<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[5 extra points for the WAF :)]]></title><description><![CDATA[<p dir="auto">Hi,</p>
<p dir="auto">I want to share with you my first MM build !</p>
<p dir="auto">It is based on a 22" monitor (not IPS unfortunately) and a photo frame.</p>
<p dir="auto">Currently, I have put a mirror protective film on the glass but … this is not perfect, I can see the some traces of glue when the monitor is running.<br />
I will move to an acrylic mirror (<a href="http://www.signmaterialsdirect.com/3mm-plaskolite-silver-mirror-acrylic-sheet-3mmsilvermea" target="_blank" rel="noopener noreferrer nofollow ugc">http://www.signmaterialsdirect.com/3mm-plaskolite-silver-mirror-acrylic-sheet-3mmsilvermea</a>)</p>
<p dir="auto">Here is the result:</p>
<p dir="auto"><img src="/assets/uploads/files/1489409070311-img_0493.jpeg" alt="0_1489409063815_IMG_0493.JPG" class=" img-fluid img-markdown" /></p>
<p dir="auto"><img src="/assets/uploads/files/1489409076936-img_0492.jpeg" alt="0_1489409071004_IMG_0492.JPG" class=" img-fluid img-markdown" /></p>
<p dir="auto"><img src="/assets/uploads/files/1489409087896-img_1168.jpeg" alt="0_1489409079585_IMG_1168.JPG" class=" img-fluid img-markdown" /></p>
<p dir="auto"><img src="/assets/uploads/files/1489409103102-img_1169.jpeg" alt="0_1489409089556_IMG_1169.JPG" class=" img-fluid img-markdown" /></p>
<p dir="auto">Thanks all for the information found here !</p>
]]></description><link>https://forum.magicmirror.builders/topic/2059/5-extra-points-for-the-waf</link><generator>RSS for Node</generator><lastBuildDate>Wed, 17 Jun 2026 04:36:29 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/2059.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 13 Mar 2017 12:47:58 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to 5 extra points for the WAF :) on Sun, 07 Jan 2018 10:35:59 GMT]]></title><description><![CDATA[<p dir="auto">Hi,<br />
can you explain a noob a little bit more in detail how to implement the Dakboard calandar into the MM?</p>
<p dir="auto">I really like your setup,</p>
<p dir="auto">Regards, Chris</p>
]]></description><link>https://forum.magicmirror.builders/post/33493</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/33493</guid><dc:creator><![CDATA[chris1971]]></dc:creator><pubDate>Sun, 07 Jan 2018 10:35:59 GMT</pubDate></item><item><title><![CDATA[Reply to 5 extra points for the WAF :) on Tue, 14 Mar 2017 09:04:28 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/d3r" aria-label="Profile: d3r">@<bdi>d3r</bdi></a> this is the only way I found to have this kind of view !</p>
]]></description><link>https://forum.magicmirror.builders/post/17362</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/17362</guid><dc:creator><![CDATA[dementia]]></dc:creator><pubDate>Tue, 14 Mar 2017 09:04:28 GMT</pubDate></item><item><title><![CDATA[Reply to 5 extra points for the WAF :) on Mon, 13 Mar 2017 22:24:12 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/dementia" aria-label="Profile: dementia">@<bdi>dementia</bdi></a> Looks good.<br />
I like that monthly iframe calendar. I’ll check that website to see if I can get a weekly iframe calendar.</p>
]]></description><link>https://forum.magicmirror.builders/post/17331</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/17331</guid><dc:creator><![CDATA[d3r]]></dc:creator><pubDate>Mon, 13 Mar 2017 22:24:12 GMT</pubDate></item><item><title><![CDATA[Reply to 5 extra points for the WAF :) on Mon, 13 Mar 2017 13:09:27 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/dementia" aria-label="Profile: dementia">@<bdi>dementia</bdi></a> said in <a href="/post/17275">5 extra points for the WAF :)</a>:</p>
<p dir="auto">Looks good! :thumbsup_tone2:</p>
]]></description><link>https://forum.magicmirror.builders/post/17277</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/17277</guid><dc:creator><![CDATA[Mykle1]]></dc:creator><pubDate>Mon, 13 Mar 2017 13:09:27 GMT</pubDate></item><item><title><![CDATA[Reply to 5 extra points for the WAF :) on Mon, 13 Mar 2017 12:55:57 GMT]]></title><description><![CDATA[<p dir="auto">Modules installed:</p>
<ul>
<li>trafic information from home to work</li>
<li>RSS feed</li>
<li>new email notification</li>
<li>calendar</li>
<li>weather</li>
</ul>
<p dir="auto">The monthly calendar view comes from an iFrame and <a href="http://dakboard.com" target="_blank" rel="noopener noreferrer nofollow ugc">dakboard.com</a></p>
<p dir="auto">For that I have had to start MagicMirror in server mode and open the url through Chromium cause dakboard needs to be loged on …</p>
]]></description><link>https://forum.magicmirror.builders/post/17276</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/17276</guid><dc:creator><![CDATA[dementia]]></dc:creator><pubDate>Mon, 13 Mar 2017 12:55:57 GMT</pubDate></item></channel></rss>
