<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Does MM no longer work on Pi Zero2w?]]></title><description><![CDATA[<p dir="auto">I ran the update script a few days ago after seeing PM2 error messages about the MMM-Jast module requiring Node 22.0.0. I saw posts about issues with node on the Pi 0, but didn’t see a workaround, or at least didn’t understand a workaround.</p>
<p dir="auto">My current branch is Master<br />
I tried “git checkout -b oldbranch tags/v2.30”</p>
<p dir="auto">If Pi Zero2w is no longer viable, would a 3B+ work?</p>
]]></description><link>https://forum.magicmirror.builders/topic/20243/does-mm-no-longer-work-on-pi-zero2w</link><generator>RSS for Node</generator><lastBuildDate>Sun, 12 Jul 2026 03:18:34 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/20243.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 13 May 2026 16:19:36 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Does MM no longer work on Pi Zero2w? on Fri, 15 May 2026 16:10:32 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/wyovino" aria-label="Profile: wyovino">@<bdi>wyovino</bdi></a><br />
I find a very easy setup to be a server on an RPi3 A+ and the client in kiosk mode on an RPi Zero 2W.  This also gives one the option of having multiple clients attached to one server.</p>
<p dir="auto">I’m an (old) engineer and a minimalist so I chose DietPi for my OS. This results in very little lag while easily maintaining them via ssh.</p>
<p dir="auto">Total power consumption at full load is 5.5W (3.2W + 2.3W) versus the 4.6W for the Model 3 B+, but incrementally you get power savings as you add more clients. Cost wise, this is also more effective if you have multiple clients.</p>
<p dir="auto"><strong>On the server side</strong>, I created scripts to install MM and eliminated the need for pm2 in favor of using services, as this save significantly on memory usage (RPi3 A+ only has 512MB of RAM).  DietPi + bare services + dropbear + MM server take up only 194-206MB of RAM.  Swap varies from 0-30MB.</p>
<p dir="auto">I do not have a lot of modules running.  The basic Calendar, Weather, MMM-RAIN-MAP plus a module I create for to capture and display Ring camera snapshots (currently called MMM-RingSnapshot).</p>
<p dir="auto"><strong>On the client side</strong>, I created a script to perform the most basic installation which reduces all display resources to bare X and chromium.  Total is 240-248MB running DietPi + chromium in kiosk mode with no windows manager.  Swap varies from 0-120MB while running.</p>
<p dir="auto">I was thinking of posting the scripts on GitHub, but I’m not certain there is appetite for something that is non-standard for MM.</p>
<p dir="auto">YMMV</p>
]]></description><link>https://forum.magicmirror.builders/post/131149</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/131149</guid><dc:creator><![CDATA[noholdsbard]]></dc:creator><pubDate>Fri, 15 May 2026 16:10:32 GMT</pubDate></item><item><title><![CDATA[Reply to Does MM no longer work on Pi Zero2w? on Thu, 14 May 2026 00:23:17 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/wyovino" aria-label="Profile: wyovino">@<bdi>wyovino</bdi></a> should be no difference, actually the ui side will be better</p>
]]></description><link>https://forum.magicmirror.builders/post/131146</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/131146</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Thu, 14 May 2026 00:23:17 GMT</pubDate></item><item><title><![CDATA[Reply to Does MM no longer work on Pi Zero2w? on Wed, 13 May 2026 22:27:49 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a>  I have a spare Zero2W. Would it make sense to run MM server on that one and have the one on the mirror in brower mode? Do you think that would make a difference in performance?</p>
]]></description><link>https://forum.magicmirror.builders/post/131145</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/131145</guid><dc:creator><![CDATA[wyovino]]></dc:creator><pubDate>Wed, 13 May 2026 22:27:49 GMT</pubDate></item><item><title><![CDATA[Reply to Does MM no longer work on Pi Zero2w? on Wed, 13 May 2026 19:54:07 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/wyovino" aria-label="Profile: wyovino">@<bdi>wyovino</bdi></a> bullseye is 2 releases back…</p>
<p dir="auto">Maybe run MagicMirror server mode on the pi, and launch a browser on the mirror…. Same set w surf w MagicMirror on a different system….</p>
]]></description><link>https://forum.magicmirror.builders/post/131144</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/131144</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Wed, 13 May 2026 19:54:07 GMT</pubDate></item><item><title><![CDATA[Reply to Does MM no longer work on Pi Zero2w? on Wed, 13 May 2026 19:21:04 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a><br />
I’m using a USB drive.  This is so weird. Sometimes it works and sometimes it doesn’t. Right now everything looks good.  Even MMM-Jast is working even though there was a warning that it required Node 20.0.0.  Sometimes when I reboot it locks up at the GUI screen and I can’t connect remotely.</p>
<p dir="auto">I have a spare Pi 4 I could use but I’m reluctant because the mirror is in a tiny bathroom and the sound of the cooling fan in noticeable when placed behind the mirror. I guess I could run it without the fan and monitor the temp.</p>
]]></description><link>https://forum.magicmirror.builders/post/131143</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/131143</guid><dc:creator><![CDATA[wyovino]]></dc:creator><pubDate>Wed, 13 May 2026 19:21:04 GMT</pubDate></item><item><title><![CDATA[Reply to Does MM no longer work on Pi Zero2w? on Wed, 13 May 2026 19:09:22 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/wyovino" aria-label="Profile: wyovino">@<bdi>wyovino</bdi></a> look good on swap</p>
<p dir="auto">Because you will use swap, the speed of the sd card makes a difference.</p>
]]></description><link>https://forum.magicmirror.builders/post/131142</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/131142</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Wed, 13 May 2026 19:09:22 GMT</pubDate></item><item><title><![CDATA[Reply to Does MM no longer work on Pi Zero2w? on Wed, 13 May 2026 19:07:58 GMT]]></title><description><![CDATA[<pre><code>               total        used        free      shared  buff/cache   available
Mem:             426         206          28          52         191         115
Swap:           2047         194        1853
]]></description><link>https://forum.magicmirror.builders/post/131141</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/131141</guid><dc:creator><![CDATA[wyovino]]></dc:creator><pubDate>Wed, 13 May 2026 19:07:58 GMT</pubDate></item><item><title><![CDATA[Reply to Does MM no longer work on Pi Zero2w? on Wed, 13 May 2026 18:09:51 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/wyovino" aria-label="Profile: wyovino">@<bdi>wyovino</bdi></a><br />
do</p>
<pre><code>free -m
<p dir="auto">it will tell you how much of the swap file is in use… the 2W only has 512meg of ram.  the pi3 have 768m or more.</p>
]]></description><link>https://forum.magicmirror.builders/post/131140</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/131140</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Wed, 13 May 2026 18:09:51 GMT</pubDate></item><item><title><![CDATA[Reply to Does MM no longer work on Pi Zero2w? on Wed, 13 May 2026 18:05:06 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a>  I’m running Bullseye (Raspbian 11)</p>
<p dir="auto">I ran the setup browser script and selected Surf.</p>
<p dir="auto">My swapfile size is 2048. Does that need to be increased?</p>
]]></description><link>https://forum.magicmirror.builders/post/131139</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/131139</guid><dc:creator><![CDATA[wyovino]]></dc:creator><pubDate>Wed, 13 May 2026 18:05:06 GMT</pubDate></item><item><title><![CDATA[Reply to Does MM no longer work on Pi Zero2w? on Wed, 13 May 2026 16:38:38 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/wyovino" aria-label="Profile: wyovino">@<bdi>wyovino</bdi></a> 2w is a pi3 in pi 0 form factor and smaller memory</p>
<p dir="auto">What os is on the 2w?<br />
Do</p>
<pre><code>lsb_release -a
<p dir="auto">MagicMirror runs, but you have to increase the swap space<br />
And may have to use one of the add on browsers . Surf looks the best.  (You have to install that separately)</p>
<p dir="auto">See the bottom of readme for the scripts to see what to do</p>
<p dir="auto"><a href="https://github.com/sdetweil/MagicMirror_scripts" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/sdetweil/MagicMirror_scripts</a></p>
<p dir="auto">I think you will run</p>
<p dir="auto">bash -c “$(curl -sL <a href="https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/setup_browser_over_server.sh" target="_blank" rel="noopener noreferrer nofollow ugc">https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/setup_browser_over_server.sh</a>)”</p>
<p dir="auto">Then add the environment variable to whatever script launches MagicMirror (pm2 or …)</p>
]]></description><link>https://forum.magicmirror.builders/post/131135</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/131135</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Wed, 13 May 2026 16:38:38 GMT</pubDate></item></channel></rss>
