<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Updating my MagicMirror using @sdetweil's script.]]></title><description><![CDATA[<p dir="auto">Hello, I can no longer update my MagicMirror using <a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a>’s script; do you know why? I’m getting this message:<br />
"update log will be in /home/pi/MagicMirror/installers/upgrade.log<br />
doing test run = false</p>
<p dir="auto">MagicMirror version 2.28.0 (July 1 2024), will not run on OS level buster, due to system limitations</p>
<p dir="auto">you must upgrade to a newer release of the raspi OS at some point" Could you please help me? Thanks.</p>
]]></description><link>https://forum.magicmirror.builders/topic/20373/updating-my-magicmirror-using-@sdetweil-s-script.</link><generator>RSS for Node</generator><lastBuildDate>Mon, 28 Sep 2026 22:45:35 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/20373.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 28 Sep 2026 14:07:39 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Updating my MagicMirror using @sdetweil's script. on Mon, 28 Sep 2026 21:27:27 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/manu85340" aria-label="Profile: manu85340">@<bdi>manu85340</bdi></a> in the new versions since 2.35, custom.css is in the config folder (all the user config stuff in one folder)</p>
<p dir="auto">runtime should move it if found…<br />
install puts an empty file there<br />
upgrade  moves it too</p>
]]></description><link>https://forum.magicmirror.builders/post/131996</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/131996</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Mon, 28 Sep 2026 21:27:27 GMT</pubDate></item><item><title><![CDATA[Reply to Updating my MagicMirror using @sdetweil's script. on Mon, 28 Sep 2026 21:05:13 GMT]]></title><description><![CDATA[<p dir="auto">Thanks for the reply. I just reinstalled everything using your script, but I’ve run into something strange: my custom CSS file is no longer being recognized, and none of the settings inside it are taking effect. Do you know why?</p>
]]></description><link>https://forum.magicmirror.builders/post/131995</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/131995</guid><dc:creator><![CDATA[manu85340]]></dc:creator><pubDate>Mon, 28 Sep 2026 21:05:13 GMT</pubDate></item><item><title><![CDATA[Reply to Updating my MagicMirror using @sdetweil's script. on Mon, 28 Sep 2026 15:21:45 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/manu85340" aria-label="Profile: manu85340">@<bdi>manu85340</bdi></a> thanks , I just updated the text… good catch.<br />
but it says everything…<br />
running latest releases doesn’t work on buster</p>
<p dir="auto">I recommend using my backup script to save your MM config and list of modules<br />
with the backup command</p>
<p dir="auto">see <a href="https://github.com/sdetweil/MagicMirror-backup-restore" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/sdetweil/MagicMirror-backup-restore</a></p>
<p dir="auto">setup the new sd card, &lt;— do NOT write over your existing card til you have new system running<br />
install MM, make sure it runs,</p>
<p dir="auto">then restore your config and modules<br />
with the restore command</p>
]]></description><link>https://forum.magicmirror.builders/post/131992</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/131992</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Mon, 28 Sep 2026 15:21:45 GMT</pubDate></item></channel></rss>
