<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Upgrade docker from 2.33 to 2.36 failure]]></title><description><![CDATA[<p dir="auto">Trying to upgrade my RPI5 v2.33 to V2.36 and get the following error while doing the “docker compose Pull”:</p>
<pre><code>ron@rpi5:~/magicmirror/run $ docker compose pull
[+] Pulling 16/18
 ✔ init Skipped - Image is already being pulled by magicmirror             0.0s
 ⠏ magicmirror [⣿⣿⣿⣿⣿⣿⣿⣿⣿⣿⣿⣿⣿⣿⣿⣿] 386.2MB / 390.3MB Pulling               23.9s
   ⠏ 76b7b92b680d Extracting         181kB/181kB                          22.9s
   ✔ 0479d40f39a3 Download complete                                        2.4s
   ✔ 2d0f308d8afe Download complete                                        0.4s
   ✔ 06d4fbe68d7c Download complete                                        5.6s
   ✔ 245238857a72 Download complete                                        5.7s
   ✔ 50618a6ac35d Download complete                                        7.2s
   ✔ d0d0bce19890 Download complete                                       10.8s
   ✔ d0326d1e8758 Download complete                                       10.8s
   ✔ 22ef58b941aa Download complete                                       10.8s
   ✔ 3cbe9d4d3f1b Download complete                                       11.1s
   ✔ 8ce16659ba64 Download complete                                       11.1s
   ✔ bd6473435aa5 Download complete                                       11.1s
   ✔ 153a60e41e92 Download complete                                       19.2s
   ✔ 4ac394d170cb Download complete                                       11.3s
   ✔ 7c3a6344e52e Download complete                                       22.9s
   ✔ 4f4fb700ef54 Download complete                                       16.7s
failed to register layer: Error processing tar file(exit status 1): archive/tar: invalid tar header
<p dir="auto">Tried it twice with the same error<br />
system info:<br />
RPI 5, 4GB ram, 128GB SSD, RPI OS Bookworm</p>
]]></description><link>https://forum.magicmirror.builders/topic/20244/upgrade-docker-from-2.33-to-2.36-failure</link><generator>RSS for Node</generator><lastBuildDate>Tue, 14 Jul 2026 22:15:09 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/20244.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 16 May 2026 12:36:20 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Upgrade docker from 2.33 to 2.36 failure on Sun, 17 May 2026 23:09:12 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ronr" aria-label="Profile: RonR">@<bdi>RonR</bdi></a></p>
<p dir="auto">Thanks for the positive feedback. I found it amusing that you thanked Sam first, since he provides most of the support here — something for which, honestly, I often lack the time and patience…</p>
<p dir="auto">The problem itself seemed familiar to me; I just had to track down the corresponding issue.</p>
]]></description><link>https://forum.magicmirror.builders/post/131162</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/131162</guid><dc:creator><![CDATA[karsten13]]></dc:creator><pubDate>Sun, 17 May 2026 23:09:12 GMT</pubDate></item><item><title><![CDATA[Reply to Upgrade docker from 2.33 to 2.36 failure on Sun, 17 May 2026 07:58:59 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/karsten13" aria-label="Profile: karsten13">@<bdi>karsten13</bdi></a> Thank you for the lead on how to fix my update failure.  I had done a brief search on the forum and didn’t find anything.  I had been reluctant to upgrade docker because I had to uninstall it and rebuild it the last time I tried to upgrade.  Now I know it can be done painlessly.</p>
<p dir="auto">Thank you very much for your help.<br />
Ron</p>
]]></description><link>https://forum.magicmirror.builders/post/131159</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/131159</guid><dc:creator><![CDATA[RonR]]></dc:creator><pubDate>Sun, 17 May 2026 07:58:59 GMT</pubDate></item><item><title><![CDATA[Reply to Upgrade docker from 2.33 to 2.36 failure on Sun, 17 May 2026 01:11:46 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ronr" aria-label="Profile: RonR">@<bdi>RonR</bdi></a> wasn’t me. Karsten does the docker container, he replied with the link</p>
]]></description><link>https://forum.magicmirror.builders/post/131158</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/131158</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sun, 17 May 2026 01:11:46 GMT</pubDate></item><item><title><![CDATA[Reply to Upgrade docker from 2.33 to 2.36 failure on Sun, 17 May 2026 00:42:48 GMT]]></title><description><![CDATA[<p dir="auto">Sam thanks for the info on out of date docker.</p>
<p dir="auto">I updated docker from 20.10 to 29.5 and then was able to install MM cleanly and my delay problem has disappeared.  All that fighting because I was unsure about updating docker with out wiping it out first.<br />
It is nice to not have to wait for MM to come up any more.</p>
<p dir="auto">THANK YOU VERY MUCH FOR YOUR HELP.<br />
Ron</p>
]]></description><link>https://forum.magicmirror.builders/post/131157</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/131157</guid><dc:creator><![CDATA[RonR]]></dc:creator><pubDate>Sun, 17 May 2026 00:42:48 GMT</pubDate></item><item><title><![CDATA[Reply to Upgrade docker from 2.33 to 2.36 failure on Sat, 16 May 2026 16:36:27 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ronr" aria-label="Profile: RonR">@<bdi>RonR</bdi></a></p>
<p dir="auto">see <a href="https://gitlab.com/khassel/magicmirror/-/work_items/103" target="_blank" rel="noopener noreferrer nofollow ugc">https://gitlab.com/khassel/magicmirror/-/work_items/103</a></p>
]]></description><link>https://forum.magicmirror.builders/post/131156</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/131156</guid><dc:creator><![CDATA[karsten13]]></dc:creator><pubDate>Sat, 16 May 2026 16:36:27 GMT</pubDate></item><item><title><![CDATA[Reply to Upgrade docker from 2.33 to 2.36 failure on Sat, 16 May 2026 12:41:59 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> Thank you, mind slip again.  I ment to put that in.</p>
]]></description><link>https://forum.magicmirror.builders/post/131153</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/131153</guid><dc:creator><![CDATA[RonR]]></dc:creator><pubDate>Sat, 16 May 2026 12:41:59 GMT</pubDate></item><item><title><![CDATA[Reply to Upgrade docker from 2.33 to 2.36 failure on Sun, 17 May 2026 01:18:28 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ronr" aria-label="Profile: RonR">@<bdi>RonR</bdi></a> I edited the title</p>
<p dir="auto">Correct answer below</p>
]]></description><link>https://forum.magicmirror.builders/post/131152</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/131152</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sun, 17 May 2026 01:18:28 GMT</pubDate></item></channel></rss>
