<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[MMM-Swipe - Sensor]]></title><description><![CDATA[<p dir="auto"><a href="https://forum.magicmirror.builders/topic/174/mmm-swipe-hand-gestures">This</a> looks great! Thanks for sharing the module <a class="plugin-mentions-user plugin-mentions-a" href="/user/mochman" aria-label="Profile: mochman">@<bdi>mochman</bdi></a>  :)<br />
How do you plan to integrate the sensors in the housing of your mirror? I guess it’s not possible to cover them with glass or plastic, right?</p>
]]></description><link>https://forum.magicmirror.builders/topic/217/mmm-swipe-sensor</link><generator>RSS for Node</generator><lastBuildDate>Tue, 19 May 2026 01:14:43 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/217.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 07 Jun 2016 15:30:56 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to MMM-Swipe - Sensor on Fri, 17 Jun 2016 03:00:25 GMT]]></title><description><![CDATA[<p dir="auto">You don’t have to, if you just want to use a jumper cable like this one:<br />
<img src="http://i.ebayimg.com/images/g/BxIAAOxyOeBRyvzt/s-l300.jpg" alt="Image" class=" img-fluid img-markdown" /><br />
It should connect the raspberry pi to the sonic device.</p>
]]></description><link>https://forum.magicmirror.builders/post/1715</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/1715</guid><dc:creator><![CDATA[mochman]]></dc:creator><pubDate>Fri, 17 Jun 2016 03:00:25 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Swipe - Sensor on Thu, 16 Jun 2016 20:03:08 GMT]]></title><description><![CDATA[<p dir="auto">Completely noob question, will I have to solder this in?</p>
]]></description><link>https://forum.magicmirror.builders/post/1709</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/1709</guid><dc:creator><![CDATA[Mitchfarino]]></dc:creator><pubDate>Thu, 16 Jun 2016 20:03:08 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Swipe - Sensor on Thu, 09 Jun 2016 08:39:49 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mochman" aria-label="Profile: mochman">@<bdi>mochman</bdi></a> Great! Look forward to seeing it.</p>
<p dir="auto">I’ve just ordered some sensors, so waiting on them to arrive.</p>
<p dir="auto">Thanks for the module, it’s great!</p>
]]></description><link>https://forum.magicmirror.builders/post/1520</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/1520</guid><dc:creator><![CDATA[Mitchfarino]]></dc:creator><pubDate>Thu, 09 Jun 2016 08:39:49 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Swipe - Sensor on Wed, 08 Jun 2016 19:06:24 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mitchfarino" aria-label="Profile: Mitchfarino">@<bdi>Mitchfarino</bdi></a> I will once I do wire everything up.  I’m in the middle of a move, so when I get settled into my new place I can start building.</p>
]]></description><link>https://forum.magicmirror.builders/post/1505</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/1505</guid><dc:creator><![CDATA[mochman]]></dc:creator><pubDate>Wed, 08 Jun 2016 19:06:24 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Swipe - Sensor on Tue, 07 Jun 2016 21:38:00 GMT]]></title><description><![CDATA[<p dir="auto">Could you post the finished “product” wired up?</p>
<p dir="auto">Just wanting to visualise how it would look.</p>
<p dir="auto">Fantastic work by the way, I’m now this could be used in stead of the PIR sensor to activate and deactivate the monitor.</p>
<p dir="auto">Or even instead of the camera/ facial recognition module to switch between profiles!</p>
]]></description><link>https://forum.magicmirror.builders/post/1470</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/1470</guid><dc:creator><![CDATA[Mitchfarino]]></dc:creator><pubDate>Tue, 07 Jun 2016 21:38:00 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Swipe - Sensor on Tue, 07 Jun 2016 16:18:18 GMT]]></title><description><![CDATA[<p dir="auto">No, but I did test it behind a mesh speaker screen.  They work just fine behind that, so I’ll just mount them where I mount the speakers.</p>
]]></description><link>https://forum.magicmirror.builders/post/1453</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/1453</guid><dc:creator><![CDATA[mochman]]></dc:creator><pubDate>Tue, 07 Jun 2016 16:18:18 GMT</pubDate></item></channel></rss>
