<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[MMM-Carousel breaks with multiple instances of module by using positional]]></title><description><![CDATA[<p dir="auto">Re: <a href="/topic/16379/mmm-carousel-how-to-configure-a-module-multiple-times-on-the-same-page">MMM-Carousel - how to configure a module multiple times on the SAME page?</a></p>
<p dir="auto">I looked through that thread but it doesn’t quite help with my issue.<br />
I’m using scenes 2 on my calendars to rotate between the various family calendars.</p>
<p dir="auto">In the top_left in trying to display weather info that rotates separately and  aren’t part of the scenes . I’m trying to do that with carousel. It works great with 3 modules all different. The moment I had another instance of weather into the mix the last module no longer shows. I just get a blank area when it should show that module .</p>
<p dir="auto">Any pointers on where to look?</p>
]]></description><link>https://forum.magicmirror.builders/topic/20249/mmm-carousel-breaks-with-multiple-instances-of-module-by-using-positional</link><generator>RSS for Node</generator><lastBuildDate>Sun, 12 Jul 2026 02:20:12 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/20249.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 24 May 2026 17:45:57 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to MMM-Carousel breaks with multiple instances of module by using positional on Sun, 24 May 2026 23:24:37 GMT]]></title><description><![CDATA[<p dir="auto">I got it working. The problem was a misconfiguration in one of the modules (not carousel).</p>
]]></description><link>https://forum.magicmirror.builders/post/131197</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/131197</guid><dc:creator><![CDATA[gonzonia]]></dc:creator><pubDate>Sun, 24 May 2026 23:24:37 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Carousel breaks with multiple instances of module by using positional on Mon, 25 May 2026 00:17:08 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/gonzonia" aria-label="Profile: gonzonia">@<bdi>gonzonia</bdi></a> you didn’t mention scenes before. But it’s just another module</p>
]]></description><link>https://forum.magicmirror.builders/post/131198</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/131198</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Mon, 25 May 2026 00:17:08 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Carousel breaks with multiple instances of module by using positional on Sun, 24 May 2026 23:24:37 GMT]]></title><description><![CDATA[<p dir="auto">I got it working. The problem was a misconfiguration in one of the modules (not carousel).</p>
]]></description><link>https://forum.magicmirror.builders/post/131197</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/131197</guid><dc:creator><![CDATA[gonzonia]]></dc:creator><pubDate>Sun, 24 May 2026 23:24:37 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Carousel breaks with multiple instances of module by using positional on Sun, 24 May 2026 23:13:56 GMT]]></title><description><![CDATA[<p dir="auto">Thanks. I tried Pages, but it seems like it’s an all or nothing situation. Each page has to be set up and it would change all the elements between pages. What I like about Scenes2 is if I don’t have a class from a scene assigned to an element, that element remains unaffected. This is why with a combination of Scenes2 and Carousel I can have multiple areas changing independently  at different times. So I have the “Weather” area rotating between options there that appear all the time, and then the calendars rotating independently. I may be missing something but I don’t think I can do that with Pages.</p>
]]></description><link>https://forum.magicmirror.builders/post/131196</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/131196</guid><dc:creator><![CDATA[gonzonia]]></dc:creator><pubDate>Sun, 24 May 2026 23:13:56 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Carousel breaks with multiple instances of module by using positional on Sun, 24 May 2026 18:41:57 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/gonzonia" aria-label="Profile: gonzonia">@<bdi>gonzonia</bdi></a> see this post<br />
<a href="https://forum.magicmirror.builders/topic/18218/mmm-carousel-two-of-the-same-module">https://forum.magicmirror.builders/topic/18218/mmm-carousel-two-of-the-same-module</a></p>
<p dir="auto">I like MMM-Pages for this</p>
]]></description><link>https://forum.magicmirror.builders/post/131194</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/131194</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sun, 24 May 2026 18:41:57 GMT</pubDate></item></channel></rss>
