<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[[MMM-NoFade] Withdrawn — use MagicMirror's built-in animationSpeed: 0]]></title><description><![CDATA[<p dir="auto"><strong>Withdrawn.</strong> The MagicMirror maintainer kindly pointed out that this is already covered by the built-in per-module <code>animationSpeed: 0</code> config option — it gives an instant, blink-free content swap for any module that passes it through. Where a module hardcodes its fade duration, the correct fix is in that module (expose <code>animationSpeed</code>), not a separate global module.</p>
<p dir="auto">I’ve corrected that in my own modules and withdrawn MMM-NoFade.</p>
<p dir="auto"><strong>TL;DR:</strong> to stop a module from fading on updates, just set <code>animationSpeed: 0</code> in that module’s config.</p>
]]></description><link>https://forum.magicmirror.builders/topic/20344/mmm-nofade-withdrawn-use-magicmirror-s-built-in-animationspeed-0</link><generator>RSS for Node</generator><lastBuildDate>Fri, 28 Aug 2026 07:33:55 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/20344.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 27 Aug 2026 07:41:44 GMT</pubDate><ttl>60</ttl></channel></rss>
