<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Wich pir sensor ?]]></title><description><![CDATA[<p dir="auto">Hi !</p>
<p dir="auto">I want to put a pir sensor but I don’t know which one to choose and if it will be compatible with my monitor.<br />
The monitor is connected in DVI with a DVI / HDMI adapter.<br />
And if you have a good tutorial for me please ^^</p>
<p dir="auto">Thank you !</p>
]]></description><link>https://forum.magicmirror.builders/topic/2115/wich-pir-sensor</link><generator>RSS for Node</generator><lastBuildDate>Tue, 21 Apr 2026 19:45:44 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/2115.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 20 Mar 2017 08:15:20 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Wich pir sensor ? on Mon, 20 Mar 2017 09:30:16 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/yawns" aria-label="Profile: yawns">@<bdi>yawns</bdi></a></p>
<p dir="auto">Yes I want to simulate the behaviour before buying the sensor</p>
]]></description><link>https://forum.magicmirror.builders/post/17894</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/17894</guid><dc:creator><![CDATA[vicdilou]]></dc:creator><pubDate>Mon, 20 Mar 2017 09:30:16 GMT</pubDate></item><item><title><![CDATA[Reply to Wich pir sensor ? on Mon, 20 Mar 2017 09:15:09 GMT]]></title><description><![CDATA[<p dir="auto">What do you want to simulate? The behaviour before you buy a sensor? Or check the output/detection before actually disabling the screen?</p>
]]></description><link>https://forum.magicmirror.builders/post/17893</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/17893</guid><dc:creator><![CDATA[yawns]]></dc:creator><pubDate>Mon, 20 Mar 2017 09:15:09 GMT</pubDate></item><item><title><![CDATA[Reply to Wich pir sensor ? on Mon, 20 Mar 2017 08:46:17 GMT]]></title><description><![CDATA[<p dir="auto">Thank you</p>
<p dir="auto">There is a way to simulate the operation of the sensor to see the result on my monitor ?</p>
]]></description><link>https://forum.magicmirror.builders/post/17890</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/17890</guid><dc:creator><![CDATA[vicdilou]]></dc:creator><pubDate>Mon, 20 Mar 2017 08:46:17 GMT</pubDate></item><item><title><![CDATA[Reply to Wich pir sensor ? on Mon, 20 Mar 2017 08:41:19 GMT]]></title><description><![CDATA[<p dir="auto">The PIR sensor does not depend on your screen or the connection to the screen.<br />
The sensor comes with three pins:</p>
<ol>
<li>power supply</li>
<li>ground</li>
<li>data</li>
</ol>
<p dir="auto">If the sensor detects a heat change (e.g. a person is coming closer to the sensor) it triggers the data port to say “I noticed something”. Based on this detection you can tell your pi/your script to do whatever you want, for example disable the HDMI port.</p>
<p dir="auto">This tutorial is for arduino, but the technical part should be of help: <a href="https://learn.adafruit.com/pir-passive-infrared-proximity-motion-sensor/overview" target="_blank" rel="noopener noreferrer nofollow ugc">https://learn.adafruit.com/pir-passive-infrared-proximity-motion-sensor/overview</a></p>
]]></description><link>https://forum.magicmirror.builders/post/17889</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/17889</guid><dc:creator><![CDATA[yawns]]></dc:creator><pubDate>Mon, 20 Mar 2017 08:41:19 GMT</pubDate></item></channel></rss>
