<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Pi-hole API presenter]]></title><description><![CDATA[<p dir="auto">I use Pi-hole on my mirror-pi. And they give a read data API.<br />
It would be nifty to be able to present the data on the mirror.</p>
<p dir="auto"><a href="https://github.com/pi-hole/pi-hole#api" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/pi-hole/pi-hole#api</a></p>
]]></description><link>https://forum.magicmirror.builders/topic/225/pi-hole-api-presenter</link><generator>RSS for Node</generator><lastBuildDate>Fri, 17 Jul 2026 17:04:32 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/225.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 12 Jun 2016 10:48:46 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Pi-hole API presenter on Thu, 28 May 2020 19:31:03 GMT]]></title><description><![CDATA[<p dir="auto">I was also having this issue where magic mirror was not showing status.</p>
<p dir="auto">i made silly mistake of copying the url which i access in browser but later i noticed that we need to copy the url with “api.php” in end of the address which fix the issue for me.</p>
]]></description><link>https://forum.magicmirror.builders/post/76033</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/76033</guid><dc:creator><![CDATA[HK]]></dc:creator><pubDate>Thu, 28 May 2020 19:31:03 GMT</pubDate></item><item><title><![CDATA[Reply to Pi-hole API presenter on Fri, 27 Apr 2018 13:53:03 GMT]]></title><description><![CDATA[<p dir="auto">Hi,</p>
<p dir="auto">Thanks for the tip barnosch, adding the hostname - for me it took adding the ip address of the magic mirror raspberry pi (where “<a href="http://your.hostname.com" target="_blank" rel="noopener noreferrer nofollow ugc">your.hostname.com</a>” is in the example line) - to that file on the pi-hole raspberry pi did the trick.</p>
<p dir="auto">However, I now have the same issue that others have reported of this module causing the mirror to freeze and/or crash after a few hours, maybe a day of uptime. I’ve disabled it and everything is working again, but does anyone know why this module causes this, or any likely fixes?</p>
<p dir="auto">Cheers</p>
]]></description><link>https://forum.magicmirror.builders/post/38997</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/38997</guid><dc:creator><![CDATA[nitram]]></dc:creator><pubDate>Fri, 27 Apr 2018 13:53:03 GMT</pubDate></item><item><title><![CDATA[Reply to Pi-hole API presenter on Fri, 23 Mar 2018 21:36:09 GMT]]></title><description><![CDATA[<p dir="auto">oh i forgot something…<br />
i also added this one at the pi server</p>
<pre><code>In file /var/www/html/admin/scripts/pi-hole/php/auth.php add your host in the array of allow hosts:
$AUTHORIZED_HOSTNAMES = array( $ipv4, $ipv6, str_replace(array("[","]"), array("",""), $_SERVER["SERVER_NAME"]), "pi.hole", "localhost", "your.hostname.com" );
]]></description><link>https://forum.magicmirror.builders/post/37359</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/37359</guid><dc:creator><![CDATA[barnosch]]></dc:creator><pubDate>Fri, 23 Mar 2018 21:36:09 GMT</pubDate></item><item><title><![CDATA[Reply to Pi-hole API presenter on Fri, 23 Mar 2018 22:17:04 GMT]]></title><description><![CDATA[<p dir="auto">got it work.<br />
Check if your clone from git is correct from up an lowercase…<br />
for me it was cloned to<br />
mmm-pihole-stats<br />
instead of<br />
MMM-pihole-stats<br />
also check that in the config style.</p>
<p dir="auto">it only showed something for me, after setting<br />
showSources: false,</p>
<p dir="auto">Maybe it helps someone</p>
<p dir="auto">changed also some stats to see the more interesting stuff<br />
<img src="/assets/uploads/files/1521843408505-6c29a650-1799-486e-98fa-b0b8434e6e8e-grafik.png" alt="0_1521843413987_6c29a650-1799-486e-98fa-b0b8434e6e8e-grafik.png" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.magicmirror.builders/post/37358</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/37358</guid><dc:creator><![CDATA[barnosch]]></dc:creator><pubDate>Fri, 23 Mar 2018 22:17:04 GMT</pubDate></item><item><title><![CDATA[Reply to Pi-hole API presenter on Sun, 25 Feb 2018 20:28:44 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/bmarofsky" aria-label="Profile: bmarofsky">@<bdi>bmarofsky</bdi></a> Hey guys… any luck on getting this to work?  I’m seeing the same issues and no errors in my logs.</p>
]]></description><link>https://forum.magicmirror.builders/post/36263</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/36263</guid><dc:creator><![CDATA[beeficecream]]></dc:creator><pubDate>Sun, 25 Feb 2018 20:28:44 GMT</pubDate></item><item><title><![CDATA[Reply to Pi-hole API presenter on Thu, 08 Feb 2018 03:23:13 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/vladoportos" aria-label="Profile: VladoPortos">@<bdi>VladoPortos</bdi></a> same here, but on a Windows PC if i go to the MM url, the pihole stat show perfectly.<br />
could it be a raspbian browser issue?</p>
]]></description><link>https://forum.magicmirror.builders/post/35373</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/35373</guid><dc:creator><![CDATA[bmarofsky]]></dc:creator><pubDate>Thu, 08 Feb 2018 03:23:13 GMT</pubDate></item><item><title><![CDATA[Reply to Pi-hole API presenter on Mon, 26 Dec 2016 21:32:08 GMT]]></title><description><![CDATA[<p dir="auto">Already exists here:<br />
<a href="https://github.com/sheyabernstein/MMM-pihole-stats" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/sheyabernstein/MMM-pihole-stats</a></p>
<p dir="auto">can’t get it to work though, its say Loading all the time :-/</p>
]]></description><link>https://forum.magicmirror.builders/post/9869</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/9869</guid><dc:creator><![CDATA[VladoPortos]]></dc:creator><pubDate>Mon, 26 Dec 2016 21:32:08 GMT</pubDate></item></channel></rss>
