<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Overlapping modules]]></title><description><![CDATA[<p dir="auto">I have done a fairly vanilla install and am having problems with some of the compliments I wrote overlapping with the calendar. <img src="/assets/uploads/files/1489426990918-mirror-error.png" alt="0_1489426985833_Mirror Error.PNG" class=" img-fluid img-markdown" /> I have looked through several forum posts in an effort to try and fix this, but to no avail. Does anyone have any suggestions? I can supply you with any information you may need.</p>
<p dir="auto">P.S. Disregard the gray box at the top I am remoted in with Teamviewer<br />
P.P.S. Is anyone else having problems with the time not changing for Day Light Savings Time?</p>
]]></description><link>https://forum.magicmirror.builders/topic/2060/overlapping-modules</link><generator>RSS for Node</generator><lastBuildDate>Sat, 16 May 2026 14:16:08 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/2060.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 13 Mar 2017 17:44:30 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Overlapping modules on Mon, 13 Mar 2017 21:42:26 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/zack949" aria-label="Profile: zack949">@<bdi>zack949</bdi></a> if you dont depend on having the module at exact this spot, probably it would fit into position <code>lower_third</code>.</p>
<p dir="auto">you could also set a fixed width to the compliments module in custom.css</p>
<pre><code>.compliments {
  width: 300px;
]]></description><link>https://forum.magicmirror.builders/post/17326</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/17326</guid><dc:creator><![CDATA[strawberry 3.141]]></dc:creator><pubDate>Mon, 13 Mar 2017 21:42:26 GMT</pubDate></item><item><title><![CDATA[Reply to Overlapping modules on Mon, 13 Mar 2017 18:01:44 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/zack949" aria-label="Profile: zack949">@<bdi>zack949</bdi></a> said in <a href="/post/17284">Overlapping modules</a>:</p>
<p dir="auto">P.S. Disregard the gray box at the top I am remoted in with Teamviewer</p>
<p dir="auto">Pay no attention to that man behind the curtain. ;-)</p>
<p dir="auto">P.P.S. Is anyone else having problems with the time not changing for Day Light Savings Time?</p>
<p dir="auto">I don’t know if this will help but in Preferences/Raspberry Pi Configuration/Localisation - Are your <code>Set Locale...</code> and your <code>Set Timezone...</code> correctly set?</p>
<p dir="auto">or</p>
<p dir="auto">If you set the Time Zone in raspi-config the Raspberry Pi will automatically update the time on boot, if connected to the internet.<br />
sudo raspi-config.<br />
Select Internationalisation Options.<br />
Select I2 Change Timezone.<br />
Select your Geographical Area.<br />
Select your nearest City.<br />
Select Finish.<br />
Select Yes to reboot now.</p>
]]></description><link>https://forum.magicmirror.builders/post/17286</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/17286</guid><dc:creator><![CDATA[Mykle1]]></dc:creator><pubDate>Mon, 13 Mar 2017 18:01:44 GMT</pubDate></item></channel></rss>
