<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[[newsfeed] (default module) - get stuck after first RSS download and does not refresh reliably]]></title><description><![CDATA[<p dir="auto">Hi,</p>
<p dir="auto">I am using the default newsfeed module and the news get stuck.</p>
<p dir="auto">Below are the logs with the error ENOTFOUND :</p>
<p dir="auto">I tried to search StackOverflow but I am not knowledgeable enough in javascript to understand what to do. Any help ?</p>
<p dir="auto">mm-start-error-0.log</p>
<pre><code>{ Error: getaddrinfo ENOTFOUND www.lemonde.fr www.lemonde.fr:80
    at errnoException (dns.js:28:10)
    at GetAddrInfoReqWrap.onlookup [as oncomplete] (dns.js:76:26)
  code: 'ENOTFOUND',
  errno: 'ENOTFOUND',
  syscall: 'getaddrinfo',
  hostname: 'www.lemonde.fr',
  host: 'www.lemonde.fr',
  port: 80 }
{ Error: getaddrinfo ENOTFOUND www.economist.com www.economist.com:80
  code: 'ENOTFOUND',
  errno: 'ENOTFOUND',
  hostname: 'www.economist.com',
  host: 'www.economist.com',
  port: 80 }
<p dir="auto">And from the</p>
<p dir="auto">mm-start-out-0.log</p>
<pre><code>&gt; magicmirror@2.1.0 start /home/pi/MagicMirror
&gt; electron js/electron.js
Starting MagicMirror: v2.1.0
Loading config ...
Loading module helpers ...
All module helpers loaded.
Starting server op port 8080 ...
Server started ...
Starting module: newsfeed
Connecting socket for: mmm_velib
Sockets connected &amp; modules started ...
Launching application.
Create new calendar fetcher for url: https://calendar.google.com[XYZ]basic.ics - Interval: 300000
Create new calendar fetcher for url: https://calendar.google.com/[XYZ]basic.ics - Interval: 300000
Create new news fetcher for url: http://www.lemonde.fr/rss/une.xml - Interval: 300000
Create new news fetcher for url: http://www.economist.com/sections/international/rss.xml - Interval: 300000
Loading config ...
Server started ...
Connecting socket for: MMM-Remote-Control
Starting node helper for: MMM-Remote-Control
Create new calendar fetcher for url: https://calendar.google.com/calendar/[XYZ]/basic.ics - Interval: 300000
Powering off HDMI
Powering on HDMI with preferred settings
]]></description><link>https://forum.magicmirror.builders/topic/2116/newsfeed-default-module-get-stuck-after-first-rss-download-and-does-not-refresh-reliably</link><generator>RSS for Node</generator><lastBuildDate>Fri, 07 Aug 2026 18:09:09 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/2116.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 20 Mar 2017 09:31:20 GMT</pubDate><ttl>60</ttl></channel></rss>
