li>The calendar name is definitely correct and matches what I’m targeting</li>
<li>Styling appears to apply fine in general, just not for timed events ( as above)</li>
<li>I have tested ev.transformers with modifying the title and it has worked on time events and all days events without issue</li>
<li>It feels like timed events might be using a different class or structure</li>
</ul>
<p dir="auto">What I’m trying to understand:</p>
<ol>
<li>Do timed events use a different class name or structure compared to all-day events?</li>
<li>Is there a different selector required to target timed events specifically?</li>
<li>Is this expected behaviour, or am I missing something in the config/CSS?</li>
</ol>
<p dir="auto">If anyone has successfully styled timed events based on calendar name, I’d really appreciate an example or pointer.</p>
<p dir="auto">Thanks 👍</p>
]]></description><link>https://forum.magicmirror.builders/topic/20213/mmm-calendarext3-timed-events-color-change</link><generator>RSS for Node</generator><lastBuildDate>Tue, 14 Apr 2026 12:35:44 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/20213.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 13 Apr 2026 18:20:04 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to MMM-CalendarExt3 - Timed events color change on Mon, 13 Apr 2026 21:38:09 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/cybex999" aria-label="Profile: Cybex999">@<bdi>Cybex999</bdi></a> all you should have to do is set the color in the default calendar for each url</p>
<p dir="auto">Make sure you set coloredText:true,<br />
Before the url list</p>
]]></description><link>https://forum.magicmirror.builders/post/130784</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/130784</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Mon, 13 Apr 2026 21:38:09 GMT</pubDate></item></channel></rss>
