<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[JavaScript error]]></title><description><![CDATA[<p dir="auto">Hi,</p>
<p dir="auto">I’d appreciate help with resolving this issue:</p>
<p dir="auto">Thank you!</p>
<pre><code>A JavaScript error occurred in the main process
Uncaught Exception:
TypeError: styleText is not a function
    at /home/pi/MagicMirror/js/logger.js:40:42
    at Object.&lt;anonymous&gt; (/home/pi/MagicMirror/js/logger.js:114:2)
    at Module._compile (node:internal/modules/cjs/loader:1141:14)
    at Module._extensions..js (node:internal/modules/cjs/loader:1196:10)
    at Module.load (node:internal/modules/cjs/loader:1011:32)
    at Module._load (node:internal/modules/cjs/loader:846:12)
    at f._load (node:electron/js2c/asar_bundle:2:13330)
    at Module.require (node:internal/modules/cjs/loader:1035:19)
    at require (node:internal/modules/cjs/helpers:102:18)
    at Object.&lt;anonymous&gt; (/home/pi/MagicMirror/js/app.js:7:13)
]]></description><link>https://forum.magicmirror.builders/topic/20242/javascript-error</link><generator>RSS for Node</generator><lastBuildDate>Tue, 14 Jul 2026 21:32:54 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/20242.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 11 May 2026 12:18:41 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to JavaScript error on Tue, 12 May 2026 11:02:13 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> got the new card up and running! Went through the scripts as you instructed but came up with a new error. Started the magic mirror in x11 and it works! Thanks again for your help! You’re indispensable!</p>
]]></description><link>https://forum.magicmirror.builders/post/131122</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/131122</guid><dc:creator><![CDATA[Lmagenis]]></dc:creator><pubDate>Tue, 12 May 2026 11:02:13 GMT</pubDate></item><item><title><![CDATA[Reply to JavaScript error on Tue, 12 May 2026 12:07:46 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/lmagenis" aria-label="Profile: Lmagenis">@<bdi>Lmagenis</bdi></a> ok, understood</p>
<p dir="auto">We changed npm start to use the Wayland compositor, instead of x11 because the pi os has that as default now</p>
<p dir="auto">If you used my install script and selected pm2, then my startup script (<a href="http://mm.sh" target="_blank" rel="noopener noreferrer nofollow ugc">mm.sh</a>) detects which compositor is running, and issues the appropriate start command</p>
]]></description><link>https://forum.magicmirror.builders/post/131125</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/131125</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Tue, 12 May 2026 12:07:46 GMT</pubDate></item><item><title><![CDATA[Reply to JavaScript error on Tue, 12 May 2026 11:57:25 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> I backed up the files with your script first in case the sd copy program in the pi failed. I didn’t need the backup, but it’s nice to have in case something goes wrong.</p>
<p dir="auto">when I ran “npm start” it was loading the modules and returned this:</p>
<p dir="auto">(I skipped copying the earliest info about all of the modules)</p>
<p dir="auto">[2026-05-12 07:52:44.151] [LOG]   [node_helper] Connecting socket for: MMM-OpenWeatherForecast<br />
[2026-05-12 07:52:44.152] [LOG]   [MMM-OpenWeatherForecast] ====================== Starting node_helper for module [MMM-OpenWeatherForecast]<br />
[2026-05-12 07:52:44.153] [LOG]   [node_helper] Connecting socket for: newsfeed<br />
[2026-05-12 07:52:44.154] [LOG]   [newsfeed] Starting node helper for: newsfeed<br />
[2026-05-12 07:52:44.155] [LOG]   [app] Sockets connected &amp; modules started …<br />
[10718:0512/075244.158823:ERROR:ui/ozone/platform/wayland/host/wayland_connection.cc:202] Failed to connect to Wayland display: No such file or directory (2)<br />
[10718:0512/075244.159077:ERROR:ui/ozone/platform/wayland/ozone_platform_wayland.cc:281] Failed to initialize Wayland platform<br />
[10718:0512/075244.159133:ERROR:ui/aura/env.cc:246] The platform failed to initialize.  Exiting.<br />
/home/pi/MagicMirror/node_modules/electron/dist/electron exited with signal SIGSEGV</p>
]]></description><link>https://forum.magicmirror.builders/post/131124</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/131124</guid><dc:creator><![CDATA[Lmagenis]]></dc:creator><pubDate>Tue, 12 May 2026 11:57:25 GMT</pubDate></item><item><title><![CDATA[Reply to JavaScript error on Tue, 12 May 2026 11:16:35 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/lmagenis" aria-label="Profile: Lmagenis">@<bdi>Lmagenis</bdi></a> great news!!!</p>
<p dir="auto">Where did you see the error ?</p>
<p dir="auto">How did you install MagicMirror on the new system?</p>
]]></description><link>https://forum.magicmirror.builders/post/131123</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/131123</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Tue, 12 May 2026 11:16:35 GMT</pubDate></item><item><title><![CDATA[Reply to JavaScript error on Tue, 12 May 2026 11:02:13 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> got the new card up and running! Went through the scripts as you instructed but came up with a new error. Started the magic mirror in x11 and it works! Thanks again for your help! You’re indispensable!</p>
]]></description><link>https://forum.magicmirror.builders/post/131122</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/131122</guid><dc:creator><![CDATA[Lmagenis]]></dc:creator><pubDate>Tue, 12 May 2026 11:02:13 GMT</pubDate></item><item><title><![CDATA[Reply to JavaScript error on Mon, 11 May 2026 20:00:51 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/lmagenis" aria-label="Profile: Lmagenis">@<bdi>Lmagenis</bdi></a> yes, maybe there is a bunch of log files you can delete</p>
<p dir="auto">Then you could use my backup/restore scripts<br />
<a href="https://github.com/sdetweil/MagicMirror-backup-restore.git" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/sdetweil/MagicMirror-backup-restore.git</a></p>
<p dir="auto">Which has a perfect use for this<br />
Very small data. Can use GitHub too as the storage place</p>
]]></description><link>https://forum.magicmirror.builders/post/131118</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/131118</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Mon, 11 May 2026 20:00:51 GMT</pubDate></item><item><title><![CDATA[Reply to JavaScript error on Mon, 11 May 2026 19:53:46 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> Thank you! Looks like I have some cloning to do (once I get the new card)</p>
]]></description><link>https://forum.magicmirror.builders/post/131117</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/131117</guid><dc:creator><![CDATA[Lmagenis]]></dc:creator><pubDate>Mon, 11 May 2026 19:53:46 GMT</pubDate></item><item><title><![CDATA[Reply to JavaScript error on Mon, 11 May 2026 19:23:15 GMT]]></title><description><![CDATA[<p dir="auto">The log says your  disk/sd card is full (or failing)</p>
<pre><code>no space left on device
]]></description><link>https://forum.magicmirror.builders/post/131115</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/131115</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Mon, 11 May 2026 19:23:15 GMT</pubDate></item><item><title><![CDATA[Reply to JavaScript error on Mon, 11 May 2026 19:15:44 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/lmagenis" aria-label="Profile: Lmagenis">@<bdi>Lmagenis</bdi></a> can you send me the log , same userid at gmail please</p>
]]></description><link>https://forum.magicmirror.builders/post/131114</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/131114</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Mon, 11 May 2026 19:15:44 GMT</pubDate></item><item><title><![CDATA[Reply to JavaScript error on Mon, 11 May 2026 19:10:28 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/lmagenis" aria-label="Profile: Lmagenis">@<bdi>Lmagenis</bdi></a> did it succeed or fail,</p>
<p dir="auto">Without the log</p>
]]></description><link>https://forum.magicmirror.builders/post/131112</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/131112</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Mon, 11 May 2026 19:10:28 GMT</pubDate></item><item><title><![CDATA[Reply to JavaScript error on Mon, 11 May 2026 19:10:26 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a><br />
The install returned “npm error A complete log of this…”</p>
]]></description><link>https://forum.magicmirror.builders/post/131113</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/131113</guid><dc:creator><![CDATA[Lmagenis]]></dc:creator><pubDate>Mon, 11 May 2026 19:10:26 GMT</pubDate></item><item><title><![CDATA[Reply to JavaScript error on Mon, 11 May 2026 19:06:33 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> I really appreciate your help with this!</p>
<p dir="auto">The log has over 600 lines in it. Is there something specific to look for?</p>
]]></description><link>https://forum.magicmirror.builders/post/131111</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/131111</guid><dc:creator><![CDATA[Lmagenis]]></dc:creator><pubDate>Mon, 11 May 2026 19:06:33 GMT</pubDate></item><item><title><![CDATA[Reply to JavaScript error on Mon, 11 May 2026 18:57:40 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/lmagenis" aria-label="Profile: Lmagenis">@<bdi>Lmagenis</bdi></a> fun times</p>
<p dir="auto">Try</p>
<pre><code>cd ~/MagicMirror
npm install electron@41.3.0
<p dir="auto">please advise results</p>
]]></description><link>https://forum.magicmirror.builders/post/131109</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/131109</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Mon, 11 May 2026 18:57:40 GMT</pubDate></item><item><title><![CDATA[Reply to JavaScript error on Mon, 11 May 2026 18:50:19 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a></p>
<p dir="auto">I’ve always used “npm start”. Tried starting it with both commands.</p>
<p dir="auto">pi@raspberrypi:~/MagicMirror $ Start MagicMirror<br />
-bash: Start: command not found<br />
pi@raspberrypi:~/MagicMirror $ npm start</p>
<p dir="auto">magicmirror@2.36.0 start<br />
node --run start:wayland</p>
<p dir="auto">/bin/sh: 1: ./node_modules/.bin/electron: not found<br />
pi@raspberrypi:~/MagicMirror $</p>
]]></description><link>https://forum.magicmirror.builders/post/131108</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/131108</guid><dc:creator><![CDATA[Lmagenis]]></dc:creator><pubDate>Mon, 11 May 2026 18:50:19 GMT</pubDate></item><item><title><![CDATA[Reply to JavaScript error on Mon, 11 May 2026 18:42:25 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/lmagenis" aria-label="Profile: Lmagenis">@<bdi>Lmagenis</bdi></a> hmm</p>
<p dir="auto">Do<br />
Stop MagicMirror</p>
git checkout package.json
rm package-lock.json
rm -rf  node_modules
npm run install-mm
<p dir="auto">Start MagicMirror</p>
]]></description><link>https://forum.magicmirror.builders/post/131107</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/131107</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Mon, 11 May 2026 18:42:25 GMT</pubDate></item><item><title><![CDATA[Reply to JavaScript error on Mon, 11 May 2026 18:10:45 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a></p>
<p dir="auto">Here’s what it returned:</p>
<p dir="auto">diff --git a/package.json b/package.json<br />
index b2c0eca…878e7cc 100644<br />
— a/package.json<br />
+++ b/package.json<br />
@@ -138,7 +138,7 @@<br />
“vitest”: “^4.1.5”<br />
},<br />
“optionalDependencies”: {</p>
<ul>
<li>
<pre><code>          "electron": "^41.3.0"
</li>
</ul>
<ul>
<li>
<pre><code>          "electron": "^22.3.4"
  "engines": {
          "node": "&gt;=22.21.1 &lt;23 || &gt;=24"
</li>
</ul>
]]></description><link>https://forum.magicmirror.builders/post/131106</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/131106</guid><dc:creator><![CDATA[Lmagenis]]></dc:creator><pubDate>Mon, 11 May 2026 18:10:45 GMT</pubDate></item><item><title><![CDATA[Reply to JavaScript error on Mon, 11 May 2026 14:09:48 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/lmagenis" aria-label="Profile: Lmagenis">@<bdi>Lmagenis</bdi></a> can you do</p>
<pre><code>git diff package.json
<p dir="auto">Looks like you used my installer script at some time</p>
]]></description><link>https://forum.magicmirror.builders/post/131101</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/131101</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Mon, 11 May 2026 14:09:48 GMT</pubDate></item><item><title><![CDATA[Reply to JavaScript error on Mon, 11 May 2026 14:02:35 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a></p>
<p dir="auto">On branch master<br />
Your branch is up to date with ‘origin/master’.</p>
<p dir="auto">Changes not staged for commit:<br />
(use “git add …” to update what will be committed)<br />
(use “git restore …” to discard changes in working directory)<br />
modified:   package-lock.json<br />
modified:   package.json</p>
<p dir="auto">Untracked files:<br />
(use “git add …” to include in what will be committed)<br />
RTSPtoWeb/<br />
icons/<br />
installers/<br />
make_error<br />
old_modules/<br />
<a href="http://run-start.sh" target="_blank" rel="noopener noreferrer nofollow ugc">run-start.sh</a><br />
splashscreen/</p>
<p dir="auto">no changes added to commit (use “git add” and/or “git commit -a”)</p>
]]></description><link>https://forum.magicmirror.builders/post/131100</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/131100</guid><dc:creator><![CDATA[Lmagenis]]></dc:creator><pubDate>Mon, 11 May 2026 14:02:35 GMT</pubDate></item><item><title><![CDATA[Reply to JavaScript error on Mon, 11 May 2026 13:40:13 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/lmagenis" aria-label="Profile: Lmagenis">@<bdi>Lmagenis</bdi></a> ok, sounds like update didn’t complete</p>
<p dir="auto">Do,</p>
git status
<p dir="auto">Report output</p>
]]></description><link>https://forum.magicmirror.builders/post/131097</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/131097</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Mon, 11 May 2026 13:40:13 GMT</pubDate></item><item><title><![CDATA[Reply to JavaScript error on Mon, 11 May 2026 13:35:24 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a></p>
<p dir="auto">I’m not using pm2.<br />
I updated from the main MM site</p>
<p dir="auto">When I run npm run start:x11, I’m getting the same error.</p>
]]></description><link>https://forum.magicmirror.builders/post/131096</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/131096</guid><dc:creator><![CDATA[Lmagenis]]></dc:creator><pubDate>Mon, 11 May 2026 13:35:24 GMT</pubDate></item><item><title><![CDATA[Reply to JavaScript error on Mon, 11 May 2026 13:32:56 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/lmagenis" aria-label="Profile: Lmagenis">@<bdi>Lmagenis</bdi></a> failed to connect to Wayland display</p>
<p dir="auto">Npm start was changed to do Wayland, instead of x11<br />
Documented in the release notes</p>
<p dir="auto">Now need to do</p>
<pre><code>npm run start:x11
<p dir="auto">Are you using pm2 to launch?</p>
<p dir="auto">How did you upgrade MagicMirror?  Manually or my scripted update?</p>
]]></description><link>https://forum.magicmirror.builders/post/131095</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/131095</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Mon, 11 May 2026 13:32:56 GMT</pubDate></item><item><title><![CDATA[Reply to JavaScript error on Mon, 11 May 2026 13:21:30 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a></p>
<p dir="auto">It returned:<br />
App threw an error during load<br />
TypeError: styleText is not a function<br />
at /home/pi/MagicMirror/js/logger.js:40:42<br />
at Object. (/home/pi/MagicMirror/js/logger.js:114:2)<br />
at Module._compile (node:internal/modules/cjs/loader:1141:14)<br />
at Module._extensions…js (node:internal/modules/cjs/loader:1196:10)<br />
at Module.load (node:internal/modules/cjs/loader:1011:32)<br />
at Module._load (node:internal/modules/cjs/loader:846:12)<br />
at f._load (node:electron/js2c/asar_bundle:2:13330)<br />
at Module.require (node:internal/modules/cjs/loader:1035:19)<br />
at require (node:internal/modules/cjs/helpers:102:18)<br />
at Object. (/home/pi/MagicMirror/js/app.js:7:13)<br />
A JavaScript error occurred in the main process<br />
Uncaught Exception:<br />
[405959:0511/092036.982897:ERROR:wayland_connection.cc(224)] Failed to connect to Wayland display: No such file or directory (2)<br />
[405959:0511/092036.983156:ERROR:ozone_platform_wayland.cc(223)] Failed to initialize Wayland platform<br />
[405959:0511/092036.983172:ERROR:env.cc(255)] The platform failed to initialize.  Exiting.<br />
The futex facility returned an unexpected error code.<br />
/home/pi/MagicMirror/node_modules/electron/dist/electron exited with signal SIGABRT</p>
]]></description><link>https://forum.magicmirror.builders/post/131094</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/131094</guid><dc:creator><![CDATA[Lmagenis]]></dc:creator><pubDate>Mon, 11 May 2026 13:21:30 GMT</pubDate></item><item><title><![CDATA[Reply to JavaScript error on Mon, 11 May 2026 13:19:25 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/lmagenis" aria-label="Profile: Lmagenis">@<bdi>Lmagenis</bdi></a> you can now… we have debugged, and it works…</p>
<p dir="auto">ctrl-c to stop server and then do your normal start for MM</p>
]]></description><link>https://forum.magicmirror.builders/post/131093</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/131093</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Mon, 11 May 2026 13:19:25 GMT</pubDate></item><item><title><![CDATA[Reply to JavaScript error on Mon, 11 May 2026 13:15:50 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a></p>
<p dir="auto">Now it’s running perfectly if I’m using the browser.<br />
So, why can’t it run if I use “npm start”?</p>
]]></description><link>https://forum.magicmirror.builders/post/131092</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/131092</guid><dc:creator><![CDATA[Lmagenis]]></dc:creator><pubDate>Mon, 11 May 2026 13:15:50 GMT</pubDate></item><item><title><![CDATA[Reply to JavaScript error on Mon, 11 May 2026 13:04:21 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/lmagenis" aria-label="Profile: Lmagenis">@<bdi>Lmagenis</bdi></a> the MMM-TitanSchoolMealMenu module removed the axios requirement over a year ago</p>
<pre><code>cd ~/MagicMirror/modules/MMM-TitanSchoolMealMenu
git pull
<p dir="auto">if that succeeds, do</p>
<pre><code>npm install
<p dir="auto">then</p>
npm run server
<p dir="auto">if good, then use browser to go to</p>
<pre><code>http://localhost:8080
]]></description><link>https://forum.magicmirror.builders/post/131091</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/131091</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Mon, 11 May 2026 13:04:21 GMT</pubDate></item></channel></rss>
