<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[[SOLVED] Help on Install]]></title><description><![CDATA[<p dir="auto">I seem to have installed everything, but when i run cd MagicMirror/config I get -bash: cd: MagicMirror/config: No such file or directory</p>
<p dir="auto">Ideas?</p>
]]></description><link>https://forum.magicmirror.builders/topic/2189/solved-help-on-install</link><generator>RSS for Node</generator><lastBuildDate>Wed, 13 May 2026 12:39:17 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/2189.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 01 Apr 2017 20:42:59 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to [SOLVED] Help on Install on Sun, 02 Apr 2017 14:46:59 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/strawberry-3.141" aria-label="Profile: strawberry-3.141">@<bdi>strawberry-3.141</bdi></a> said in <a href="/post/18666">Help on Install</a>:</p>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/hartattack" aria-label="Profile: hartattack">@<bdi>hartattack</bdi></a> you’re already logged in as pi <code>user@host</code></p>
<p dir="auto">Hey! I was able to figure this out pretty late last night. When I updated/installed the latest node version, it must not have taken. I re-updated it and now it is working like a charm! Thank you for the help~</p>
]]></description><link>https://forum.magicmirror.builders/post/18684</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/18684</guid><dc:creator><![CDATA[hartattack]]></dc:creator><pubDate>Sun, 02 Apr 2017 14:46:59 GMT</pubDate></item><item><title><![CDATA[Reply to [SOLVED] Help on Install on Sun, 02 Apr 2017 09:36:50 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/hartattack" aria-label="Profile: hartattack">@<bdi>hartattack</bdi></a> you’re already logged in as pi <code>user@host</code></p>
]]></description><link>https://forum.magicmirror.builders/post/18666</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/18666</guid><dc:creator><![CDATA[strawberry 3.141]]></dc:creator><pubDate>Sun, 02 Apr 2017 09:36:50 GMT</pubDate></item><item><title><![CDATA[Reply to [SOLVED] Help on Install on Sat, 01 Apr 2017 21:29:26 GMT]]></title><description><![CDATA[<p dir="auto">tried the su pi command, i enter my password, but it takes me back to pi@retropie</p>
]]></description><link>https://forum.magicmirror.builders/post/18652</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/18652</guid><dc:creator><![CDATA[hartattack]]></dc:creator><pubDate>Sat, 01 Apr 2017 21:29:26 GMT</pubDate></item><item><title><![CDATA[Reply to [SOLVED] Help on Install on Sat, 01 Apr 2017 21:26:18 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/strawberry-3.141" aria-label="Profile: strawberry-3.141">@<bdi>strawberry-3.141</bdi></a> said in <a href="/post/18645">Help on Install</a>:</p>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/hartattack" aria-label="Profile: hartattack">@<bdi>hartattack</bdi></a> when you open the terminal in which directory are you and in which did you install the MagicMirror? can you execute <code>ls</code></p>
<p dir="auto">I am stuck in the pi@retropie command line, can’t seem to switch</p>
]]></description><link>https://forum.magicmirror.builders/post/18651</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/18651</guid><dc:creator><![CDATA[hartattack]]></dc:creator><pubDate>Sat, 01 Apr 2017 21:26:18 GMT</pubDate></item><item><title><![CDATA[Reply to [SOLVED] Help on Install on Sat, 01 Apr 2017 21:00:46 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/hartattack" aria-label="Profile: hartattack">@<bdi>hartattack</bdi></a> when you open the terminal in which directory are you and in which did you install the MagicMirror? can you execute <code>ls</code></p>
]]></description><link>https://forum.magicmirror.builders/post/18645</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/18645</guid><dc:creator><![CDATA[strawberry 3.141]]></dc:creator><pubDate>Sat, 01 Apr 2017 21:00:46 GMT</pubDate></item><item><title><![CDATA[Reply to [SOLVED] Help on Install on Sat, 01 Apr 2017 20:57:53 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/strawberry-3.141" aria-label="Profile: strawberry-3.141">@<bdi>strawberry-3.141</bdi></a> said in <a href="/post/18641">Help on Install</a>:</p>
<p dir="auto">cd ~/MagicMirror/config<br />
Should I try and re-install Magic Mirror?</p>
]]></description><link>https://forum.magicmirror.builders/post/18643</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/18643</guid><dc:creator><![CDATA[hartattack]]></dc:creator><pubDate>Sat, 01 Apr 2017 20:57:53 GMT</pubDate></item><item><title><![CDATA[Reply to [SOLVED] Help on Install on Sat, 01 Apr 2017 20:50:45 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/strawberry-3.141" aria-label="Profile: strawberry-3.141">@<bdi>strawberry-3.141</bdi></a> said in <a href="/post/18641">Help on Install</a>:</p>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/hartattack" aria-label="Profile: hartattack">@<bdi>hartattack</bdi></a> did you try <code>cd ~/MagicMirror/config</code>?</p>
<p dir="auto">Yes, same result…</p>
]]></description><link>https://forum.magicmirror.builders/post/18642</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/18642</guid><dc:creator><![CDATA[hartattack]]></dc:creator><pubDate>Sat, 01 Apr 2017 20:50:45 GMT</pubDate></item><item><title><![CDATA[Reply to [SOLVED] Help on Install on Sat, 01 Apr 2017 20:49:32 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/hartattack" aria-label="Profile: hartattack">@<bdi>hartattack</bdi></a> did you try <code>cd ~/MagicMirror/config</code>?</p>
]]></description><link>https://forum.magicmirror.builders/post/18641</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/18641</guid><dc:creator><![CDATA[strawberry 3.141]]></dc:creator><pubDate>Sat, 01 Apr 2017 20:49:32 GMT</pubDate></item></channel></rss>
