<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[multiple error in magic mirror after update from 2.28.0 to 2.36.0]]></title><description><![CDATA[<p dir="auto">uhm hi, its been awhile since i updated my MM.</p>
<p dir="auto">i ran sdetweil upgrade script and these were being upgrade.</p>
<pre><code>doing test run = false
Node currently installed. Checking version number.
Minimum Node version: v22.21.1
Installed Node version: v20.9.0
installing correct version of node and npm, please wait
Check current Node installation ...
Installed Node version: v22.21.1
No Node.js upgrade necessary.
Check current NPM installation ...
NPM currently installed. Checking version number.
Minimum npm version: V10.9.4
Installed npm version: V10.9.4
No npm upgrade necessary.
saving custom.css
upgrading from version 2.28.0 to 2.36.0
fetching latest revisions
updating MagicMirror runtime, please wait
&gt; magicmirror@2.36.0 postinstall
&gt; git clean -df fonts vendor modules/default
&gt; magicmirror@2.36.0 prepare
&gt; [ -f node_modules/.bin/husky ] &amp;&amp; husky || echo no husky installed.
no husky installed.
<p dir="auto">i then tried to pm2 start and ran into this error. Ok not exactly error, but the mirror just keep going to blackscreen and nothing then back to wall paper then blackscreen and keep looping this.</p>
<pre><code>(node:1971942) [DEP0044] DeprecationWarning: The `util.isArray` API is deprecated. Please use `Array.isArray()` instead.
(Use `node --trace-deprecation ...` to show where the warning was created)
<p dir="auto">then i ran npm start and get the punycode error</p>
<pre><code>[ERROR] [unknown] (node:1970698) [DEP0040] DeprecationWarning: The `punycode` module is deprecated. Please use a userland alternative instead.
(Use `electron --trace-deprecation ...` to show where the warning was created)
[1970698:0501/224750.044913:ERROR:ui/ozone/platform/wayland/host/wayland_connection.cc:202] Failed to connect to Wayland display: No such file or directory (2)
[1970698:0501/224750.044978:ERROR:ui/ozone/platform/wayland/ozone_platform_wayland.cc:281] Failed to initialize Wayland platform
[1970698:0501/224750.044995:ERROR:ui/aura/env.cc:246] The platform failed to initialize.  Exiting.
/home/hsa/MagicMirror/node_modules/electron/dist/electron exited with signal SIGSEGV
<p dir="auto">i then read in another thread to do npm run start:x11<br />
this works but the punycode still appear but mirror runs.</p>
<p dir="auto">feels like theres multiple item for me to fix and im kinda lost.</p>
<p dir="auto">can some kind soul help me out?</p>
]]></description><link>https://forum.magicmirror.builders/topic/20231/multiple-error-in-magic-mirror-after-update-from-2.28.0-to-2.36.0</link><generator>RSS for Node</generator><lastBuildDate>Sat, 02 May 2026 12:43:47 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/20231.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 01 May 2026 15:05:53 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to multiple error in magic mirror after update from 2.28.0 to 2.36.0 on Fri, 01 May 2026 19:31:21 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> many thanks for your help once again sam!</p>
]]></description><link>https://forum.magicmirror.builders/post/131041</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/131041</guid><dc:creator><![CDATA[1a2a3a]]></dc:creator><pubDate>Fri, 01 May 2026 19:31:21 GMT</pubDate></item><item><title><![CDATA[Reply to multiple error in magic mirror after update from 2.28.0 to 2.36.0 on Fri, 01 May 2026 19:29:40 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/1a2a3a" aria-label="Profile: 1a2a3a">@<bdi>1a2a3a</bdi></a> yes…</p>
<p dir="auto">all should be good now</p>
]]></description><link>https://forum.magicmirror.builders/post/131040</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/131040</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Fri, 01 May 2026 19:29:40 GMT</pubDate></item><item><title><![CDATA[Reply to multiple error in magic mirror after update from 2.28.0 to 2.36.0 on Fri, 01 May 2026 19:28:29 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> it worked! is that your expectation?</p>
]]></description><link>https://forum.magicmirror.builders/post/131039</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/131039</guid><dc:creator><![CDATA[1a2a3a]]></dc:creator><pubDate>Fri, 01 May 2026 19:28:29 GMT</pubDate></item><item><title><![CDATA[Reply to multiple error in magic mirror after update from 2.28.0 to 2.36.0 on Fri, 01 May 2026 21:29:33 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/1a2a3a" aria-label="Profile: 1a2a3a">@<bdi>1a2a3a</bdi></a> yeh, fine, but no wayland info there</p>
<p dir="auto">I see a diff on my <a href="http://mm.sh" target="_blank" rel="noopener noreferrer nofollow ugc">mm.sh</a></p>
<p dir="auto">if wayland_display is not set, then I set it to<br />
WAYLAND_DISPLAY=wayland-0<br />
but your scripts use wayland-1</p>
<p dir="auto">SO, lets  try this</p>
<p dir="auto">edit <a href="http://mm.sh" target="_blank" rel="noopener noreferrer nofollow ugc">mm.sh</a> again<br />
change this line</p>
<pre><code>  if [ $(ps -ef | grep -v grep | grep -i -e xway -e labwc | wc -l) -ne 1 ]; then
<p dir="auto">back to</p>
<pre><code>  if [ $(ps -ef | grep -v grep | grep -i -e xway -e labwc | wc -l) -ne 0 ]; then
<p dir="auto">and change this line</p>
<pre><code>export WAYLAND_DISPLAY=${WAYLAND_DISPLAY:=wayland-0}
<p dir="auto">to</p>
<pre><code>export WAYLAND_DISPLAY=${WAYLAND_DISPLAY:=wayland-1}
<p dir="auto">and save <a href="http://mm.sh" target="_blank" rel="noopener noreferrer nofollow ugc">mm.sh</a></p>
<p dir="auto">then</p>
<pre><code>pm2 stop all
pm2 start MagicMirror
]]></description><link>https://forum.magicmirror.builders/post/131038</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/131038</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Fri, 01 May 2026 21:29:33 GMT</pubDate></item><item><title><![CDATA[Reply to multiple error in magic mirror after update from 2.28.0 to 2.36.0 on Fri, 01 May 2026 19:13:42 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> this safe?</p>
<pre><code>SHELL=/bin/bash
LANGUAGE=en_US.UTF-8
NO_AT_BRIDGE=1
XDG_SESSION_TYPE=tty
MOTD_SHOWN=pam
LANG=en_US.UTF-8
LS_COLORS=rs=0:di=01;34:ln=01;36:mh=00:pi=40;33:so=01;35:do=01;35:bd=40;33;01:cd=40;33;01:or=40;31;01:mi=00:su=37;41:sg=30;43:ca=00:tw=30;42:ow=34;42:st=37;44:ex=01;32:*.tar=01;31:*.tgz=01;31:*.arc=01;31:*.arj=01;31:*.taz=01;31:*.lha=01;31:*.lz4=01;31:*.lzh=01;31:*.lzma=01;31:*.tlz=01;31:*.txz=01;31:*.tzo=01;31:*.t7z=01;31:*.zip=01;31:*.z=01;31:*.dz=01;31:*.gz=01;31:*.lrz=01;31:*.lz=01;31:*.lzo=01;31:*.xz=01;31:*.zst=01;31:*.tzst=01;31:*.bz2=01;31:*.bz=01;31:*.tbz=01;31:*.tbz2=01;31:*.tz=01;31:*.deb=01;31:*.rpm=01;31:*.jar=01;31:*.war=01;31:*.ear=01;31:*.sar=01;31:*.rar=01;31:*.alz=01;31:*.ace=01;31:*.zoo=01;31:*.cpio=01;31:*.7z=01;31:*.rz=01;31:*.cab=01;31:*.wim=01;31:*.swm=01;31:*.dwm=01;31:*.esd=01;31:*.avif=01;35:*.jpg=01;35:*.jpeg=01;35:*.mjpg=01;35:*.mjpeg=01;35:*.gif=01;35:*.bmp=01;35:*.pbm=01;35:*.pgm=01;35:*.ppm=01;35:*.tga=01;35:*.xbm=01;35:*.xpm=01;35:*.tif=01;35:*.tiff=01;35:*.png=01;35:*.svg=01;35:*.svgz=01;35:*.mng=01;35:*.pcx=01;35:*.mov=01;35:*.mpg=01;35:*.mpeg=01;35:*.m2v=01;35:*.mkv=01;35:*.webm=01;35:*.webp=01;35:*.ogm=01;35:*.mp4=01;35:*.m4v=01;35:*.mp4v=01;35:*.vob=01;35:*.qt=01;35:*.nuv=01;35:*.wmv=01;35:*.asf=01;35:*.rm=01;35:*.rmvb=01;35:*.flc=01;35:*.avi=01;35:*.fli=01;35:*.flv=01;35:*.gl=01;35:*.dl=01;35:*.xcf=01;35:*.xwd=01;35:*.yuv=01;35:*.cgm=01;35:*.emf=01;35:*.ogv=01;35:*.ogx=01;35:*.aac=00;36:*.au=00;36:*.flac=00;36:*.m4a=00;36:*.mid=00;36:*.midi=00;36:*.mka=00;36:*.mp3=00;36:*.mpc=00;36:*.ogg=00;36:*.ra=00;36:*.wav=00;36:*.oga=00;36:*.opus=00;36:*.spx=00;36:*.xspf=00;36:*~=00;90:*#=00;90:*.bak=00;90:*.old=00;90:*.orig=00;90:*.part=00;90:*.rej=00;90:*.swp=00;90:*.tmp=00;90:*.dpkg-dist=00;90:*.dpkg-old=00;90:*.ucf-dist=00;90:*.ucf-new=00;90:*.ucf-old=00;90:*.rpmnew=00;90:*.rpmorig=00;90:*.rpmsave=00;90:
XDG_SESSION_CLASS=user
TERM=xterm
SHLVL=1
XDG_SESSION_ID=6
XDG_RUNTIME_DIR=/run/user/1000
LC_ALL=en_US.UTF-8
DBUS_SESSION_BUS_ADDRESS=unix:path=/run/user/1000/bus
SSH_TTY=/dev/pts/0
_=/usr/bin/env
]]></description><link>https://forum.magicmirror.builders/post/131037</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/131037</guid><dc:creator><![CDATA[1a2a3a]]></dc:creator><pubDate>Fri, 01 May 2026 19:13:42 GMT</pubDate></item><item><title><![CDATA[Reply to multiple error in magic mirror after update from 2.28.0 to 2.36.0 on Fri, 01 May 2026 19:10:39 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/1a2a3a" aria-label="Profile: 1a2a3a">@<bdi>1a2a3a</bdi></a> sensitive</p>
<p dir="auto">name, address, zipcode, apikeys, passwords…</p>
]]></description><link>https://forum.magicmirror.builders/post/131036</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/131036</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Fri, 01 May 2026 19:10:39 GMT</pubDate></item><item><title><![CDATA[Reply to multiple error in magic mirror after update from 2.28.0 to 2.36.0 on Fri, 01 May 2026 19:06:44 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> uhm which are the info that are sensitive?</p>
<p dir="auto">so im actually wayland instead of x11?</p>
]]></description><link>https://forum.magicmirror.builders/post/131035</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/131035</guid><dc:creator><![CDATA[1a2a3a]]></dc:creator><pubDate>Fri, 01 May 2026 19:06:44 GMT</pubDate></item><item><title><![CDATA[Reply to multiple error in magic mirror after update from 2.28.0 to 2.36.0 on Fri, 01 May 2026 19:02:52 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/1a2a3a" aria-label="Profile: 1a2a3a">@<bdi>1a2a3a</bdi></a> yeh… weird indeed… those scripts are wayland based…</p>
<p dir="auto">ok, open a new terminal window<br />
and do</p>
<pre><code>env
<p dir="auto">to dump out the environment variables…<br />
check to make sure none expose any info you don’t want shown here and paste the cleaned list</p>
]]></description><link>https://forum.magicmirror.builders/post/131034</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/131034</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Fri, 01 May 2026 19:02:52 GMT</pubDate></item><item><title><![CDATA[Reply to multiple error in magic mirror after update from 2.28.0 to 2.36.0 on Fri, 01 May 2026 18:58:45 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> dont know man, gets even weirder.</p>
<p dir="auto">i cant turn on mm using the terminal on the pi directly.<br />
i tried npm run start:x11 and it will just close off with a /home/hsa/MagicMirror/node_modules/electron/dist/electron exited with signal SIGSEGV</p>
<p dir="auto">i can now only turn on my mm using pm2 on my ssh terminal…</p>
<p dir="auto">btw i have a cron job, not sure if this is causing the issue</p>
<pre><code>crontab -e
38 00 * * * /home/HSA/display_on.sh
37 00 * * * /home/HSA/display_off.sh
<pre><code>display_off.sh
#!/bin/bash
export WAYLAND_DISPLAY=wayland-1
export XDG_RUNTIME_DIR=/run/user/1000
/usr/bin/wlr-randr --output HDMI-A-2 --off
<pre><code>display_on.sh
#!/bin/bash
/usr/bin/wlr-randr --output HDMI-A-2 --on --transform 90
]]></description><link>https://forum.magicmirror.builders/post/131033</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/131033</guid><dc:creator><![CDATA[1a2a3a]]></dc:creator><pubDate>Fri, 01 May 2026 18:58:45 GMT</pubDate></item><item><title><![CDATA[Reply to multiple error in magic mirror after update from 2.28.0 to 2.36.0 on Fri, 01 May 2026 18:55:12 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/1a2a3a" aria-label="Profile: 1a2a3a">@<bdi>1a2a3a</bdi></a> thanks…</p>
]]></description><link>https://forum.magicmirror.builders/post/131032</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/131032</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Fri, 01 May 2026 18:55:12 GMT</pubDate></item><item><title><![CDATA[Reply to multiple error in magic mirror after update from 2.28.0 to 2.36.0 on Fri, 01 May 2026 18:52:39 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a></p>
<pre><code>hsa@HSA:~/MagicMirror $ lsb_release -a
No LSB modules are available.
Distributor ID: Debian
Description:    Debian GNU/Linux 12 (bookworm)
Release:        12
Codename:       bookworm
hsa@HSA:~/MagicMirror $ uname -a
Linux HSA 6.12.75+rpt-rpi-2712 #1 SMP PREEMPT Debian 1:6.12.75-1+rpt1~bookworm (2026-03-11) aarch64 GNU/Linux
]]></description><link>https://forum.magicmirror.builders/post/131031</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/131031</guid><dc:creator><![CDATA[1a2a3a]]></dc:creator><pubDate>Fri, 01 May 2026 18:52:39 GMT</pubDate></item><item><title><![CDATA[Reply to multiple error in magic mirror after update from 2.28.0 to 2.36.0 on Fri, 01 May 2026 18:51:42 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/1a2a3a" aria-label="Profile: 1a2a3a">@<bdi>1a2a3a</bdi></a> yeh,  weird tho</p>
<p dir="auto">can you show me output of</p>
<pre><code>lsb_release -a
uname -a
<p dir="auto">weird it thinks wayland, but won’t run that way</p>
]]></description><link>https://forum.magicmirror.builders/post/131030</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/131030</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Fri, 01 May 2026 18:51:42 GMT</pubDate></item><item><title><![CDATA[Reply to multiple error in magic mirror after update from 2.28.0 to 2.36.0 on Fri, 01 May 2026 18:50:24 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> ok it runs now. what do i do next?</p>
<p dir="auto">edit sorry obviously stupid. just pm2 start and we are GOLD :D</p>
<p dir="auto">thanks again!</p>
]]></description><link>https://forum.magicmirror.builders/post/131029</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/131029</guid><dc:creator><![CDATA[1a2a3a]]></dc:creator><pubDate>Fri, 01 May 2026 18:50:24 GMT</pubDate></item><item><title><![CDATA[Reply to multiple error in magic mirror after update from 2.28.0 to 2.36.0 on Fri, 01 May 2026 18:46:01 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/1a2a3a" aria-label="Profile: 1a2a3a">@<bdi>1a2a3a</bdi></a> ok, it still thinks wayland is active.</p>
<pre><code>nano  installers/mm.sh
<p dir="auto">change line</p>
<p dir="auto">ctrl-o,<br />
enter<br />
ctrl-x</p>
<pre><code>installers/mm.sh
]]></description><link>https://forum.magicmirror.builders/post/131028</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/131028</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Fri, 01 May 2026 18:46:01 GMT</pubDate></item><item><title><![CDATA[Reply to multiple error in magic mirror after update from 2.28.0 to 2.36.0 on Fri, 01 May 2026 18:41:08 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> did not manage to open MM</p>
<pre><code>&gt; magicmirror@2.36.0 start:wayland
&gt; WAYLAND_DISPLAY="${WAYLAND_DISPLAY:=wayland-1}" ./node_modules/.bin/electron js/electron.js --ozone-platform=wayland
[2026-05-02 02:39:50.838] [LOG]   [app] Starting MagicMirror: v2.36.0
[2026-05-02 02:39:50.845] [LOG]   [utils] Loading config ...
[2026-05-02 02:39:51.547] [INFO]  [systeminformation]
####  System Information  ####
- SYSTEM:   manufacturer: Raspberry Pi Foundation; model: Raspberry Pi 5 Model B Rev 1.0; virtual: false; MM: v2.36.0
- OS:       platform: linux; distro: Debian GNU/Linux; release: 12; arch: arm64; kernel: 6.12.75+rpt-rpi-2712
- VERSIONS: electron: 41.3.0; used node: 22.21.1; installed node: 22.21.1; npm: 10.9.4; pm2: 6.0.14
- ENV:      XDG_SESSION_TYPE: tty; MM_CONFIG_FILE: undefined
            WAYLAND_DISPLAY:  wayland-0; DISPLAY: undefined; ELECTRON_ENABLE_GPU: undefined
- RAM:      total: 8059.06 MB; free: 6932.14 MB; used: 1126.92 MB
- OTHERS:   uptime: 65 minutes; timeZone: Asia/Singapore
[2026-05-02 02:40:04.644] [INFO]  [utils] Checking config file /home/hsa/MagicMirror/config/config.js ...
[2026-05-02 02:40:04.720] [INFO]  [utils] Your configuration file doesn't contain syntax errors :)
[2026-05-02 02:40:04.721] [INFO]  [utils] Checking modules structure configuration ...
[2026-05-02 02:40:04.787] [INFO]  [utils] Your modules structure configuration doesn't contain errors :)
[2026-05-02 02:40:04.788] [LOG]   [app] Loading module helpers ...
[2026-05-02 02:40:04.788] [LOG]   [app] No helper found for module: alert.
[2026-05-02 02:40:04.790] [LOG]   [node_helper] Initializing new module helper ...
[2026-05-02 02:40:04.791] [LOG]   [node_helper] Module helper loaded: updatenotification
[2026-05-02 02:40:04.791] [LOG]   [app] No helper found for module: clock.
[2026-05-02 02:40:04.891] [LOG]   [node_helper] Initializing new module helper ...
[2026-05-02 02:40:04.891] [LOG]   [node_helper] Module helper loaded: MMM-Jast
[2026-05-02 02:40:05.554] [LOG]   [node_helper] Initializing new module helper ...
[2026-05-02 02:40:05.555] [LOG]   [node_helper] Module helper loaded: MMM-GoogleDocs-Notes
[2026-05-02 02:40:05.580] [LOG]   [node_helper] Initializing new module helper ...
[2026-05-02 02:40:05.580] [LOG]   [node_helper] Module helper loaded: newsfeed
[2026-05-02 02:40:05.586] [LOG]   [node_helper] Initializing new module helper ...
[2026-05-02 02:40:05.586] [LOG]   [app] Check MagicMirror² version for node helper 'MMM-NewsAPI' - Minimum version: 2.21.0 - Current version: 2.36.0
[2026-05-02 02:40:05.587] [LOG]   [app] Version is ok!
[2026-05-02 02:40:05.587] [LOG]   [node_helper] Module helper loaded: MMM-NewsAPI
[2026-05-02 02:40:05.588] [LOG]   [node_helper] Initializing new module helper ...
[2026-05-02 02:40:05.588] [LOG]   [node_helper] Module helper loaded: MMM-MyScoreboard
[2026-05-02 02:40:05.595] [LOG]   [node_helper] Initializing new module helper ...
[2026-05-02 02:40:05.595] [LOG]   [app] Check MagicMirror² version for node helper 'MMM-SoccerLiveScore' - Minimum version: 2.1.0 - Current version: 2.36.0
[2026-05-02 02:40:05.595] [LOG]   [app] Version is ok!
[2026-05-02 02:40:05.595] [LOG]   [node_helper] Module helper loaded: MMM-SoccerLiveScore
[2026-05-02 02:40:05.688] [LOG]   [node_helper] Initializing new module helper ...
[2026-05-02 02:40:05.688] [LOG]   [node_helper] Module helper loaded: MMM-OneDrive
[2026-05-02 02:40:05.689] [LOG]   [node_helper] Initializing new module helper ...
[2026-05-02 02:40:05.689] [LOG]   [node_helper] Module helper loaded: MMM-CalendarExt3Agenda
[2026-05-02 02:40:05.746] [LOG]   [node_helper] Initializing new module helper ...
[2026-05-02 02:40:05.746] [LOG]   [node_helper] Module helper loaded: calendar
[2026-05-02 02:40:05.747] [LOG]   [node_helper] Initializing new module helper ...
[2026-05-02 02:40:05.747] [LOG]   [node_helper] Module helper loaded: MMM-CalendarExt3
[2026-05-02 02:40:05.747] [LOG]   [app] All module helpers loaded.
[2026-05-02 02:40:05.751] [LOG]   [server] Starting server on port 8080 ...
[2026-05-02 02:40:05.760] [ERROR] [unknown] (node:13239) [DEP0040] DeprecationWarning: The `punycode` module is deprecated. Please use a userland alternative instead.
[13239:0502/024005.762036:ERROR:ui/ozone/platform/wayland/host/wayland_connection.cc:202] Failed to connect to Wayland display: No such file or directory (2)
[13239:0502/024005.762106:ERROR:ui/ozone/platform/wayland/ozone_platform_wayland.cc:281] Failed to initialize Wayland platform
[13239:0502/024005.762122:ERROR:ui/aura/env.cc:246] The platform failed to initialize.  Exiting.
]]></description><link>https://forum.magicmirror.builders/post/131027</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/131027</guid><dc:creator><![CDATA[1a2a3a]]></dc:creator><pubDate>Fri, 01 May 2026 18:41:08 GMT</pubDate></item><item><title><![CDATA[Reply to multiple error in magic mirror after update from 2.28.0 to 2.36.0 on Fri, 01 May 2026 18:38:40 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/1a2a3a" aria-label="Profile: 1a2a3a">@<bdi>1a2a3a</bdi></a></p>
cd ~/MagicMirror
installers/mm.sh
]]></description><link>https://forum.magicmirror.builders/post/131026</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/131026</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Fri, 01 May 2026 18:38:40 GMT</pubDate></item><item><title><![CDATA[Reply to multiple error in magic mirror after update from 2.28.0 to 2.36.0 on Fri, 01 May 2026 18:37:20 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> mm is not up</p>
<pre><code>hsa@HSA:~ $ pm2 status
│ id │ name           │ namespace   │ version │ mode    │ pid      │ uptime │ ↺    │ status    │ cpu      │ mem      │ user     │ watching │
│ 0  │ MagicMirror    │ default     │ 2.36.0  │ fork    │ 12206    │ 15s    │ 49   │ online    │ 0%       │ 2.6mb    │ hsa      │ disabled │
hsa@HSA:~ $
]]></description><link>https://forum.magicmirror.builders/post/131025</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/131025</guid><dc:creator><![CDATA[1a2a3a]]></dc:creator><pubDate>Fri, 01 May 2026 18:37:20 GMT</pubDate></item><item><title><![CDATA[Reply to multiple error in magic mirror after update from 2.28.0 to 2.36.0 on Fri, 01 May 2026 18:36:06 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/1a2a3a" aria-label="Profile: 1a2a3a">@<bdi>1a2a3a</bdi></a> and MM is up or not?</p>
<p dir="auto">pm2 status</p>
<p dir="auto">has the cycle count changed?</p>
]]></description><link>https://forum.magicmirror.builders/post/131024</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/131024</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Fri, 01 May 2026 18:36:06 GMT</pubDate></item><item><title><![CDATA[Reply to multiple error in magic mirror after update from 2.28.0 to 2.36.0 on Fri, 01 May 2026 18:32:17 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a></p>
<p dir="auto">done, but mirror no response or whatsoever</p>
<pre><code>hsa@HSA:~ $ cd ~/MagicMirror/installers
hsa@HSA:~/MagicMirror/installers $ curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/refs/heads/master/mm.sh &gt;mm.sh
hsa@HSA:~/MagicMirror/installers $ pm2 stop all
(node:10682) [DEP0044] DeprecationWarning: The `util.isArray` API is deprecated. Please use `Array.isArray()` instead.
[PM2] Applying action stopProcessId on app [all](ids: [ 0 ])
[PM2] [all](0) ✓
│ id │ name               │ mode     │ ↺    │ status    │ cpu      │ memory   │
│ 0  │ MagicMirror        │ fork     │ 45   │ stopped   │ 0%       │ 0b       │
hsa@HSA:~/MagicMirror/installers $ pm2 start MagicMirror
(node:10691) [DEP0044] DeprecationWarning: The `util.isArray` API is deprecated. Please use `Array.isArray()` instead.
[PM2] Applying action restartProcessId on app [MagicMirror](ids: [ 0 ])
[PM2] [MagicMirror](0) ✓
[PM2] Process successfully started
│ 0  │ MagicMirror        │ fork     │ 45   │ online    │ 0%       │ 2.7mb    │
]]></description><link>https://forum.magicmirror.builders/post/131023</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/131023</guid><dc:creator><![CDATA[1a2a3a]]></dc:creator><pubDate>Fri, 01 May 2026 18:32:17 GMT</pubDate></item><item><title><![CDATA[Reply to multiple error in magic mirror after update from 2.28.0 to 2.36.0 on Fri, 01 May 2026 18:29:51 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/1a2a3a" aria-label="Profile: 1a2a3a">@<bdi>1a2a3a</bdi></a> <a href="/post/131021">said</a>:</p>
<p dir="auto">/home/hsa/MagicMirror/installers/mm.sh</p>
<p dir="auto">weird… do this</p>
<pre><code>cd ~/MagicMirror/installers
<p dir="auto">then do the</p>
]]></description><link>https://forum.magicmirror.builders/post/131022</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/131022</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Fri, 01 May 2026 18:29:51 GMT</pubDate></item><item><title><![CDATA[Reply to multiple error in magic mirror after update from 2.28.0 to 2.36.0 on Fri, 01 May 2026 18:25:58 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a></p>
<p dir="auto">status            │ errored                                   │<br />
│ name              │ MagicMirror                               │<br />
│ namespace         │ default                                   │<br />
│ version           │ 2.36.0                                    │<br />
│ restarts          │ 45                                        │<br />
│ uptime            │ 0                                         │<br />
│ script path       │ /home/hsa/MagicMirror/installers/mm.sh    │<br />
│ script args       │ N/A                                       │<br />
│ error log path    │ /home/hsa/.pm2/logs/MagicMirror-error.log │<br />
│ out log path      │ /home/hsa/.pm2/logs/MagicMirror-out.log   │<br />
│ pid path          │ /home/hsa/.pm2/pids/MagicMirror-0.pid     │<br />
│ interpreter       │ bash                                      │<br />
│ interpreter args  │ N/A                                       │<br />
│ script id         │ 0                                         │<br />
│ exec cwd          │ /home/hsa/MagicMirror                     │<br />
│ exec mode         │ fork_mode                                 │<br />
│ node.js version   │ N/A                                       │<br />
│ node env          │ N/A                                       │<br />
│ watch &amp; reload    │ ✘                                         │<br />
│ unstable restarts │ 0                                         │<br />
│ created at        │ N/A</p>
]]></description><link>https://forum.magicmirror.builders/post/131021</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/131021</guid><dc:creator><![CDATA[1a2a3a]]></dc:creator><pubDate>Fri, 01 May 2026 18:25:58 GMT</pubDate></item><item><title><![CDATA[Reply to multiple error in magic mirror after update from 2.28.0 to 2.36.0 on Fri, 01 May 2026 18:24:48 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/1a2a3a" aria-label="Profile: 1a2a3a">@<bdi>1a2a3a</bdi></a> are you sure this is the script listed in pm2 info output?</p>
]]></description><link>https://forum.magicmirror.builders/post/131020</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/131020</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Fri, 01 May 2026 18:24:48 GMT</pubDate></item><item><title><![CDATA[Reply to multiple error in magic mirror after update from 2.28.0 to 2.36.0 on Fri, 01 May 2026 18:23:58 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> edited to your <a href="http://mm.sh" target="_blank" rel="noopener noreferrer nofollow ugc">mm.sh</a> but same result</p>
<pre><code>hsa@HSA:~/MagicMirror/installers $ cat mm.sh
#!/bin/bash
cd ~/MagicMirror
   # if WAYLAND_DISPLAYis set, use it, else set to -0
   npm run start:wayland
else
   DISPLAY=:0 npm run start:x11
fi
]]></description><link>https://forum.magicmirror.builders/post/131019</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/131019</guid><dc:creator><![CDATA[1a2a3a]]></dc:creator><pubDate>Fri, 01 May 2026 18:23:58 GMT</pubDate></item><item><title><![CDATA[Reply to multiple error in magic mirror after update from 2.28.0 to 2.36.0 on Fri, 01 May 2026 18:19:12 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/1a2a3a" aria-label="Profile: 1a2a3a">@<bdi>1a2a3a</bdi></a> ok, thats not my <a href="http://mm.sh" target="_blank" rel="noopener noreferrer nofollow ugc">mm.sh</a> which you supposedly saved</p>
<p dir="auto">but</p>
<p dir="auto">nano <a href="http://mm.sh" target="_blank" rel="noopener noreferrer nofollow ugc">mm.sh</a></p>
<p dir="auto">remove the blank line 2<br />
and go to the end of new line 2 and if the cursor is not after the last character,  hit backspace,<br />
then ctrl-o to save<br />
and ctrl-x to exit nano</p>
]]></description><link>https://forum.magicmirror.builders/post/131018</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/131018</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Fri, 01 May 2026 18:19:12 GMT</pubDate></item></channel></rss>
