<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[problème youtube MMM-ISS-Live]]></title><description><![CDATA[<p dir="auto">Hello everyone. I installed the MMM-ISS-Live module by <a class="plugin-mentions-user plugin-mentions-a" href="/user/kristjanesperanto" aria-label="Profile: kristjanesperanto">@<bdi>kristjanesperanto</bdi></a>, but the video isn’t working; I get the following message in the YouTube window: “Video unavailable; playback on other websites has been disabled by the video owner.”<br />
I added these lines to my <code>config.js</code> file, right before <code>modules: [</code>:</p>
<pre><code></code></pre>
<pre><code class="language-electronOptions:">    webPreferences: {
      webviewTag: true
  electronSwitches: ["enable-unsafe-swiftshader"],
<p dir="auto">I should mention that I don’t have any ad blockers installed.I’ve attached a screenshot.<br />
I’ve had this module installed for several years—initially with <a class="plugin-mentions-user plugin-mentions-a" href="/user/mykle1" aria-label="Profile: mykle1">@<bdi>mykle1</bdi></a> <img src="/assets/uploads/files/1790929435065-capture-ecran-youtube.jpg" alt="Capture ecran youtube.JPG" class="img-markdown  img-fluid" />  version, and later with <a class="plugin-mentions-user plugin-mentions-a" href="/user/kristjanesperanto" aria-label="Profile: kristjanesperanto">@<bdi>kristjanesperanto</bdi></a> .<br />
It stopped working due to YouTube’s restrictions, but I saw that <a class="plugin-mentions-user plugin-mentions-a" href="/user/kristjanesperanto" aria-label="Profile: kristjanesperanto">@<bdi>kristjanesperanto</bdi></a> has brought it back to life. Could you help me get MMM-ISS-Live working? Thanks for your help.</p>
]]></description><link>https://forum.magicmirror.builders/topic/20379/problème-youtube-mmm-iss-live</link><generator>RSS for Node</generator><lastBuildDate>Fri, 02 Oct 2026 22:52:31 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/20379.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 02 Oct 2026 08:25:44 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to problème youtube MMM-ISS-Live on Fri, 02 Oct 2026 19:16:43 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/manu85340" aria-label="Profile: manu85340">@<bdi>manu85340</bdi></a> Hi, that message comes from YouTube itself, so your Electron settings are probably fine. Please make sure no DNS filter (e.g. Pi-hole or AdGuard Home) is active, since the video only plays for me once Pi-hole is switched off. Then try this config:</p>
<pre><code class="language-js">{
  module: "MMM-ISS-Live",
    url: "https://youtu.be/fO9e9jnhYK8"
<p dir="auto">If you use a different <code>url</code> at the moment, it may be a stream whose owner disabled embedding. Does the video play with this one?</p>
]]></description><link>https://forum.magicmirror.builders/post/132050</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/132050</guid><dc:creator><![CDATA[KristjanESPERANTO]]></dc:creator><pubDate>Fri, 02 Oct 2026 19:16:43 GMT</pubDate></item></channel></rss>
