<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[After upgrade (v2.1.1) multiple calendars not displaying]]></title><description><![CDATA[<p dir="auto">I have two calendars which would display fine before the update.  After the update only the 2nd calendar displays.  Has anyone else seen this?</p>
<p dir="auto">Thanks, Dave</p>
<p dir="auto">{<br />
module: ‘calendar’,<br />
header: ‘Calendar’,<br />
position: ‘top_left’,<br />
config: {<br />
colored: true,<br />
calendars: [<br />
{<br />
url: ‘<a href="https://calendar.google.com/calendar/ical/.../basic.ics" target="_blank" rel="noopener noreferrer nofollow ugc">https://calendar.google.com/calendar/ical/.../basic.ics</a>’,<br />
color: ‘#f70000’<br />
},</p>
<pre><code>           	 {
                   	 url: 'https://calendar.google.com/calendar/ical/.../basic.ics',
            	color: '#04f448'
<p dir="auto">},</p>
]]></description><link>https://forum.magicmirror.builders/topic/2221/after-upgrade-v2-1-1-multiple-calendars-not-displaying</link><generator>RSS for Node</generator><lastBuildDate>Fri, 04 Sep 2026 20:37:38 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/2221.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 03 Apr 2017 22:03:38 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to After upgrade (v2.1.1) multiple calendars not displaying on Sun, 21 Jan 2018 19:50:03 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mitch1138" aria-label="Profile: Mitch1138">@<bdi>Mitch1138</bdi></a> said in <a href="/post/33133">After upgrade (v2.1.1) multiple calendars not displaying</a>:</p>
<p dir="auto">Edit this file:<br />
/home/pi/MagicMirror/node_modules/rrule-alt/lib/rrule.js</p>
<ul>
<li>Go to line 56 or search for the first occurance of “ORDINAL_BASE” and change this line:<br />
ORDINAL_BASE: new Date(1970, 0, 1),  ORDINAL_BASE: new Date(1000, 0, 1), (set it to a lower year like 1900, I used 1000)</li>
<li>Then restart your magic mirror</li>
</ul>
<p dir="auto">This resolved the same problem for me. Thanks!</p>
]]></description><link>https://forum.magicmirror.builders/post/34377</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/34377</guid><dc:creator><![CDATA[lavolp3]]></dc:creator><pubDate>Sun, 21 Jan 2018 19:50:03 GMT</pubDate></item><item><title><![CDATA[Reply to After upgrade (v2.1.1) multiple calendars not displaying on Mon, 01 Jan 2018 17:40:44 GMT]]></title><description><![CDATA[<p dir="auto">Just for info, after upgrading to v2.2.0, this issue resurfaced.  I tried replacing the ical scripts as described here: <a href="https://github.com/MichMich/MagicMirror/issues/839#issuecomment-298308733" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/MichMich/MagicMirror/issues/839#issuecomment-298308733</a><br />
but that didn’t work for me.    I used this recommendation which was posted on the forum and was overwritten when I updgraded:<br />
<ul>
</ul>
]]></description><link>https://forum.magicmirror.builders/post/33133</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/33133</guid><dc:creator><![CDATA[Mitch1138]]></dc:creator><pubDate>Mon, 01 Jan 2018 17:40:44 GMT</pubDate></item><item><title><![CDATA[Reply to After upgrade (v2.1.1) multiple calendars not displaying on Sun, 09 Apr 2017 01:44:36 GMT]]></title><description><![CDATA[<p dir="auto">I have the same issue with Google Calendar private url. I have two calendars running, a private url and a public url. The private url is not working but the public url DOES work strangely enough. I have two pi’s, one updated and one not. The pi that has not been updated still has that private url and it works, but the post update does not.</p>
]]></description><link>https://forum.magicmirror.builders/post/19281</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/19281</guid><dc:creator><![CDATA[Chadeus]]></dc:creator><pubDate>Sun, 09 Apr 2017 01:44:36 GMT</pubDate></item><item><title><![CDATA[Reply to After upgrade (v2.1.1) multiple calendars not displaying on Mon, 03 Apr 2017 22:38:35 GMT]]></title><description><![CDATA[<p dir="auto">It doesn’t look like it has anything to do with the position of the calendar.  If i switch the calendar positions it follows the calendar not the placement.</p>
]]></description><link>https://forum.magicmirror.builders/post/18865</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/18865</guid><dc:creator><![CDATA[yoda16]]></dc:creator><pubDate>Mon, 03 Apr 2017 22:38:35 GMT</pubDate></item><item><title><![CDATA[Reply to After upgrade (v2.1.1) multiple calendars not displaying on Mon, 03 Apr 2017 22:15:13 GMT]]></title><description><![CDATA[<p dir="auto">I am having the same issue after upgrading.</p>
]]></description><link>https://forum.magicmirror.builders/post/18861</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/18861</guid><dc:creator><![CDATA[yoda16]]></dc:creator><pubDate>Mon, 03 Apr 2017 22:15:13 GMT</pubDate></item></channel></rss>
