<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[MMM-Pinfo Not showing information]]></title><description><![CDATA[<p dir="auto">installed update using Sams update script.<br />
MMM-Pinfo Not showing any information.<br />
Did get pull and npm install<br />
That did nothing.<br />
IDEAS???</p>
]]></description><link>https://forum.magicmirror.builders/topic/20302/mmm-pinfo-not-showing-information</link><generator>RSS for Node</generator><lastBuildDate>Sat, 18 Jul 2026 05:05:02 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/20302.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 17 Jul 2026 00:13:57 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to MMM-Pinfo Not showing information on Sat, 18 Jul 2026 00:28:50 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/plainbroke" aria-label="Profile: plainbroke">@<bdi>plainbroke</bdi></a> I dont know, can you send me the ~/MagicMirror/installers/upgrade.log</p>
<p dir="auto">Or open an issue in the repo and attach it there</p>
]]></description><link>https://forum.magicmirror.builders/post/131576</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/131576</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sat, 18 Jul 2026 00:28:50 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Pinfo Not showing information on Fri, 17 Jul 2026 22:34:33 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a><br />
Do I need to be worried about this when using the update script.?</p>
<pre><code>force: line 1193: 0: Permission denied
<p dir="auto">I forgot to ask last time.</p>
]]></description><link>https://forum.magicmirror.builders/post/131575</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/131575</guid><dc:creator><![CDATA[plainbroke]]></dc:creator><pubDate>Fri, 17 Jul 2026 22:34:33 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Pinfo Not showing information on Fri, 17 Jul 2026 22:23:15 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a><br />
Only issue showing in log is MMM-Globe not able to refresh after about 3 hours.<br />
I will disable it and see if that helps.</p>
]]></description><link>https://forum.magicmirror.builders/post/131574</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/131574</guid><dc:creator><![CDATA[plainbroke]]></dc:creator><pubDate>Fri, 17 Jul 2026 22:23:15 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Pinfo Not showing information on Fri, 17 Jul 2026 02:04:46 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/plainbroke" aria-label="Profile: plainbroke">@<bdi>plainbroke</bdi></a> I’m guessing the library the module uses is now down level from what MagicMirror is using</p>
<p dir="auto">I see you opened an issue., I don’t see any trouble logging in the module.</p>
<p dir="auto">Does anything show up in the pm2 logs?</p>
]]></description><link>https://forum.magicmirror.builders/post/131573</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/131573</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Fri, 17 Jul 2026 02:04:46 GMT</pubDate></item></channel></rss>
