<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Last time connected to Net]]></title><description><![CDATA[<p dir="auto">(For debugging purposes)<br />
I have found the my (WiFi only) MM sometimes “falls off the net” - which means that the info it displays is outdated.<br />
It still display stuff, but there seems no EASY way for me to tell what happened as far as I can tell. I just notice that my calendar is outdated; that my Wunderlist is old; that my commute times don’t seem right…<br />
Then I try pinging/SSHing &amp; fail. Reboot time.</p>
<p dir="auto">So I am requesting a (small) module that states “last time connected” so I have an indication if things are wrong. Or I’d like someone to tell me how to deal with this. Or (better still) the module would check for WiFi signal &amp; then respawn a PM2 process.</p>
<p dir="auto">Thanks</p>
]]></description><link>https://forum.magicmirror.builders/topic/2098/last-time-connected-to-net</link><generator>RSS for Node</generator><lastBuildDate>Sun, 12 Apr 2026 16:27:35 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/2098.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 17 Mar 2017 23:28:47 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Last time connected to Net on Tue, 28 Mar 2017 21:28:34 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mykle1" aria-label="Profile: Mykle1">@<bdi>Mykle1</bdi></a> I did - I also run cron jobs to turn the monitor off &amp; on (night &amp; day). I just have “interesting” WiFi, so monitoring is not a bad idea.  Guess I really should run a ping of the MM from somewhere else &amp; send myself a txt if it goes down. I’ll putter around with IFTTT…</p>
]]></description><link>https://forum.magicmirror.builders/post/18395</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/18395</guid><dc:creator><![CDATA[amanzimdwini]]></dc:creator><pubDate>Tue, 28 Mar 2017 21:28:34 GMT</pubDate></item><item><title><![CDATA[Reply to Last time connected to Net on Tue, 28 Mar 2017 20:42:54 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/amanzimdwini" aria-label="Profile: amanzimdwini">@<bdi>amanzimdwini</bdi></a></p>
<p dir="auto">Have you done this?<br />
<a href="https://github.com/MichMich/MagicMirror/wiki/Configuring-the-Raspberry-Pi#disable-wifi-power-save" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/MichMich/MagicMirror/wiki/Configuring-the-Raspberry-Pi#disable-wifi-power-save</a></p>
<p dir="auto">(Snip)</p>
<p dir="auto"><strong>Disable WiFi Power Save</strong></p>
<p dir="auto">Edit /etc/modprobe.d/8192cu.conf</p>
<p dir="auto">sudo nano /etc/modprobe.d/8192cu.conf<br />
Add the following lines</p>
<h1>Disable power saving</h1>
<p dir="auto">options 8192cu rtw_power_mgnt=0 rtw_enusbss=1 rtw_ips_mode=1</p>
<p dir="auto"><strong>For Raspberry Pi 3</strong><br />
Edit /etc/network/interfaces</p>
<p dir="auto">sudo nano /etc/network/interfaces<br />
Add the following line under the wlan0 section</p>
<p dir="auto">wireless-power off<br />
Reboot your PI</p>
<p dir="auto">sudo reboot</p>
]]></description><link>https://forum.magicmirror.builders/post/18393</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/18393</guid><dc:creator><![CDATA[Mykle1]]></dc:creator><pubDate>Tue, 28 Mar 2017 20:42:54 GMT</pubDate></item><item><title><![CDATA[Reply to Last time connected to Net on Tue, 28 Mar 2017 20:34:06 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ashidian" aria-label="Profile: Ashidian">@<bdi>Ashidian</bdi></a> Yup. Thx.</p>
]]></description><link>https://forum.magicmirror.builders/post/18391</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/18391</guid><dc:creator><![CDATA[amanzimdwini]]></dc:creator><pubDate>Tue, 28 Mar 2017 20:34:06 GMT</pubDate></item><item><title><![CDATA[Reply to Last time connected to Net on Tue, 28 Mar 2017 20:31:34 GMT]]></title><description><![CDATA[<p dir="auto">You mean something like this? <a href="https://github.com/CFenner/MagicMirror-Ping-Module" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/CFenner/MagicMirror-Ping-Module</a></p>
]]></description><link>https://forum.magicmirror.builders/post/18388</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/18388</guid><dc:creator><![CDATA[Ashidian]]></dc:creator><pubDate>Tue, 28 Mar 2017 20:31:34 GMT</pubDate></item></channel></rss>
