<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[No display after upgrading to 2.38]]></title><description><![CDATA[<p dir="auto">on my setup, after upgrading to 2.38, the MM fullscreen display gets minimized to the taskbar right after startup.<br />
after some debugging, it turned out that manual upgrading electron from 44.4.5 .to 44.5.0 fixed the issue.</p>
<p dir="auto">runnning mm on:<br />
Raspberry Pi OS	Debian 12 arm64<br />
Display	Wayland</p>
]]></description><link>https://forum.magicmirror.builders/topic/20378/no-display-after-upgrading-to-2.38</link><generator>RSS for Node</generator><lastBuildDate>Fri, 02 Oct 2026 22:52:06 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/20378.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 01 Oct 2026 21:22:19 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to No display after upgrading to 2.38 on Fri, 02 Oct 2026 22:45:02 GMT]]></title><description><![CDATA[<p dir="auto">I can confirm this issue on my setup as well.</p>
<p dir="auto">I upgraded MagicMirror from 2.37.0 to 2.38.0 on a Raspberry Pi 3 Model B running Raspberry Pi OS Debian 13 (Trixie), 64-bit, with Wayland/labwc.</p>
<p dir="auto">After the upgrade, MagicMirror was running under PM2 and the server on port 8080 was working correctly, but the Electron window remained black / did not display the mirror.<br />
I initially had Electron 44.4.5, and upgrading manually to <strong>44.5.0 did NOT fix the problem</strong> on my system.</p>
<p dir="auto">I then tested Electron 43.7.7, and MagicMirror worked correctly.<br />
Finally, after seeing that the MagicMirror upgrade script had been updated to install <strong>Electron 44.5.1</strong>, I installed 44.5.1 manually:</p>
<p dir="auto"><code>npm install --no-save electron@44.5.1</code></p>
<p dir="auto">With Electron <strong>44.5.1</strong>, MagicMirror immediately started working correctly again under Wayland, with all my modules running normally.<br />
So, at least on my Raspberry Pi 3B, <strong>44.5.0 was not sufficient; Electron 44.5.1 was the version that actually fixed the problem</strong>.</p>
<p dir="auto">Thanks for updating the upgrade script to install 44.5.1 — that was essential in my case.<br />
Hopefully this helps anyone else who finds that upgrading only to 44.5.0 doesn’t solve the issue.</p>
]]></description><link>https://forum.magicmirror.builders/post/132055</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/132055</guid><dc:creator><![CDATA[papinist]]></dc:creator><pubDate>Fri, 02 Oct 2026 22:45:02 GMT</pubDate></item><item><title><![CDATA[Reply to No display after upgrading to 2.38 on Fri, 02 Oct 2026 22:45:02 GMT]]></title><description><![CDATA[<p dir="auto">I can confirm this issue on my setup as well.</p>
]]></description><link>https://forum.magicmirror.builders/post/132056</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/132056</guid><dc:creator><![CDATA[papinist]]></dc:creator><pubDate>Fri, 02 Oct 2026 22:45:02 GMT</pubDate></item><item><title><![CDATA[Reply to No display after upgrading to 2.38 on Fri, 02 Oct 2026 22:45:02 GMT]]></title><description><![CDATA[<p dir="auto">I can confirm this issue on my setup as well.</p>
]]></description><link>https://forum.magicmirror.builders/post/132057</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/132057</guid><dc:creator><![CDATA[papinist]]></dc:creator><pubDate>Fri, 02 Oct 2026 22:45:02 GMT</pubDate></item><item><title><![CDATA[Reply to No display after upgrading to 2.38 on Fri, 02 Oct 2026 22:45:02 GMT]]></title><description><![CDATA[<p dir="auto">I can confirm this issue on my setup as well.</p>
]]></description><link>https://forum.magicmirror.builders/post/132058</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/132058</guid><dc:creator><![CDATA[papinist]]></dc:creator><pubDate>Fri, 02 Oct 2026 22:45:02 GMT</pubDate></item><item><title><![CDATA[Reply to No display after upgrading to 2.38 on Fri, 02 Oct 2026 22:45:02 GMT]]></title><description><![CDATA[<p dir="auto">I can confirm this issue on my setup as well.</p>
]]></description><link>https://forum.magicmirror.builders/post/132059</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/132059</guid><dc:creator><![CDATA[papinist]]></dc:creator><pubDate>Fri, 02 Oct 2026 22:45:02 GMT</pubDate></item><item><title><![CDATA[Reply to No display after upgrading to 2.38 on Fri, 02 Oct 2026 22:45:02 GMT]]></title><description><![CDATA[<p dir="auto">I can confirm this issue on my setup as well.</p>
]]></description><link>https://forum.magicmirror.builders/post/132060</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/132060</guid><dc:creator><![CDATA[papinist]]></dc:creator><pubDate>Fri, 02 Oct 2026 22:45:02 GMT</pubDate></item><item><title><![CDATA[Reply to No display after upgrading to 2.38 on Fri, 02 Oct 2026 20:23:11 GMT]]></title><description><![CDATA[<p dir="auto">I’ve updated my scripts to install an updated electron to fix this problem…<br />
during install or upgrade</p>
]]></description><link>https://forum.magicmirror.builders/post/132051</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/132051</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Fri, 02 Oct 2026 20:23:11 GMT</pubDate></item><item><title><![CDATA[Reply to No display after upgrading to 2.38 on Fri, 02 Oct 2026 11:15:06 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/wimthoelke" aria-label="Profile: wimThoelke">@<bdi>wimThoelke</bdi></a> thanks. Very helpful</p>
]]></description><link>https://forum.magicmirror.builders/post/132047</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/132047</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Fri, 02 Oct 2026 11:15:06 GMT</pubDate></item><item><title><![CDATA[Reply to No display after upgrading to 2.38 on Fri, 02 Oct 2026 06:15:46 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a><br />
manual upgrade of mm by <code>git pull &amp;&amp; node --run install-mm</code> according to<br />
<a href="https://docs.magicmirror.builders/getting-started/upgrade-guide.html" target="_blank" rel="noopener noreferrer nofollow ugc">https://docs.magicmirror.builders/getting-started/upgrade-guide.html</a>.<br />
then update of electron by <code>npm install --save-dev electron@44.5.0</code></p>
]]></description><link>https://forum.magicmirror.builders/post/132046</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/132046</guid><dc:creator><![CDATA[wimThoelke]]></dc:creator><pubDate>Fri, 02 Oct 2026 06:15:46 GMT</pubDate></item><item><title><![CDATA[Reply to No display after upgrading to 2.38 on Thu, 01 Oct 2026 21:38:47 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/wimthoelke" aria-label="Profile: wimThoelke">@<bdi>wimThoelke</bdi></a> thanks for the feedback…</p>
<p dir="auto">how did you upgrade? manual or scripted?</p>
]]></description><link>https://forum.magicmirror.builders/post/132038</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/132038</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Thu, 01 Oct 2026 21:38:47 GMT</pubDate></item></channel></rss>
