<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Run MM on Ubuntu 16 VM]]></title><description><![CDATA[<p dir="auto">Hi everyone!<br />
I’m looking foward to start developing the MM, but at the moment in my country I can’t get a raspi.</p>
<p dir="auto">Is it any chance to start trying on a ubuntu 16 VM?</p>
<p dir="auto">Kind regards</p>
]]></description><link>https://forum.magicmirror.builders/topic/2117/run-mm-on-ubuntu-16-vm</link><generator>RSS for Node</generator><lastBuildDate>Sat, 13 Jun 2026 22:01:28 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/2117.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 20 Mar 2017 14:42:17 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Run MM on Ubuntu 16 VM on Tue, 23 Oct 2018 11:43:51 GMT]]></title><description><![CDATA[<p dir="auto">Hey,</p>
<p dir="auto">i tried tu remove and reinstall MM.<br />
Here is the new error :</p>
<pre><code>VirtualBox:~/MagicMirror$ node serveronly/
module.js:328
    throw err;
Error: Cannot find module 'express'
    at Function.Module._resolveFilename (module.js:326:15)
    at Function.Module._load (module.js:277:25)
    at Module.require (module.js:354:17)
    at require (internal/module.js:12:17)
    at Object.&lt;anonymous&gt; (/home/monagraphic/MagicMirror/js/server.js:8:15)
    at Module._compile (module.js:410:26)
    at Object.Module._extensions..js (module.js:417:10)
    at Module.load (module.js:344:32)
    at Function.Module._load (module.js:301:12)
<p dir="auto">Some one can help me ?</p>
<p dir="auto">EDIT :</p>
<p dir="auto">It works, i launch a second time “npm install”.</p>
]]></description><link>https://forum.magicmirror.builders/post/45761</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/45761</guid><dc:creator><![CDATA[reitrac]]></dc:creator><pubDate>Tue, 23 Oct 2018 11:43:51 GMT</pubDate></item><item><title><![CDATA[Reply to Run MM on Ubuntu 16 VM on Wed, 17 Oct 2018 15:24:49 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/justjim1220" aria-label="Profile: justjim1220">@<bdi>justjim1220</bdi></a> Yeah of course :)<br />
I followed <a class="plugin-mentions-user plugin-mentions-a" href="/user/mykle1" aria-label="Profile: Mykle1">@<bdi>Mykle1</bdi></a> tutorial.</p>
<p dir="auto">If can help, I’m using VirtualBox on MAC with UBUNTU 16.04 LTS</p>
]]></description><link>https://forum.magicmirror.builders/post/45549</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/45549</guid><dc:creator><![CDATA[reitrac]]></dc:creator><pubDate>Wed, 17 Oct 2018 15:24:49 GMT</pubDate></item><item><title><![CDATA[Reply to Run MM on Ubuntu 16 VM on Tue, 16 Oct 2018 20:08:37 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/reitrac" aria-label="Profile: reitrac">@<bdi>reitrac</bdi></a></p>
<p dir="auto">Did you change the name of the config file from ‘config.js.sample’ to ‘config.js’ ?</p>
]]></description><link>https://forum.magicmirror.builders/post/45510</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/45510</guid><dc:creator><![CDATA[justjim1220]]></dc:creator><pubDate>Tue, 16 Oct 2018 20:08:37 GMT</pubDate></item><item><title><![CDATA[Reply to Run MM on Ubuntu 16 VM on Tue, 16 Oct 2018 17:31:41 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mykle1" aria-label="Profile: Mykle1">@<bdi>Mykle1</bdi></a> @Sean Didn’t works with the default config … I don’t know why.</p>
]]></description><link>https://forum.magicmirror.builders/post/45504</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/45504</guid><dc:creator><![CDATA[reitrac]]></dc:creator><pubDate>Tue, 16 Oct 2018 17:31:41 GMT</pubDate></item><item><title><![CDATA[Reply to Run MM on Ubuntu 16 VM on Tue, 16 Oct 2018 11:58:12 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/reitrac" aria-label="Profile: reitrac">@<bdi>reitrac</bdi></a><br />
I can bet you have missed comma after <code>language:"fr"</code>.  95% of syntax error was that thing in my case. :D</p>
]]></description><link>https://forum.magicmirror.builders/post/45488</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/45488</guid><dc:creator><![CDATA[[[global:former-user]]]]></dc:creator><pubDate>Tue, 16 Oct 2018 11:58:12 GMT</pubDate></item><item><title><![CDATA[Reply to Run MM on Ubuntu 16 VM on Tue, 16 Oct 2018 11:33:53 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/reitrac" aria-label="Profile: reitrac">@<bdi>reitrac</bdi></a></p>
 * MIT Licensed.
var config = {
	port: 8080,
	language: "en",
	timeFormat: 24,
	units: "metric",
			module: "alert",
			module: "updatenotification",
			position: "top_bar"
			module: "clock",
			position: "top_left"
			header: "US Holidays",
						symbol: "calendar-check-o ",
						url: "webcal://www.calendarlabs.com/templates/ical/US-Holidays.ics"
			module: "compliments",
			position: "lower_third"
			module: "currentweather",
				locationID: "",  //ID from http://bulk.openweathermap.org/sample/; unzip the gz file and find your city
				appid: "YOUR_OPENWEATHER_API_KEY"
			module: "weatherforecast",
			header: "Weather Forecast",
				locationID: "5128581",  //ID from http://www.openweathermap.org/help/city_list.txt
			module: "newsfeed",
			position: "bottom_bar",
				feeds: [
						title: "New York Times",
				showSourceTitle: true,
				showPublishDate: true
]]></description><link>https://forum.magicmirror.builders/post/45486</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/45486</guid><dc:creator><![CDATA[Mykle1]]></dc:creator><pubDate>Tue, 16 Oct 2018 11:33:53 GMT</pubDate></item><item><title><![CDATA[Reply to Run MM on Ubuntu 16 VM on Tue, 16 Oct 2018 11:55:16 GMT]]></title><description><![CDATA[<p dir="auto">My config.js is by default :D<br />
I just changed “en” by “fr”.</p>
<p dir="auto">I’ll try to find config.js on Git and come back to you.</p>
<p dir="auto">Thanks.</p>
<p dir="auto">I downloaded the latest config.js from : <a href="https://github.com/MichMich/MagicMirror/blob/master/config/config.js.sample" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/MichMich/MagicMirror/blob/master/config/config.js.sample</a><br />
And not works :'(</p>
]]></description><link>https://forum.magicmirror.builders/post/45485</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/45485</guid><dc:creator><![CDATA[reitrac]]></dc:creator><pubDate>Tue, 16 Oct 2018 11:55:16 GMT</pubDate></item><item><title><![CDATA[Reply to Run MM on Ubuntu 16 VM on Tue, 16 Oct 2018 10:14:35 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/reitrac" aria-label="Profile: reitrac">@<bdi>reitrac</bdi></a><br />
Your config.js might have some misspell or wrong syntax.</p>
]]></description><link>https://forum.magicmirror.builders/post/45483</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/45483</guid><dc:creator><![CDATA[[[global:former-user]]]]></dc:creator><pubDate>Tue, 16 Oct 2018 10:14:35 GMT</pubDate></item><item><title><![CDATA[Reply to Run MM on Ubuntu 16 VM on Tue, 16 Oct 2018 08:33:49 GMT]]></title><description><![CDATA[<p dir="auto">Hello everyone,</p>
<p dir="auto">3months later, I hope it’s not too late :)</p>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/axled" aria-label="Profile: AxLed">@<bdi>AxLed</bdi></a> i’m trying to use “node serveronly” but have this error :<br />
WARNING! Could not validate config file. Please correct syntax errors. Starting with default configuration.</p>
<p dir="auto"><img src="/assets/uploads/files/1539678764899-capture-d-e-cran-2018-10-16-a-10.31.27.png" alt="0_1539678763897_Capture d’écran 2018-10-16 à 10.31.27.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">I followed <a class="plugin-mentions-user plugin-mentions-a" href="/user/mykle1" aria-label="Profile: Mykle1">@<bdi>Mykle1</bdi></a> tutorial to create default config.js but this not works.</p>
<p dir="auto">Any idea ? (My internet connection works)</p>
]]></description><link>https://forum.magicmirror.builders/post/45482</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/45482</guid><dc:creator><![CDATA[reitrac]]></dc:creator><pubDate>Tue, 16 Oct 2018 08:33:49 GMT</pubDate></item><item><title><![CDATA[Reply to Run MM on Ubuntu 16 VM on Wed, 25 Jul 2018 04:27:16 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/axled" aria-label="Profile: axled">@<bdi>axled</bdi></a></p>
<p dir="auto">Thanks, that worked!!!<br />
:winking_face: :winking_face: :smiling_face: :smiling_face: :grinning_face_with_smiling_eyes: :grinning_face_with_smiling_eyes: :smiling_face_with_sunglasses: :smiling_face_with_sunglasses:</p>
]]></description><link>https://forum.magicmirror.builders/post/42610</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/42610</guid><dc:creator><![CDATA[justjim1220]]></dc:creator><pubDate>Wed, 25 Jul 2018 04:27:16 GMT</pubDate></item><item><title><![CDATA[Reply to Run MM on Ubuntu 16 VM on Mon, 23 Jul 2018 10:38:45 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/justjim1220" aria-label="Profile: justjim1220">@<bdi>justjim1220</bdi></a><br />
try this.</p>
<pre><code>sudo apt-get install libgconf-2-4
]]></description><link>https://forum.magicmirror.builders/post/42539</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/42539</guid><dc:creator><![CDATA[[[global:former-user]]]]></dc:creator><pubDate>Mon, 23 Jul 2018 10:38:45 GMT</pubDate></item><item><title><![CDATA[Reply to Run MM on Ubuntu 16 VM on Mon, 23 Jul 2018 07:54:53 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/justjim1220" aria-label="Profile: justjim1220">@<bdi>justjim1220</bdi></a><br />
did you try to start the “Server only” mode an open a browser on Ubuntu with IP of your MM?<br />
To start Server only do <code>node serveronly</code> in your MagicMirror directory.</p>
<p dir="auto">Maybe this helps to find the problem.</p>
<p dir="auto">AxLED</p>
]]></description><link>https://forum.magicmirror.builders/post/42534</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/42534</guid><dc:creator><![CDATA[AxLed]]></dc:creator><pubDate>Mon, 23 Jul 2018 07:54:53 GMT</pubDate></item><item><title><![CDATA[Reply to Run MM on Ubuntu 16 VM on Mon, 23 Jul 2018 04:12:26 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mykle1" aria-label="Profile: mykle1">@<bdi>mykle1</bdi></a></p>
<p dir="auto">Still getting this…</p>
<p dir="auto"><img src="/assets/uploads/files/1532318743201-screenshot-from-2018-07-22-23-03-01.png" alt="0_1532318741939_Screenshot from 2018-07-22 23-03-01.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">doesn’t matter if i’m in Ubuntu 16.04 OR 18.04<br />
and it doesn’t matter if I’m in home directory OR the root directory…</p>
<p dir="auto">is there a different way to run MM other than ‘npm start’?</p>
]]></description><link>https://forum.magicmirror.builders/post/42528</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/42528</guid><dc:creator><![CDATA[justjim1220]]></dc:creator><pubDate>Mon, 23 Jul 2018 04:12:26 GMT</pubDate></item><item><title><![CDATA[Reply to Run MM on Ubuntu 16 VM on Mon, 23 Jul 2018 02:39:28 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mykle1" aria-label="Profile: mykle1">@<bdi>mykle1</bdi></a></p>
<p dir="auto">so I have everything now installed in the root but still getting nowhere with getting the mirror to start up and run…:worried_face:</p>
]]></description><link>https://forum.magicmirror.builders/post/42524</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/42524</guid><dc:creator><![CDATA[justjim1220]]></dc:creator><pubDate>Mon, 23 Jul 2018 02:39:28 GMT</pubDate></item><item><title><![CDATA[Reply to Run MM on Ubuntu 16 VM on Mon, 23 Jul 2018 00:07:32 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/justjim1220" aria-label="Profile: justjim1220">@<bdi>justjim1220</bdi></a> said in <a href="/post/42507">Run MM on Ubuntu 16 VM</a>:</p>
<p dir="auto">Got any ideas?</p>
<p dir="auto">Why are you using <strong>sudo</strong> <code>npm start</code>? You shouldn’t use sudo to install MM or run MM. That can lead to problems. Also, it shouldn’t matter but for the sake of conformity I always install MM in the home directory</p>
]]></description><link>https://forum.magicmirror.builders/post/42518</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/42518</guid><dc:creator><![CDATA[Mykle1]]></dc:creator><pubDate>Mon, 23 Jul 2018 00:07:32 GMT</pubDate></item><item><title><![CDATA[Reply to Run MM on Ubuntu 16 VM on Sun, 22 Jul 2018 19:42:54 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/justjim1220" aria-label="Profile: justjim1220">@<bdi>justjim1220</bdi></a> said in <a href="/post/42507">Run MM on Ubuntu 16 VM</a>:</p>
<p dir="auto">error Make sure you have the latest version of node.js and npm installed.</p>
<p dir="auto">Upgrade npm with</p>
<pre><code>npm install -g npm@latest
]]></description><link>https://forum.magicmirror.builders/post/42509</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/42509</guid><dc:creator><![CDATA[NoNameRo]]></dc:creator><pubDate>Sun, 22 Jul 2018 19:42:54 GMT</pubDate></item><item><title><![CDATA[Reply to Run MM on Ubuntu 16 VM on Sun, 22 Jul 2018 18:56:33 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mykle1" aria-label="Profile: Mykle1">@<bdi>Mykle1</bdi></a></p>
<p dir="auto">ok, I now have both Ubuntu versions 16.04 and 18.04 up and running…</p>
<p dir="auto">I have Chrome, node.js, npm, &amp; git installed…</p>
<p dir="auto">I have MagicMirror installed…</p>
<p dir="auto">Getting the following error with both versions…</p>
<p dir="auto"><img src="/assets/uploads/files/1532285623566-screenshot-from-2018-07-22-13-49-02.png" alt="0_1532285621408_Screenshot from 2018-07-22 13-49-02.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">log file…</p>
<pre><code>0 info it worked if it ends with ok
1 verbose cli [ '/usr/bin/node', '/usr/bin/npm', 'start' ]
2 info using npm@3.5.2
3 info using node@v8.10.0
5 info lifecycle magicmirror@2.4.1~prestart: magicmirror@2.4.1
6 silly lifecycle magicmirror@2.4.1~prestart: no script for prestart, continuing
7 info lifecycle magicmirror@2.4.1~start: magicmirror@2.4.1
8 verbose lifecycle magicmirror@2.4.1~start: unsafe-perm in lifecycle true
9 verbose lifecycle magicmirror@2.4.1~start: PATH: /usr/share/npm/bin/node-gyp-bin:/home/wes/MagicMirror/node_modules/.bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/snap/bin
10 verbose lifecycle magicmirror@2.4.1~start: CWD: /home/wes/MagicMirror
11 silly lifecycle magicmirror@2.4.1~start: Args: [ '-c', 'sh run-start.sh' ]
12 info lifecycle magicmirror@2.4.1~start: Failed to exec start script
13 verbose stack Error: magicmirror@2.4.1 start: `sh run-start.sh`
13 verbose stack spawn ENOENT
13 verbose stack     at ChildProcess.&lt;anonymous&gt; (/usr/share/npm/lib/utils/spawn.js:17:16)
13 verbose stack     at emitTwo (events.js:126:13)
13 verbose stack     at ChildProcess.emit (events.js:214:7)
13 verbose stack     at maybeClose (internal/child_process.js:925:16)
13 verbose stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:209:5)
14 verbose pkgid magicmirror@2.4.1
15 verbose cwd /home/wes/MagicMirror
16 error Linux 4.15.0-29-generic
17 error argv "/usr/bin/node" "/usr/bin/npm" "start"
18 error node v8.10.0
19 error npm  v3.5.2
20 error file sh
21 error code ELIFECYCLE
22 error errno ENOENT
23 error syscall spawn
24 error magicmirror@2.4.1 start: `sh run-start.sh`
24 error spawn ENOENT
25 error Failed at the magicmirror@2.4.1 start script 'sh run-start.sh'.
25 error Make sure you have the latest version of node.js and npm installed.
25 error If you do, this is most likely a problem with the magicmirror package,
25 error not with npm itself.
25 error Tell the author that this fails on your system:
25 error     sh run-start.sh
25 error You can get information on how to open an issue for this project with:
25 error     npm bugs magicmirror
25 error Or if that isn't available, you can get their info via:
25 error     npm owner ls magicmirror
25 error There is likely additional logging output above.
26 verbose exit [ 1, true ]
]]></description><link>https://forum.magicmirror.builders/post/42507</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/42507</guid><dc:creator><![CDATA[justjim1220]]></dc:creator><pubDate>Sun, 22 Jul 2018 18:56:33 GMT</pubDate></item><item><title><![CDATA[Reply to Run MM on Ubuntu 16 VM on Thu, 31 May 2018 18:25:16 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/axled" aria-label="Profile: axled">@<bdi>axled</bdi></a> yes I did but nothing changed.  Do you have to make it work on a virtual machine? How to enable it on Ubuntu?</p>
]]></description><link>https://forum.magicmirror.builders/post/40015</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/40015</guid><dc:creator><![CDATA[Hriereb]]></dc:creator><pubDate>Thu, 31 May 2018 18:25:16 GMT</pubDate></item><item><title><![CDATA[Reply to Run MM on Ubuntu 16 VM on Thu, 31 May 2018 15:59:40 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/hriereb" aria-label="Profile: Hriereb">@<bdi>Hriereb</bdi></a><br />
Did  you install “npm” and “node” as this sometimes isnt installed at ubuntu by default?</p>
]]></description><link>https://forum.magicmirror.builders/post/39997</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/39997</guid><dc:creator><![CDATA[AxLed]]></dc:creator><pubDate>Thu, 31 May 2018 15:59:40 GMT</pubDate></item><item><title><![CDATA[Reply to Run MM on Ubuntu 16 VM on Thu, 31 May 2018 15:16:39 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/pepemujica" aria-label="Profile: pepemujica">@<bdi>pepemujica</bdi></a> said in <a href="/post/17931">Run MM on Ubuntu 16 VM</a>:</p>
<p dir="auto">Hi <a class="plugin-mentions-user plugin-mentions-a" href="/user/mykle1" aria-label="Profile: Mykle1">@<bdi>Mykle1</bdi></a> Thanks for the answer.<br />
I’ve started following the instructions, but I get the following error:</p>
<p dir="auto"><img src="/assets/uploads/files/1490032841979-upload-627b7d7b-12f7-443e-b447-8750893adc5b.png" alt="0_1490032831021_upload-627b7d7b-12f7-443e-b447-8750893adc5b" class=" img-fluid img-markdown" /></p>
<p dir="auto"><img src="/assets/uploads/files/1490032899839-upload-f0ae1e26-6c2e-4c9d-a476-149c808e2b85.png" alt="0_1490032896329_upload-f0ae1e26-6c2e-4c9d-a476-149c808e2b85" class=" img-fluid img-markdown" /></p>
<p dir="auto">Any idea why?</p>
<p dir="auto">I have the same kind of issue on ubuntu 18.04, did someone fix it? When someone says that it doesn’t run out of the box, what does this means?</p>
]]></description><link>https://forum.magicmirror.builders/post/39990</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/39990</guid><dc:creator><![CDATA[Hriereb]]></dc:creator><pubDate>Thu, 31 May 2018 15:16:39 GMT</pubDate></item><item><title><![CDATA[Reply to Run MM on Ubuntu 16 VM on Fri, 22 Dec 2017 01:28:07 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/rtlucht78" aria-label="Profile: rtlucht78">@<bdi>rtlucht78</bdi></a></p>
<p dir="auto">Yes, I have one laptop running ubuntu 16.04 and a netbook running ubuntu 14.04. Both are running MM</p>
]]></description><link>https://forum.magicmirror.builders/post/32614</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/32614</guid><dc:creator><![CDATA[Mykle1]]></dc:creator><pubDate>Fri, 22 Dec 2017 01:28:07 GMT</pubDate></item><item><title><![CDATA[Reply to Run MM on Ubuntu 16 VM on Fri, 22 Dec 2017 01:19:24 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mykle1" aria-label="Profile: Mykle1">@<bdi>Mykle1</bdi></a> Did you get this to work on your device running Ubuntu 16.04?  I am trying this on an old tablet running Ubuntu Mate 16.04.</p>
]]></description><link>https://forum.magicmirror.builders/post/32611</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/32611</guid><dc:creator><![CDATA[rtlucht78]]></dc:creator><pubDate>Fri, 22 Dec 2017 01:19:24 GMT</pubDate></item><item><title><![CDATA[Reply to Run MM on Ubuntu 16 VM on Tue, 21 Mar 2017 05:15:41 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/pepemujica" aria-label="Profile: pepemujica">@<bdi>pepemujica</bdi></a><br />
run sudo npm install in MagicMirror</p>
]]></description><link>https://forum.magicmirror.builders/post/17957</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/17957</guid><dc:creator><![CDATA[amanzimdwini]]></dc:creator><pubDate>Tue, 21 Mar 2017 05:15:41 GMT</pubDate></item><item><title><![CDATA[Reply to Run MM on Ubuntu 16 VM on Mon, 20 Mar 2017 18:41:28 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/pepemujica" aria-label="Profile: pepemujica">@<bdi>pepemujica</bdi></a></p>
<p dir="auto">Ok, someone will help you at some point. I don’t know if it matters but I’m running uBuntu 16.04 LTS, not as a VM</p>
]]></description><link>https://forum.magicmirror.builders/post/17934</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/17934</guid><dc:creator><![CDATA[Mykle1]]></dc:creator><pubDate>Mon, 20 Mar 2017 18:41:28 GMT</pubDate></item></channel></rss>
