<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Weatherunderground - currently - hourly - daily - configurable]]></title><description><![CDATA[<p dir="auto">Do I install this as a separate module?  When I add it to my config.js file my  MM does not start.  I have a valid API key.</p>
]]></description><link>https://forum.magicmirror.builders/topic/206/weatherunderground-currently-hourly-daily-configurable</link><generator>RSS for Node</generator><lastBuildDate>Fri, 07 Aug 2026 10:52:02 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/206.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 21 May 2016 14:06:25 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Weatherunderground - currently - hourly - daily - configurable on Sat, 08 Apr 2017 10:58:19 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/yo-less" aria-label="Profile: yo-less">@<bdi>yo-less</bdi></a></p>
<p dir="auto">i would like also got youre configuration.</p>
]]></description><link>https://forum.magicmirror.builders/post/19244</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/19244</guid><dc:creator><![CDATA[christophehlert]]></dc:creator><pubDate>Sat, 08 Apr 2017 10:58:19 GMT</pubDate></item><item><title><![CDATA[Reply to Weatherunderground - currently - hourly - daily - configurable on Sun, 19 Feb 2017 22:23:36 GMT]]></title><description><![CDATA[<p dir="auto">I am having a error. It just says loading. I did a npm start dev. I get a error that says: Failed to decode downloaded font: <a href="http://localhost:8080/vendor/weather-icons/font/weathericons-regular-webfont.woff2" target="_blank" rel="noopener noreferrer nofollow ugc">http://localhost:8080/vendor/weather-icons/font/weathericons-regular-webfont.woff2</a></p>
]]></description><link>https://forum.magicmirror.builders/post/15055</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/15055</guid><dc:creator><![CDATA[bocapie]]></dc:creator><pubDate>Sun, 19 Feb 2017 22:23:36 GMT</pubDate></item><item><title><![CDATA[Reply to Weatherunderground - currently - hourly - daily - configurable on Thu, 02 Feb 2017 07:33:53 GMT]]></title><description><![CDATA[<p dir="auto">Hi all,</p>
<p dir="auto">has anyone ideas to Change the iconsize of the current weather? It’s to big and to bold for me.</p>
<p dir="auto">Thx, Daniel</p>
]]></description><link>https://forum.magicmirror.builders/post/13324</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/13324</guid><dc:creator><![CDATA[ostfilinchen]]></dc:creator><pubDate>Thu, 02 Feb 2017 07:33:53 GMT</pubDate></item><item><title><![CDATA[Reply to Weatherunderground - currently - hourly - daily - configurable on Sun, 29 Jan 2017 14:34:34 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/rednax" aria-label="Profile: RedNax">@<bdi>RedNax</bdi></a>: it’s still not fine:<img src="/uploads/files/1485700265258-upload-26f37467-942f-462d-af4a-c3a3e1bca669.png" alt="0_1485700269786_upload-26f37467-942f-462d-af4a-c3a3e1bca669" class=" img-fluid img-markdown" /></p>
<p dir="auto">Font is not the same as the other modules and there is not a space between winddirection and humidity-icon</p>
<p dir="auto">And another issue is the size of the current weather Icon. It’s too big:<br />
<img src="/uploads/files/1485700403196-upload-4cec9558-640a-4d7b-9621-35093b3c4d22.png" alt="0_1485700407613_upload-4cec9558-640a-4d7b-9621-35093b3c4d22" class=" img-fluid img-markdown" /></p>
<p dir="auto">Can u have a look of this?</p>
]]></description><link>https://forum.magicmirror.builders/post/12898</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/12898</guid><dc:creator><![CDATA[ostfilinchen]]></dc:creator><pubDate>Sun, 29 Jan 2017 14:34:34 GMT</pubDate></item><item><title><![CDATA[Reply to Weatherunderground - currently - hourly - daily - configurable on Sun, 29 Jan 2017 13:04:57 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/rednax" aria-label="Profile: RedNax">@<bdi>RedNax</bdi></a> : you have update the Module and it doesn’t look like the old style. The humidity is permanent shown and between Icon Wind Direction and Humidity is no space. Also between humidity and sunset/sunrise is no space.</p>
<p dir="auto">Can u please change this?</p>
]]></description><link>https://forum.magicmirror.builders/post/12889</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/12889</guid><dc:creator><![CDATA[ostfilinchen]]></dc:creator><pubDate>Sun, 29 Jan 2017 13:04:57 GMT</pubDate></item><item><title><![CDATA[Reply to Weatherunderground - currently - hourly - daily - configurable on Thu, 19 Jan 2017 20:28:23 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/lsfourwheeler" aria-label="Profile: lsfourwheeler">@<bdi>lsfourwheeler</bdi></a><br />
Indeed, I missed that step. It works now. :) Thank you very much!</p>
]]></description><link>https://forum.magicmirror.builders/post/11686</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/11686</guid><dc:creator><![CDATA[eppzenberg]]></dc:creator><pubDate>Thu, 19 Jan 2017 20:28:23 GMT</pubDate></item><item><title><![CDATA[Reply to Weatherunderground - currently - hourly - daily - configurable on Thu, 19 Jan 2017 02:44:46 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/eppzenberg" aria-label="Profile: eppzenberg">@<bdi>eppzenberg</bdi></a><br />
Yes, I found out this issue actually happened because of the MagicMirror Update. Make sure that after you run the “git pull” command you also run the “npm install” command. This fixed my issue. I hope that helps.</p>
]]></description><link>https://forum.magicmirror.builders/post/11596</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/11596</guid><dc:creator><![CDATA[lsfourwheeler]]></dc:creator><pubDate>Thu, 19 Jan 2017 02:44:46 GMT</pubDate></item><item><title><![CDATA[Reply to Weatherunderground - currently - hourly - daily - configurable on Wed, 18 Jan 2017 20:00:21 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/lsfourwheeler" aria-label="Profile: lsfourwheeler">@<bdi>lsfourwheeler</bdi></a><br />
I’m facing the same problem. Module is working and up-to-date, but moon phase icon is just showing the “image missing” box. Did you find any solution?</p>
]]></description><link>https://forum.magicmirror.builders/post/11579</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/11579</guid><dc:creator><![CDATA[eppzenberg]]></dc:creator><pubDate>Wed, 18 Jan 2017 20:00:21 GMT</pubDate></item><item><title><![CDATA[Reply to Weatherunderground - currently - hourly - daily - configurable on Sun, 18 Dec 2016 18:05:14 GMT]]></title><description><![CDATA[<p dir="auto">So I just updated both my Raspberry pi, MagicMirror software, and MMM-Wunderground. The module still works but the moon phases icon is now a blank “image missing” box. Strangely, I can see the moon image just fine on a computer by going to the MagicmirroIP:8080 and viewing the magicmirror sofware from there. Any suggestions?</p>
]]></description><link>https://forum.magicmirror.builders/post/9530</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/9530</guid><dc:creator><![CDATA[lsfourwheeler]]></dc:creator><pubDate>Sun, 18 Dec 2016 18:05:14 GMT</pubDate></item><item><title><![CDATA[Reply to Weatherunderground - currently - hourly - daily - configurable on Sat, 17 Dec 2016 18:38:38 GMT]]></title><description><![CDATA[<p dir="auto">Honestly not too sure what I did… I mean I just re-cloned things in the module folder and now things are working. …So I guess if someone is having problems, simply start over from the beginning and try again?? No…idea… Anyways thanks for your help!</p>
]]></description><link>https://forum.magicmirror.builders/post/9487</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/9487</guid><dc:creator><![CDATA[Crispis]]></dc:creator><pubDate>Sat, 17 Dec 2016 18:38:38 GMT</pubDate></item><item><title><![CDATA[Reply to Weatherunderground - currently - hourly - daily - configurable on Sat, 17 Dec 2016 18:29:46 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/shockwave" aria-label="Profile: Shockwave">@<bdi>Shockwave</bdi></a> Copied yours exactly and I’m still gettin’ that black screen of death! I’m editing on the pi/mirror itself with the terminal+keyboard. Tried CO/Denver and NY/New_York… nothing. I’m not too sure… I’ll try to “reinstall everything” from step one and see if that fixes it.</p>
]]></description><link>https://forum.magicmirror.builders/post/9485</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/9485</guid><dc:creator><![CDATA[Crispis]]></dc:creator><pubDate>Sat, 17 Dec 2016 18:29:46 GMT</pubDate></item><item><title><![CDATA[Reply to Weatherunderground - currently - hourly - daily - configurable on Sat, 17 Dec 2016 18:07:06 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/crispis" aria-label="Profile: Crispis">@<bdi>Crispis</bdi></a>  Thanks for posting it.  I think you’re missing a comma after appid in the weatherforecast and currentweather modules.  Being at the end that may not be it, I seem to have instances where they aren’t on the last line either.</p>
<p dir="auto">You said it works without the Wunderground module, correct?  Could it be setting the language to Dutch without having Dutch selected in the International Settings within raspi-config?  It sure looks okay unless there’s a hidden symbol in there.  How are you editing it on the mirror?</p>
<p dir="auto">Here’s mine if you want to try.</p>
<pre><code>	{
		module: 'MMM-WunderGround',
		position: 'top_right',
		header: 'Ankeny Weather',
			apikey: 'api key here',
			pws: 'KIKV',
			hourly: '0',
			fcdaycount: '7',
			fade: 'false',
			fadePoint: '1',
			alerttime: 10000,
			UseCardinals: 1,
			roundTmpDecs: 1,
]]></description><link>https://forum.magicmirror.builders/post/9484</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/9484</guid><dc:creator><![CDATA[Shockwave]]></dc:creator><pubDate>Sat, 17 Dec 2016 18:07:06 GMT</pubDate></item><item><title><![CDATA[Reply to Weatherunderground - currently - hourly - daily - configurable on Sat, 17 Dec 2016 17:36:14 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/shockwave" aria-label="Profile: Shockwave">@<bdi>Shockwave</bdi></a> Here is my current full config.js -minus the API keys. Gives me the black screen for some reason…</p>
<p dir="auto">/* Magic Mirror Config Sample<br />
*</p>
<ul>
<li>By Michael Teeuw <a href="http://michaelteeuw.nl" target="_blank" rel="noopener noreferrer nofollow ugc">http://michaelteeuw.nl</a></li>
<li>MIT Licensed.<br />
*/</li>
</ul>
<p dir="auto">var config = {<br />
port: 8080,</p>
<pre><code>language: 'en',
timeFormat: 12,
units: 'imperial',
		module: 'alert',
		module: 'clock',
		position: 'top_left'
		module: 'calendar',
		header: 'US Holidays',
		position: 'top_left',
			maximumEntries: '3',
					symbol: 'calendar-check-o ',
					url: 'webcal://www.calendarlabs.com/templates/ical/US-Holidays.ics'
		module: 'compliments',
		position: 'bottom_bar',
			updateInterval: '1800000',
			compliments: {
				morning: [
					'What a beautiful morning!',
					'Enjoy your day!',
					'Good Morning!',
					'How was your sleep?'
				afternoon: [
					'Hey good lookin!',
					'Looking good today!',
					'You\'re doing great!',
					'Looking good!'
				evening: [
					'Wow, you look great!',
					'You look nice!'
		module: 'currentweather',
		header: 'Firestone, CO',
			initialLoadDelay: '100',
			locationID: '5577008',
			appid: '###'
		module: 'weatherforecast',
		header: 'Weather Forecast',
			locationID: '',  //ID from http://www.openweathermap.org
            		appid: '###'
		header: 'WEATHER TIME',
			apikey: '###',
			pws: 'KDEN',
			lang: 'NL',
			fctext: '1',
			fcdaycount: '5',
		fcdaystart: '0',
		hourly: '1',
		hourlyinterval: '3',
			hourlycount: '2',
<p dir="auto">};</p>
<p dir="auto">/*************** DO NOT EDIT THE LINE BELOW ***************/<br />
if (typeof module !== ‘undefined’) {module.exports = config;}</p>
]]></description><link>https://forum.magicmirror.builders/post/9482</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/9482</guid><dc:creator><![CDATA[Crispis]]></dc:creator><pubDate>Sat, 17 Dec 2016 17:36:14 GMT</pubDate></item><item><title><![CDATA[Reply to Weatherunderground - currently - hourly - daily - configurable on Fri, 16 Dec 2016 23:58:13 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/shockwave" aria-label="Profile: shockwave">@<bdi>shockwave</bdi></a> When it comes to saving the file, I open up a file and type in the ip address then /config/config.js  …I’m not too sure what Putty is… Turning off word wrap just makes the data appear on two lines but for 100 yards. It doesn’t clean things up. Have not tried the KDEN but I’ll give it a go when I’m home!</p>
]]></description><link>https://forum.magicmirror.builders/post/9468</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/9468</guid><dc:creator><![CDATA[Crispis]]></dc:creator><pubDate>Fri, 16 Dec 2016 23:58:13 GMT</pubDate></item><item><title><![CDATA[Reply to Weatherunderground - currently - hourly - daily - configurable on Fri, 16 Dec 2016 23:54:37 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/crispis" aria-label="Profile: Crispis">@<bdi>Crispis</bdi></a><br />
CO/Denver should be okay as that’s the same format I’m using for one of my entries which is AZ/Yuma.  You could also try an airport identifier such as KDEN for Denver International.</p>
<p dir="auto">As for saving the file, I assume you’re copying and pasting from Putty?  Does turning off word wrap make it any better?  Could you copy from putty and paste it in here as a code block?</p>
]]></description><link>https://forum.magicmirror.builders/post/9467</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/9467</guid><dc:creator><![CDATA[Shockwave]]></dc:creator><pubDate>Fri, 16 Dec 2016 23:54:37 GMT</pubDate></item><item><title><![CDATA[Reply to Weatherunderground - currently - hourly - daily - configurable on Fri, 16 Dec 2016 14:56:26 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/chrisfoerg" aria-label="Profile: chrisfoerg">@<bdi>chrisfoerg</bdi></a> I am not sure if CO/Denver is correct. I thought it was the “STATE/CITY” and Denver happens to be very close to me so I went with that initially. It wasn’t working with the “IUTRETCH” or “NY/New_York” inputs either.</p>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/shockwave" aria-label="Profile: Shockwave">@<bdi>Shockwave</bdi></a> I already began to…start…I tried to call up the file through <a href="http://192.XXX/config/config.js" target="_blank" rel="noopener noreferrer nofollow ugc">192.XXX/config/config.js</a> but that gives me a file to save, which then I can’t open as it continues to prompt the save file. When I drop it into notepad, its…word wrap made it too difficult to read and the line was not gonna happen. I’ve got… the entire config.js that I guess I could e-mail? I don’t think attaching it to this would be a good move? Better yet…what is the correct method for acquiring/posting the full config.js?</p>
]]></description><link>https://forum.magicmirror.builders/post/9442</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/9442</guid><dc:creator><![CDATA[Crispis]]></dc:creator><pubDate>Fri, 16 Dec 2016 14:56:26 GMT</pubDate></item><item><title><![CDATA[Reply to Weatherunderground - currently - hourly - daily - configurable on Fri, 16 Dec 2016 08:59:52 GMT]]></title><description><![CDATA[<p dir="auto">Are you sure that CO/Denver is correct?</p>
]]></description><link>https://forum.magicmirror.builders/post/9428</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/9428</guid><dc:creator><![CDATA[chrisfoerg]]></dc:creator><pubDate>Fri, 16 Dec 2016 08:59:52 GMT</pubDate></item><item><title><![CDATA[Reply to Weatherunderground - currently - hourly - daily - configurable on Fri, 16 Dec 2016 05:30:27 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/crispis" aria-label="Profile: Crispis">@<bdi>Crispis</bdi></a> Can you post your full config.js please? (if the above is just truncated)  I’m wondering if there’s something just before the MMM-Wunderground module that’s causing you grief.</p>
]]></description><link>https://forum.magicmirror.builders/post/9423</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/9423</guid><dc:creator><![CDATA[Shockwave]]></dc:creator><pubDate>Fri, 16 Dec 2016 05:30:27 GMT</pubDate></item><item><title><![CDATA[Reply to Weatherunderground - currently - hourly - daily - configurable on Fri, 16 Dec 2016 03:40:32 GMT]]></title><description><![CDATA[<p dir="auto">Did an update with:<br />
cd ~\MagicMirror<br />
git pull<br />
and then removed the “,” … still getting the black screen.</p>
<p dir="auto">When I remove THIS particular module from my whole set, the mirror works fine. I’m not sure whats wrong in that section.</p>
]]></description><link>https://forum.magicmirror.builders/post/9421</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/9421</guid><dc:creator><![CDATA[Crispis]]></dc:creator><pubDate>Fri, 16 Dec 2016 03:40:32 GMT</pubDate></item><item><title><![CDATA[Reply to Weatherunderground - currently - hourly - daily - configurable on Fri, 16 Dec 2016 03:32:49 GMT]]></title><description><![CDATA[<p dir="auto">Everything seems correct in your config. What worked for me was updating the Magic Mirror itself and then it started working. If that doesn’t do it let me know and I could try to see what else I did.</p>
]]></description><link>https://forum.magicmirror.builders/post/9420</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/9420</guid><dc:creator><![CDATA[bthuilot]]></dc:creator><pubDate>Fri, 16 Dec 2016 03:32:49 GMT</pubDate></item><item><title><![CDATA[Reply to Weatherunderground - currently - hourly - daily - configurable on Fri, 16 Dec 2016 03:31:24 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/crispis" aria-label="Profile: Crispis">@<bdi>Crispis</bdi></a> I’m not sure, but I think you may not need the comma after the ending curly bracket if you only have 1 item in modules.   (3rd line from the bottom)   I think that might be why config: {   }  doesn’t get an ending comma.</p>
]]></description><link>https://forum.magicmirror.builders/post/9419</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/9419</guid><dc:creator><![CDATA[Shockwave]]></dc:creator><pubDate>Fri, 16 Dec 2016 03:31:24 GMT</pubDate></item><item><title><![CDATA[Reply to Weatherunderground - currently - hourly - daily - configurable on Fri, 16 Dec 2016 02:45:59 GMT]]></title><description><![CDATA[<p dir="auto">Gettin’ the black screen as well…<br />
I’ve gone to the “post that may assist me” but I can’t seem to find anything from it. When looking at the console tab when F12 is pressed, it has stopped after 3 lines at the “Load script: modules/MMM-WunderGround//MMM-WunderGround.js” Opening that file it has the defaults for the api and pws blank. ok.</p>
<p dir="auto">Looking at the module coding…</p>
port: 8080,</p>
timeFormat: 12,
units: 'imperial',
			apikey: 'NUMBERS',
			pws: 'CO/Denver',
			hourly: '1',
			fctext: '1',
			fcdaycount: "5",
			fcdaystart: "0",
			hourlyinterval: "3",
			hourlycount: "2",
<p dir="auto">I can’t seem to find what is wrong. Are you able to spot my error or suggest some help?</p>
]]></description><link>https://forum.magicmirror.builders/post/9418</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/9418</guid><dc:creator><![CDATA[Crispis]]></dc:creator><pubDate>Fri, 16 Dec 2016 02:45:59 GMT</pubDate></item><item><title><![CDATA[Reply to Weatherunderground - currently - hourly - daily - configurable on Thu, 08 Sep 2016 09:06:02 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ostfilinchen" aria-label="Profile: ostfilinchen">@<bdi>ostfilinchen</bdi></a> Thanks!</p>
<p dir="auto">Slight oversight on my part when i added the horizontal layout. Now fixed. Please update MMM-WunderGround.</p>
]]></description><link>https://forum.magicmirror.builders/post/4499</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/4499</guid><dc:creator><![CDATA[RedNax]]></dc:creator><pubDate>Thu, 08 Sep 2016 09:06:02 GMT</pubDate></item><item><title><![CDATA[Reply to Weatherunderground - currently - hourly - daily - configurable on Thu, 08 Sep 2016 08:07:03 GMT]]></title><description><![CDATA[<p dir="auto">Hi all,</p>
<p dir="auto">first thanks for this great module. I have an issue to Display the time an days in one orientation.<br />
<img src="/uploads/files/1473321838776-20160907_210833-1.png" alt="0_1473321837460_20160907_210833-1.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">Can i Change the Orientation of the first column to flush right?</p>
<p dir="auto">Thanks<br />
Daniel</p>
]]></description><link>https://forum.magicmirror.builders/post/4496</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/4496</guid><dc:creator><![CDATA[ostfilinchen]]></dc:creator><pubDate>Thu, 08 Sep 2016 08:07:03 GMT</pubDate></item></channel></rss>
