<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Install scripts won&#x27;t install?]]></title><description><![CDATA[<p dir="auto">Every attempt shows the below. I am stumped any help is appreciated.</p>
<p dir="auto">ys@raspberry:~ $ bash -c  “$(curl -sL <a href="https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/raspberry.sh" target="_blank" rel="noopener noreferrer nofollow ugc">https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/raspberry.sh</a>)”</p>
<p dir="auto">$$\      $$\                     $$\           $$\      $$\ $$\                                          $$$$$$<br />
$$$\    $$$ |                    _<em>|          $$$\    $$$ |_</em>|                                        $$  <strong>$$<br />
$$$$\  $$$$ | $$$$$$\   $$$$$$\  $$\  $$$$$$$\ $$$$\  $$$$ |$$\  $$$$$$\   $$$$$$\   $$$$$$\   $$$$$$\  _<em>/  $$ |<br />
$$$$$$ $$ | _</em></strong>$$\ $$  <strong>$$\ $$ |$$  <strong><em><strong>|$$$$$$ $$ |$$ |$$  <strong>$$\ $$  <strong>$$\ $$  <em><em>$$\ $$  <strong>$$\  $$$$$$  |<br />
$$ $$$  $$ | $$$$$$$ |$$ /  $$ |$$ |$$ /      $$ $$$  $$ |$$ |$$ |  _<em>|$$ |  _</em>|$$ /  $$ |$$ |  _<em>|$$  <strong><em><em>/<br />
$$ |$  /$$ |$$  __$$ |$$ |  $$ |$$ |$$ |      $$ |$  /$$ |$$ |$$ |      $$ |      $$ |  $$ |$$ |      $$ |<br />
$$ | _/ $$ |$$$$$$$ |$$$$$$$ |$$ |$$$$$$$\ $$ | _/ $$ |$$ |$$ |      $$ |      $$$$$$  |$$ |      $$$$$$$$<br />
_</em>|     _</em>| _</strong></em></strong></em>| _</em></strong>$$ |_<em>| _</em></strong></strong></em>|_<em>|     _</em>|_<em>|_</em>|      __|       _</strong></strong><em>/ _<em>|      _</em>______|<br />
$$\   $$ |<br />
$$$$$$  |<br />
_</em>____/</p>
<p dir="auto">install log being saved to /home/hhays/install.log<br />
Updating packages …<br />
Installing helper tools …<br />
nvm_command is export NVM_DIR=/home/hhays/.config/nvm; . “/home/hhays/.config/nvm/nvm.sh” [ -s “/home/hhays/.config/nvm/nvm.sh” ] &amp;&amp; . “/home/hhays/.config/nvm/nvm.sh”; nvm install v22.21.1 nvm uninstall<br />
node failed to execute, please check the error message and resolve before trying again</p>
]]></description><link>https://forum.magicmirror.builders/topic/20221/install-scripts-won-t-install</link><generator>RSS for Node</generator><lastBuildDate>Wed, 17 Jun 2026 15:53:38 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/20221.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 20 Apr 2026 17:38:47 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Install scripts won&#x27;t install? on Wed, 13 May 2026 15:57:18 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> Sorry for the late reply, family happens… I Gave up on Pi and just wiped the machine and installed ubuntu. Scripts worked flawlessly then Thanks…</p>
]]></description><link>https://forum.magicmirror.builders/post/131136</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/131136</guid><dc:creator><![CDATA[heath1066]]></dc:creator><pubDate>Wed, 13 May 2026 15:57:18 GMT</pubDate></item><item><title><![CDATA[Reply to Install scripts won&#x27;t install? on Wed, 13 May 2026 16:40:04 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/heath1066" aria-label="Profile: heath1066">@<bdi>heath1066</bdi></a> awesome.</p>
]]></description><link>https://forum.magicmirror.builders/post/131137</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/131137</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Wed, 13 May 2026 16:40:04 GMT</pubDate></item><item><title><![CDATA[Reply to Install scripts won&#x27;t install? on Wed, 13 May 2026 15:57:18 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> Sorry for the late reply, family happens… I Gave up on Pi and just wiped the machine and installed ubuntu. Scripts worked flawlessly then Thanks…</p>
]]></description><link>https://forum.magicmirror.builders/post/131136</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/131136</guid><dc:creator><![CDATA[heath1066]]></dc:creator><pubDate>Wed, 13 May 2026 15:57:18 GMT</pubDate></item><item><title><![CDATA[Reply to Install scripts won&#x27;t install? on Mon, 20 Apr 2026 21:52:35 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/heath1066" aria-label="Profile: heath1066">@<bdi>heath1066</bdi></a> weird</p>
<p dir="auto">try this</p>
<pre><code>sudo apt update
sudo apt install libstdc++6
<p dir="auto">then if successful</p>
<pre><code>sudo n 22.21.1
]]></description><link>https://forum.magicmirror.builders/post/130848</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/130848</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Mon, 20 Apr 2026 21:52:35 GMT</pubDate></item><item><title><![CDATA[Reply to Install scripts won&#x27;t install? on Mon, 20 Apr 2026 21:32:31 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> I will have to send later this eve, but here:</p>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/raspberry" aria-label="Profile: raspberry">@<bdi>raspberry</bdi></a>:~ $ uname -a<br />
Linux raspberry 5.10.0-39-amd64 #1 SMP Debian 5.10.251-1 (2026-03-09) x86_64 GNU/Linux</p>
]]></description><link>https://forum.magicmirror.builders/post/130847</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/130847</guid><dc:creator><![CDATA[heath1066]]></dc:creator><pubDate>Mon, 20 Apr 2026 21:32:31 GMT</pubDate></item><item><title><![CDATA[Reply to Install scripts won&#x27;t install? on Mon, 20 Apr 2026 21:11:01 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/heath1066" aria-label="Profile: heath1066">@<bdi>heath1066</bdi></a> well then.</p>
<p dir="auto">uname -a</p>
]]></description><link>https://forum.magicmirror.builders/post/130845</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/130845</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Mon, 20 Apr 2026 21:11:01 GMT</pubDate></item><item><title><![CDATA[Reply to Install scripts won&#x27;t install? on Mon, 20 Apr 2026 20:55:57 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a><br />
spberry:~ $ lsb_release -a<br />
No LSB modules are available.<br />
Distributor ID:	Debian<br />
Description:	Debian GNU/Linux 11 (bullseye)<br />
Release:	11<br />
Codename:	bullseye</p>
]]></description><link>https://forum.magicmirror.builders/post/130844</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/130844</guid><dc:creator><![CDATA[heath1066]]></dc:creator><pubDate>Mon, 20 Apr 2026 20:55:57 GMT</pubDate></item><item><title><![CDATA[Reply to Install scripts won&#x27;t install? on Mon, 20 Apr 2026 20:46:31 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/heath1066" aria-label="Profile: heath1066">@<bdi>heath1066</bdi></a> oh, are you on buster?  Or 32 bit system?<br />
Do</p>
<pre><code>lsb_release -a
<p dir="auto">Can you send me the ~/install.log?</p>
<p dir="auto">Same userid as here on Gmail. Thx</p>
]]></description><link>https://forum.magicmirror.builders/post/130843</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/130843</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Mon, 20 Apr 2026 20:46:31 GMT</pubDate></item><item><title><![CDATA[Reply to Install scripts won&#x27;t install? on Mon, 20 Apr 2026 19:47:28 GMT]]></title><description><![CDATA[<p dir="auto">errors in shared libraries now</p>
<p dir="auto">hhays@raspberry:~ $ n --version<br />
10.2.0<br />
hhays@raspberry:~ $ sudo n 22.21.1<br />
installing : node-v22.21.1<br />
mkdir : /usr/local/n/versions/node/22.21.1<br />
fetch : <a href="https://nodejs.org/dist/v22.21.1/node-v22.21.1-linux-x64.tar.xz" target="_blank" rel="noopener noreferrer nofollow ugc">https://nodejs.org/dist/v22.21.1/node-v22.21.1-linux-x64.tar.xz</a><br />
copying : node/22.21.1<br />
node: error while loading shared libraries: libstdc++.so.6: cannot open shared object file: No such file or directory<br />
/usr/local/bin/node: error while loading shared libraries: libstdc++.so.6: cannot open shared object file: No such file or directory<br />
installed :  (with npm )</p>
]]></description><link>https://forum.magicmirror.builders/post/130842</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/130842</guid><dc:creator><![CDATA[heath1066]]></dc:creator><pubDate>Mon, 20 Apr 2026 19:47:28 GMT</pubDate></item><item><title><![CDATA[Reply to Install scripts won&#x27;t install? on Mon, 20 Apr 2026 18:26:17 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/heath1066" aria-label="Profile: heath1066">@<bdi>heath1066</bdi></a> ok, try the command n</p>
<p dir="auto">If it is not found do</p>
<pre><code>sudo npm install -g n
<p dir="auto">Then</p>
<pre><code>n —version
<p dir="auto">Should work</p>
<p dir="auto">If so then do</p>
hash -r
node -version
<p dir="auto">Should say 22.21.1</p>
<p dir="auto">If so, then rerun install script</p>
]]></description><link>https://forum.magicmirror.builders/post/130841</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/130841</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Mon, 20 Apr 2026 18:26:17 GMT</pubDate></item><item><title><![CDATA[Reply to Install scripts won&#x27;t install? on Mon, 20 Apr 2026 18:14:06 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> install v22.21.1 failed.</p>
]]></description><link>https://forum.magicmirror.builders/post/130840</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/130840</guid><dc:creator><![CDATA[heath1066]]></dc:creator><pubDate>Mon, 20 Apr 2026 18:14:06 GMT</pubDate></item><item><title><![CDATA[Reply to Install scripts won&#x27;t install? on Mon, 20 Apr 2026 18:03:32 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/heath1066" aria-label="Profile: heath1066">@<bdi>heath1066</bdi></a> interesting</p>
<p dir="auto">Open a terminal window, then do</p>
<pre><code>nvm install v22.21.1
<p dir="auto">If successful,<br />
do</p>
<pre><code>hash -r
node -v
<p dir="auto">Should report v22.21.1<br />
If correct, then rerun the install script</p>
<p dir="auto">Please advise. I’ll fix my script</p>
]]></description><link>https://forum.magicmirror.builders/post/130839</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/130839</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Mon, 20 Apr 2026 18:03:32 GMT</pubDate></item></channel></rss>
