<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[For your information: the end of 32 bit system support is coming]]></title><description><![CDATA[<p dir="auto">The current version of electron we use is version 43,<br />
This version actually downloads the binary for the matching runtime at startup.</p>
<p dir="auto">Help from others added a script to my scripts package to help cleanup the growing disk consumption</p>
<p dir="auto">Anyhow, version 43 is no longer supported after this year</p>
<p dir="auto">Version 44 does NOT provide support for arm32, armhf systems.<br />
Node 24 also has the same limitation.</p>
<p dir="auto">We will move to electron 44 in the October release.<br />
And will document a workaround: after install or upgrade, manually install electron 43 before running<br />
(I’ll update the install/upgrade scripts to do the hack while it works)</p>
<p dir="auto">We don’t know how long this hack will work.</p>
<p dir="auto">Soooo, for those of you running on 32bit os for smaller memory, pi0-2w or pi3, you need to start making plans</p>
<ol>
<li>Freeze upgrades on that system</li>
<li>Upgrade, possibly the hardware too, to a 64 bit os</li>
</ol>
<p dir="auto">We have added the electron 44 to the next release, aka develop, branch<br />
If you have time or interest you can start reviewing its impacts by installing the develop branch.</p>
<p dir="auto">See my post in troubleshooting about testing changes for how to get the develop branch</p>
]]></description><link>https://forum.magicmirror.builders/topic/20352/for-your-information-the-end-of-32-bit-system-support-is-coming</link><generator>RSS for Node</generator><lastBuildDate>Fri, 04 Sep 2026 06:15:39 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/20352.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 03 Sep 2026 19:35:29 GMT</pubDate><ttl>60</ttl></channel></rss>
