<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Node&#x2F;NPM not installed?]]></title><description><![CDATA[<p dir="auto">I’m not sure what happened but it seems that npm and node are no longer set up on my RPi.  The MM seems to run fine but updating (npm install) modules returns “-bash: npm:” command not found".</p>
<p dir="auto">I did “node -v” and got the same error (only “node” instead of “npm”).</p>
<p dir="auto">Is there an easy way to get this set up correctly again?</p>
<p dir="auto">Thanks!</p>
]]></description><link>https://forum.magicmirror.builders/topic/20226/node-npm-not-installed</link><generator>RSS for Node</generator><lastBuildDate>Tue, 28 Apr 2026 19:32:57 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/20226.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 27 Apr 2026 22:54:54 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Node&#x2F;NPM not installed? on Tue, 28 Apr 2026 17:37:42 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a></p>
<p dir="auto">P.S.,  I really appreciate all your help, not just for me but for everyone.  You really are a rock star!</p>
]]></description><link>https://forum.magicmirror.builders/post/130914</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/130914</guid><dc:creator><![CDATA[UncleRoger]]></dc:creator><pubDate>Tue, 28 Apr 2026 17:37:42 GMT</pubDate></item><item><title><![CDATA[Reply to Node&#x2F;NPM not installed? on Tue, 28 Apr 2026 16:07:57 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/uncleroger" aria-label="Profile: UncleRoger">@<bdi>UncleRoger</bdi></a> sadly yes…</p>
<p dir="auto">my scripts will backup/restore your config… maybe save them to github to reinstall…<br />
and then the installer script does the  base…</p>
<p dir="auto">so, its backup<br />
make a new sd card<br />
install mm via script<br />
restore the config</p>
<p dir="auto">should be back where you were… in a couple hours</p>
<p dir="auto">my scripts work over ssh… so no physical connection required</p>
]]></description><link>https://forum.magicmirror.builders/post/130912</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/130912</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Tue, 28 Apr 2026 16:07:57 GMT</pubDate></item><item><title><![CDATA[Reply to Node&#x2F;NPM not installed? on Tue, 28 Apr 2026 16:04:48 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a></p>
<p dir="auto">Okay, so I should back everything up, install MM on a new card, and then reinstall config/css/etc.?   Ugh.</p>
<p dir="auto">One of these days, I’m going to rebuild everything (physical stuff) to make it easier to access the RPi and all.</p>
]]></description><link>https://forum.magicmirror.builders/post/130911</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/130911</guid><dc:creator><![CDATA[UncleRoger]]></dc:creator><pubDate>Tue, 28 Apr 2026 16:04:48 GMT</pubDate></item><item><title><![CDATA[Reply to Node&#x2F;NPM not installed? on Mon, 27 Apr 2026 23:04:06 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/uncleroger" aria-label="Profile: UncleRoger">@<bdi>UncleRoger</bdi></a> this seems to indicate a failing SD card… get backed up ASAP…</p>
<p dir="auto">use my backup/restore scripts if nothing else. see<br />
<a href="https://github.com/sdetweil/MagicMirror-backup-restore" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/sdetweil/MagicMirror-backup-restore</a></p>
]]></description><link>https://forum.magicmirror.builders/post/130894</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/130894</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Mon, 27 Apr 2026 23:04:06 GMT</pubDate></item></channel></rss>
