<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[added touch support to MMM-ImagesPhotos]]></title><description><![CDATA[<p dir="auto">Hi,</p>
<p dir="auto">My very old monitor died that I was using for mm. I picked up a new one that supported touch. I’ve been using MMM-ImagesPhotos for quite a while, and wanted to take advantage of my new touch display.  So chatgpt and I hacked an update together.  This allows tapping the screen to pause and swipe left or right to move forward or back through the list of images.</p>
<p dir="auto">This required quite a bit of change and am not sure whether this should be a fork or pull request.  I hoping <a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> could let me know which way to go.</p>
]]></description><link>https://forum.magicmirror.builders/topic/20309/added-touch-support-to-mmm-imagesphotos</link><generator>RSS for Node</generator><lastBuildDate>Sat, 25 Jul 2026 21:43:47 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/20309.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 25 Jul 2026 14:59:22 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to added touch support to MMM-ImagesPhotos on Sat, 25 Jul 2026 17:02:31 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> okay, thanks Sam. I’ve just added some stuff for navigation and made some changes to support that.  Everything should continue to work fine.  So I will create pull request.</p>
]]></description><link>https://forum.magicmirror.builders/post/131595</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/131595</guid><dc:creator><![CDATA[rts58]]></dc:creator><pubDate>Sat, 25 Jul 2026 17:02:31 GMT</pubDate></item><item><title><![CDATA[Reply to added touch support to MMM-ImagesPhotos on Sat, 25 Jul 2026 17:03:53 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/rts58" aria-label="Profile: rts58">@<bdi>rts58</bdi></a> if the resulting support is an add on, old stuff works, new does too, then a pull request to the original source is best</p>
<p dir="auto">If it’s really all new, then you should publish a new module of your own</p>
]]></description><link>https://forum.magicmirror.builders/post/131594</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/131594</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sat, 25 Jul 2026 17:03:53 GMT</pubDate></item></channel></rss>
