<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[New weather provider: FMI Open Data for the built-in weather module]]></title><description><![CDATA[<p dir="auto">Hi,</p>
<p dir="auto">I have published a new weather provider for the built-in MagicMirror² <code>weather</code> module:</p>
<p dir="auto"><strong>MagicMirror² FMI Weather Provider</strong><br />
<a href="https://github.com/i-xul/magicmirror-weather-fmi-provider" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/i-xul/magicmirror-weather-fmi-provider</a></p>
<p dir="auto">It uses open weather data from the Finnish Meteorological Institute (FMI) and does not require an API key.</p>
<p dir="auto">This is a weather <strong>provider</strong>, not a separate MMM weather module. It uses the built-in MagicMirror² weather module and follows the server-side provider API introduced in MagicMirror² v2.35.0.</p>
<p dir="auto">Currently supported:</p>
<ul>
<li>current weather observations</li>
<li>daily forecasts using FMI HARMONIE data</li>
<li>FMI weather symbols mapped to MagicMirror Weather Icons</li>
<li>automatic day/night icon selection</li>
<li>sunrise and sunset calculation</li>
<li>daily min/max temperatures</li>
<li>daily precipitation totals</li>
<li>shared forecast requests between current and forecast instances</li>
<li>retry handling for temporary FMI request failures</li>
</ul>
<p dir="auto">Tested with:</p>
<ul>
<li>MagicMirror² 2.37.0</li>
<li>Raspberry Pi 4</li>
<li>Debian 11 arm64</li>
<li>Node.js 24.x</li>
</ul>
<p dir="auto">The provider is available as a standalone bundled <code>fmi.js</code>, so installation does not require npm dependencies on the MagicMirror system.</p>
<p dir="auto">A screenshot, installation instructions and configuration examples are available in the README.</p>
<p dir="auto">This is the initial v0.1.0 release. Feedback is welcome.</p>
]]></description><link>https://forum.magicmirror.builders/topic/20365/new-weather-provider-fmi-open-data-for-the-built-in-weather-module</link><generator>RSS for Node</generator><lastBuildDate>Tue, 15 Sep 2026 06:15:20 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/20365.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 14 Sep 2026 20:42:05 GMT</pubDate><ttl>60</ttl></channel></rss>
