<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Start MagicMirror without node serveronly]]></title><description><![CDATA[<p dir="auto">Hello,</p>
<p dir="auto">I can run the MagicMirror with “node serveronly” command from MagicMirror directory. Is this the proper way to start it? Seems like there should be another option - what am I doing wrong?</p>
]]></description><link>https://forum.magicmirror.builders/topic/2168/start-magicmirror-without-node-serveronly</link><generator>RSS for Node</generator><lastBuildDate>Wed, 13 May 2026 09:21:09 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/2168.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 29 Mar 2017 16:32:11 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Start MagicMirror without node serveronly on Wed, 29 Mar 2017 18:19:53 GMT]]></title><description><![CDATA[<p dir="auto">Thanks for your reply. I am running a Pi 3. node serveronly works fine and I am able to launch the magic mirror in Chromium, I just thought there was a more “elegant” solution to get it started. I will check out the tutorial. Thanks!</p>
]]></description><link>https://forum.magicmirror.builders/post/18442</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/18442</guid><dc:creator><![CDATA[dapter]]></dc:creator><pubDate>Wed, 29 Mar 2017 18:19:53 GMT</pubDate></item><item><title><![CDATA[Reply to Start MagicMirror without node serveronly on Wed, 29 Mar 2017 17:59:05 GMT]]></title><description><![CDATA[<p dir="auto">That depends on what raspberry you are using and what you want to achieve.<br />
Running <code>node serveronly</code> allows you to point the browser of your choice to run the magic mirror and do proper debugging.<br />
You can switch to <code>pm2</code> to automate the start of your mirror. There is a tutorial how to do this.</p>
<p dir="auto"><a href="https://github.com/MichMich/MagicMirror/wiki/Auto-Starting-MagicMirror" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/MichMich/MagicMirror/wiki/Auto-Starting-MagicMirror</a></p>
]]></description><link>https://forum.magicmirror.builders/post/18437</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/18437</guid><dc:creator><![CDATA[yawns]]></dc:creator><pubDate>Wed, 29 Mar 2017 17:59:05 GMT</pubDate></item></channel></rss>
