<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Some advice on building a frame]]></title><description><![CDATA[<p dir="auto">I previously made a magicmirror (without the mirror) using an LG 24MP88HV with the plastic casing and bezel removed. It left quite a nice panel. I then built a wooden frame around this, using 19mm thick wood, routing out a groove for the panel to sit in. The only issue was that upon delivery, the screen was damaged, so the top corner didn’t display correctly.</p>
<p dir="auto">Since then we’ve had a kitchen makeover, and I saw this as an opportunity to make mkII of the magicmirror. The price for a second hand LG 24MP88HV was waaaaay to much this time, so I ordered a different screen, however, this screen, without the plastic bits, is just the glass, and 4 or 5 layers of different materials that make up the display. With the plastic bits, it has an angled back, and would require a channel about 15mm deep to hide the bottom of the display.</p>
<p dir="auto">I’m keen to either, find a reasonably priced monitor, that stripped down, provides a uniform thickness, or take some suggestions on building a frame that will house the monitor in it’s layered form. For reference the new monitor is a Samsung LS24D400GAUXXU…</p>
]]></description><link>https://forum.magicmirror.builders/topic/20368/some-advice-on-building-a-frame</link><generator>RSS for Node</generator><lastBuildDate>Wed, 23 Sep 2026 22:35:15 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/20368.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 23 Sep 2026 16:03:55 GMT</pubDate><ttl>60</ttl></channel></rss>
