<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[MMM-TrainConnections]]></title><description><![CDATA[<p dir="auto">So if I wanted to try this with say trains here in the US, where would I even start looking to obtain that information?  I still such a noob but like how would I even Google what to look for?</p>
]]></description><link>https://forum.magicmirror.builders/topic/209/mmm-trainconnections</link><generator>RSS for Node</generator><lastBuildDate>Thu, 21 May 2026 14:04:46 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/209.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 24 May 2016 17:08:58 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to MMM-TrainConnections on Sun, 30 Oct 2016 15:00:53 GMT]]></title><description><![CDATA[<p dir="auto">okay i can’t edit my post…</p>
<p dir="auto">how can i change the connection.php script so that i see when my train come to late ?</p>
<p dir="auto">i only wanna see my train from my city (for example berlin) to frankfurt<br />
with the lateness time</p>
<p dir="auto">but only the way to the city (like that <a href="https://forum.magicmirror.builders/uploads/files/1462363258197-mm_st.jpg">https://forum.magicmirror.builders/uploads/files/1462363258197-mm_st.jpg</a>)<br />
not the way back</p>
<p dir="auto">from the “Deutsche Bahn” i only got that (with apikey)<br />
<a href="http://download-data.deutschebahn.com/static/apis/fahrplan/Fpl-API-Doku-Open-Data-BETA-0_81_2.pdf" target="_blank" rel="noopener noreferrer nofollow ugc">http://download-data.deutschebahn.com/static/apis/fahrplan/Fpl-API-Doku-Open-Data-BETA-0_81_2.pdf</a></p>
]]></description><link>https://forum.magicmirror.builders/post/7325</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/7325</guid><dc:creator><![CDATA[geeflaxx]]></dc:creator><pubDate>Sun, 30 Oct 2016 15:00:53 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-TrainConnections on Wed, 26 Oct 2016 18:28:22 GMT]]></title><description><![CDATA[<p dir="auto">i can’t use the command ‘sudo command install’ cause it isn’t a right command</p>
<p dir="auto">(i install it in the modules order)<br />
but then i can change the api.php (have to add 2 api’s right)<br />
then i have to change my config (add the modul)</p>
<p dir="auto">but how i can get german api’s ?<br />
i wrote a email on <a href="mailto:DBOpenData@deutschebahn.com" target="_blank" rel="noopener noreferrer nofollow ugc">DBOpenData@deutschebahn.com</a> to give me the api’s</p>
<p dir="auto">but where should i add then the api’s in api.php ?</p>
]]></description><link>https://forum.magicmirror.builders/post/6985</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/6985</guid><dc:creator><![CDATA[geeflaxx]]></dc:creator><pubDate>Wed, 26 Oct 2016 18:28:22 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-TrainConnections on Mon, 25 Jul 2016 07:10:14 GMT]]></title><description><![CDATA[<p dir="auto">The Problem was Thatcher the Module folder had a wrong Name, MMM-trainconnetions.<br />
I renamed it to trainconnections and it works.</p>
]]></description><link>https://forum.magicmirror.builders/post/2900</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/2900</guid><dc:creator><![CDATA[shgmongohh]]></dc:creator><pubDate>Mon, 25 Jul 2016 07:10:14 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-TrainConnections on Mon, 25 Jul 2016 06:53:43 GMT]]></title><description><![CDATA[<p dir="auto">You will need to clon it in to <code> ~/MagicMirror/modules</code><br />
and add the config to your <code>config/config.js</code> file</p>
<p dir="auto">Bangee</p>
]]></description><link>https://forum.magicmirror.builders/post/2899</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/2899</guid><dc:creator><![CDATA[Bangee]]></dc:creator><pubDate>Mon, 25 Jul 2016 06:53:43 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-TrainConnections on Sun, 24 Jul 2016 17:46:55 GMT]]></title><description><![CDATA[<p dir="auto">Have I to clone TrainConnections in MagicMirror/Modules or only in MagicMirror?</p>
<p dir="auto">I only get a black screen on my MagicMirror Version2.</p>
]]></description><link>https://forum.magicmirror.builders/post/2865</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/2865</guid><dc:creator><![CDATA[shgmongohh]]></dc:creator><pubDate>Sun, 24 Jul 2016 17:46:55 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-TrainConnections on Fri, 27 May 2016 02:31:07 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/clebo99" aria-label="Profile: clebo99">@<bdi>clebo99</bdi></a> correct</p>
]]></description><link>https://forum.magicmirror.builders/post/1121</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/1121</guid><dc:creator><![CDATA[CommanderB]]></dc:creator><pubDate>Fri, 27 May 2016 02:31:07 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-TrainConnections on Thu, 26 May 2016 18:18:54 GMT]]></title><description><![CDATA[<p dir="auto">So I cloned the GoogleMaps one.  Two questions.</p>
<p dir="auto">The directory is off the root of the Module Directory, not in the default directory.  Is that correct?</p>
<p dir="auto">I’m about to run the NPM Install command.  That’s not going to write over anything I have right?   That just “adds” to what I already have, correct?</p>
]]></description><link>https://forum.magicmirror.builders/post/1112</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/1112</guid><dc:creator><![CDATA[clebo99]]></dc:creator><pubDate>Thu, 26 May 2016 18:18:54 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-TrainConnections on Wed, 25 May 2016 16:08:41 GMT]]></title><description><![CDATA[<p dir="auto">I think this one is Europe only - taker a look at localtransport module. This uses the Google APIs and works with many global transit systems.</p>
]]></description><link>https://forum.magicmirror.builders/post/1064</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/1064</guid><dc:creator><![CDATA[CommanderB]]></dc:creator><pubDate>Wed, 25 May 2016 16:08:41 GMT</pubDate></item></channel></rss>
