<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Calendar dates wrong on all day events]]></title><description><![CDATA[<p dir="auto">I caught hell today because I had our anniversary  date wrong in MM.  I use google calendar to feed the default calendar module and it seems that if I have an all day event scheduled it puts that date as one day prior to the actual event. I verified the date is correct on my calendar and don’t see any reason for it to be incorrect in MM.  I checked another all day event coming up and MM displayed it’s date as one day prior also.</p>
<p dir="auto">I’m running on an RPI 5 with 4GB of memory and a 256GB NVME.  MM is running as a container on docker.  MMversion is 2.34.0.</p>
<p dir="auto">I also have MM ,  2.34.0, running with docker on my laptop 32GB memory and 1TB SSD dual boot with Ubuntu 26.04 and win 11.  The dates are correct on the laptop, running Linux.</p>
<p dir="auto">Is there any thing I can do to correct this since it is running on a default module?</p>
<p dir="auto">TIA, Ron</p>
]]></description><link>https://forum.magicmirror.builders/topic/20328/calendar-dates-wrong-on-all-day-events</link><generator>RSS for Node</generator><lastBuildDate>Tue, 11 Aug 2026 11:40:59 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/20328.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 11 Aug 2026 00:49:37 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Calendar dates wrong on all day events on Tue, 11 Aug 2026 03:07:01 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ronr" aria-label="Profile: RonR">@<bdi>RonR</bdi></a> this sounds like the container timezone on the pi is incorrect</p>
<p dir="auto">See the doc on the docker container project for the correct way to set it.</p>
]]></description><link>https://forum.magicmirror.builders/post/131660</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/131660</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Tue, 11 Aug 2026 03:07:01 GMT</pubDate></item></channel></rss>
