<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Removing the inner bezel from a LCD monitor]]></title><description><![CDATA[<p dir="auto">I’m disassembling my LCD Monitor to harvest the tasty bits for my mirror and there’s a metal “inner” bezel around the monitor. Can I pop this off? Will it screw up my display by allowing light to leak out?</p>
<p dir="auto">(My mirror surface is much bigger than my monitor’s surface area, if that makes a difference.)</p>
<p dir="auto">Or: should I not bother and just keep the metal bezel in tact because it won’t net any better of a display?</p>
<p dir="auto">:::</p>
<p dir="auto">Spoiler Text</p>
]]></description><link>https://forum.magicmirror.builders/topic/2067/removing-the-inner-bezel-from-a-lcd-monitor</link><generator>RSS for Node</generator><lastBuildDate>Wed, 07 Oct 2026 19:08:27 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/2067.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 14 Mar 2017 02:25:07 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Removing the inner bezel from a LCD monitor on Tue, 14 Mar 2017 07:09:39 GMT]]></title><description><![CDATA[<p dir="auto">@mizzoudavis I leave the bezel intact. Other area not covered by bezel (outside the monitor), you simply add black/dark tape/paper/paint.</p>
]]></description><link>https://forum.magicmirror.builders/post/17357</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/17357</guid><dc:creator><![CDATA[slametps]]></dc:creator><pubDate>Tue, 14 Mar 2017 07:09:39 GMT</pubDate></item></channel></rss>
