<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[New MagicMirrorOS build - mm Container in Restart Loop]]></title><description><![CDATA[<p dir="auto">I’ve just done a clean install of MagicMirrorOS (based on <a class="plugin-mentions-user plugin-mentions-a" href="/user/karsten13" aria-label="Profile: karsten13">@<bdi>karsten13</bdi></a> ’s docker install) - 4 Jul 64 bit build.</p>
<p dir="auto">The mm container just seems to be stuck in a restart loop.</p>
<p dir="auto">Suggestions to troubleshoot?</p>
<pre><code>scottwalsh@calendar:/opt/mm/run $ docker ps
CONTAINER ID   IMAGE                                      COMMAND                  CREATED         STATUS                          PORTS      NAMES
7feb4bcf2b57   karsten13/magicmirror:latest               "/usr/bin/tini -- ./…"   3 minutes ago   Restarting (1) 35 seconds ago              mm
c4ecd7a1a688   ghcr.io/nicholas-fedor/watchtower:latest   "/watchtower --inter…"   3 minutes ago   Up 3 minutes (healthy)          8080/tcp   watchtower
c0d1ee7dcd97   karsten13/labwc:latest                     "/entrypoint.sh"         3 minutes ago   Up 3 minutes (healthy)                     labwc
scottwalsh@calendar:/opt/mm/run $ docker logs mm
/opt/magic_mirror/node_modules/electron/dist/electron: /opt/magic_mirror/node_modules/electron/dist/electron: cannot execute binary file
scottwalsh@calendar:/opt/mm/run $ docker down
docker: unknown command: docker down
Run 'docker --help' for more information
scottwalsh@calendar:/opt/mm/run $ docker compose down
[+] down 5/5
 ✔ Container watchtower   Removed        0.9s
 ✔ Container mmpm         Removed        0.1s
 ✔ Container mm           Removed        0.1s
 ✔ Container labwc        Removed        1.4s
 ✔ Network magicmirror_mm Removed        0.2s
scottwalsh@calendar:/opt/mm/run $ docker compose up -d --force-recreate
[+] up 4/5
 ✔ Network magicmirror_mm Created        0.1s
 ✔ Container watchtower   Started        2.1s
 ✔ Container labwc        Healthy        7.6s
 ⠋ Container mm           Starting        7.1s
 ✔ Container mmpm         Created        0.2s
magicmirror hook exited with status 137
]]></description><link>https://forum.magicmirror.builders/topic/20292/new-magicmirroros-build-mm-container-in-restart-loop</link><generator>RSS for Node</generator><lastBuildDate>Sat, 04 Jul 2026 20:08:31 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/20292.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 04 Jul 2026 06:12:11 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to New MagicMirrorOS build - mm Container in Restart Loop on Sat, 04 Jul 2026 18:11:38 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/scottwalsh" aria-label="Profile: scottwalsh">@<bdi>scottwalsh</bdi></a></p>
<p dir="auto">thank you for bringing this up. And yes, the debian arm images had the amd64 electron version installed …</p>
<p dir="auto">I fixed this meanwhile.</p>
<p dir="auto">If you are happy with the wolfi image you can stay on this tag or use the <code>wolfi-electron</code> tag.</p>
<p dir="auto">You can set the image in the <code>.env</code> file too (without override).</p>
]]></description><link>https://forum.magicmirror.builders/post/131506</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/131506</guid><dc:creator><![CDATA[karsten13]]></dc:creator><pubDate>Sat, 04 Jul 2026 18:11:38 GMT</pubDate></item><item><title><![CDATA[Reply to New MagicMirrorOS build - mm Container in Restart Loop on Sat, 04 Jul 2026 11:48:17 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/scottwalsh" aria-label="Profile: scottwalsh">@<bdi>scottwalsh</bdi></a> did you open an issue on the repo on gitlab?</p>
]]></description><link>https://forum.magicmirror.builders/post/131505</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/131505</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sat, 04 Jul 2026 11:48:17 GMT</pubDate></item><item><title><![CDATA[Reply to New MagicMirrorOS build - mm Container in Restart Loop on Sat, 04 Jul 2026 07:13:29 GMT]]></title><description><![CDATA[<p dir="auto">Looks like it may be related to the packaging, an x86 version of electron…</p>
<pre><code>scottwalsh@calendar:/opt/mm/run $ docker cp mm:/opt/magic_mirror/node_modules/electron/dist/electron /tmp/mm-electron
Successfully copied 218MB (transferred 218MB) to /tmp/mm-electron
scottwalsh@calendar:/opt/mm/run $ readelf -h /tmp/mm-electron | egrep 'Class|Machine|OS/ABI|Entry'
  Class:                             ELF64
  OS/ABI:                            UNIX - System V
  Machine:                           Advanced Micro Devices X86-64
  Entry point address:               0x577b8a0
<p dir="auto">Resolved with adding the following override:</p>
scottwalsh@calendar:/opt/mm/run $ cat compose.override.yaml
services:
  magicmirror:
    image: karsten13/magicmirror:wolfi-electron-v2.37.0
    labels:
      - "com.centurylinklabs.watchtower.enable=false"
]]></description><link>https://forum.magicmirror.builders/post/131503</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/131503</guid><dc:creator><![CDATA[scottwalsh]]></dc:creator><pubDate>Sat, 04 Jul 2026 07:13:29 GMT</pubDate></item></channel></rss>
