<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Newsfeed Fetcher Error. Authorization Failed.]]></title><description><![CDATA[<p dir="auto">Hello,<br />
Need a help on Newsfeed module as I get Error like this;</p>
<p dir="auto">0|mm       | [2026-09-26 21:42:23.584] [ERROR] [newsfeed] Error: Could not fetch newsfeed:  <a href="https://hidayatullah.com/berita/feed" target="_blank" rel="noopener noreferrer nofollow ugc">https://hidayatullah.com/berita/feed</a> Authentication failed (403). Check your API key. Waiting 30 minutes before retry.</p>
<p dir="auto">Thanks for the help.</p>
]]></description><link>https://forum.magicmirror.builders/topic/20370/newsfeed-fetcher-error.-authorization-failed.</link><generator>RSS for Node</generator><lastBuildDate>Sat, 26 Sep 2026 19:51:12 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/20370.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 26 Sep 2026 15:13:18 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Newsfeed Fetcher Error. Authorization Failed. on Sat, 26 Sep 2026 15:49:58 GMT]]></title><description><![CDATA[<p dir="auto">I don’t see a solution in the default module either, but I’m preparing a PR to improve the error message. The API key thing is a bit misleading.</p>
]]></description><link>https://forum.magicmirror.builders/post/131976</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/131976</guid><dc:creator><![CDATA[KristjanESPERANTO]]></dc:creator><pubDate>Sat, 26 Sep 2026 15:49:58 GMT</pubDate></item><item><title><![CDATA[Reply to Newsfeed Fetcher Error. Authorization Failed. on Sat, 26 Sep 2026 15:42:29 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> Thanks Sam for prompt reply. Understand and appreciate it.</p>
]]></description><link>https://forum.magicmirror.builders/post/131975</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/131975</guid><dc:creator><![CDATA[tjetjep]]></dc:creator><pubDate>Sat, 26 Sep 2026 15:42:29 GMT</pubDate></item><item><title><![CDATA[Reply to Newsfeed Fetcher Error. Authorization Failed. on Sat, 26 Sep 2026 15:33:08 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/tjetjep" aria-label="Profile: tjetjep">@<bdi>tjetjep</bdi></a> because  there are so many credentials and authorization mechanisms, we’ve decided not to try to support them for newsfeed. There are some add on modules that have tried some approaches…</p>
<p dir="auto"><a href="https://github.com/MagicMirrorOrg/MagicMirror/issues/3884" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/MagicMirrorOrg/MagicMirror/issues/3884</a></p>
]]></description><link>https://forum.magicmirror.builders/post/131974</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/131974</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sat, 26 Sep 2026 15:33:08 GMT</pubDate></item></channel></rss>
