<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[After reboot RPI no changes are saved?]]></title><description><![CDATA[<p dir="auto">Hi all.<br />
I got a strange issue.<br />
When i reboot (Sudo reboot) the RPI after changes in the config.js and saved the config file it gets back to the same status that i hade befor changes was made.<br />
Like if i delete a module from the config and save tha file it works fine but if i do a sudo reboot after this it is back to latest version and the module are back ?</p>
<p dir="auto">Aslo i got som issues with the MM freezes and nothing can be done just power off the RPI and restart it all.</p>
<p dir="auto">I dont run the latest MM 2.1.1 as i got problems updating.<br />
Is the best way to re install the full MM or is it a solution to this?</p>
<p dir="auto">Well hope that i can get some help if some one have hade the same kind of issue and solved it.</p>
]]></description><link>https://forum.magicmirror.builders/topic/2250/after-reboot-rpi-no-changes-are-saved</link><generator>RSS for Node</generator><lastBuildDate>Wed, 22 Apr 2026 01:59:28 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/2250.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 07 Apr 2017 04:58:07 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to After reboot RPI no changes are saved? on Mon, 16 Nov 2020 00:43:23 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/daenick" aria-label="Profile: daenick">@<bdi>daenick</bdi></a>   <a class="plugin-mentions-user plugin-mentions-a" href="/user/wizz" aria-label="Profile: wizz">@<bdi>wizz</bdi></a><br />
Mine was a bad mem card.  I created an image of it with win32Diskimager, Now I can just write the complete setup to a new card anytime I need to.  In my case it requires a lot of redoing the image since I cant leave well enough alone.  Constant changing things on my MagicMirror.</p>
]]></description><link>https://forum.magicmirror.builders/post/84715</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/84715</guid><dc:creator><![CDATA[Plainbroke 0]]></dc:creator><pubDate>Mon, 16 Nov 2020 00:43:23 GMT</pubDate></item><item><title><![CDATA[Reply to After reboot RPI no changes are saved? on Mon, 16 Nov 2020 00:39:43 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/plainbroke-0" aria-label="Profile: Plainbroke-0">@<bdi>Plainbroke-0</bdi></a> said in <a href="/post/81061">After reboot RPI no changes are saved?</a>:</p>
<p dir="auto">I am having this problem of any config changes do not stay after reboot.<br />
I am editing config.js and custom.css like I have for the last year or so.<br />
Any work around?</p>
<p dir="auto">Turned out to be a bad Mem Card must have exceeded the amount of rewrites it was capable of.<br />
Luckily I could just Make an image of the disk and transfer it to a brand new card now I am able to edit again.</p>
]]></description><link>https://forum.magicmirror.builders/post/84714</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/84714</guid><dc:creator><![CDATA[Plainbroke 0]]></dc:creator><pubDate>Mon, 16 Nov 2020 00:39:43 GMT</pubDate></item><item><title><![CDATA[Reply to After reboot RPI no changes are saved? on Wed, 02 Sep 2020 01:51:22 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/daenick" aria-label="Profile: daenick">@<bdi>daenick</bdi></a><br />
Did you ever find a fix?  I am now having exact same issue.</p>
]]></description><link>https://forum.magicmirror.builders/post/81106</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/81106</guid><dc:creator><![CDATA[Plainbroke 0]]></dc:creator><pubDate>Wed, 02 Sep 2020 01:51:22 GMT</pubDate></item><item><title><![CDATA[Reply to After reboot RPI no changes are saved? on Wed, 02 Sep 2020 01:40:04 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/wizz" aria-label="Profile: wizz">@<bdi>wizz</bdi></a><br />
Did you ever find a fix for this problem… ?</p>
]]></description><link>https://forum.magicmirror.builders/post/81102</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/81102</guid><dc:creator><![CDATA[Plainbroke 0]]></dc:creator><pubDate>Wed, 02 Sep 2020 01:40:04 GMT</pubDate></item><item><title><![CDATA[Reply to After reboot RPI no changes are saved? on Wed, 02 Sep 2020 01:35:44 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/plainbroke-0" aria-label="Profile: Plainbroke-0">@<bdi>Plainbroke-0</bdi></a> ok, i have two instances installed for testing, and today was confused by a similar problem… changes I made didn’t take affect…</p>
<p dir="auto">I was editing the file in the wrong instance… took me about 15 minutes before I figured it out… so many files open in the editor it only showed the last part of the filename (config.js) not the path</p>
]]></description><link>https://forum.magicmirror.builders/post/81100</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/81100</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Wed, 02 Sep 2020 01:35:44 GMT</pubDate></item><item><title><![CDATA[Reply to After reboot RPI no changes are saved? on Wed, 02 Sep 2020 01:33:33 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a><br />
nope just one:</p>
<p dir="auto">id │ name               │ mode     │ ↺    │ status    │ cpu      │ memory   │<br />
├────┼────────────────────┼──────────┼──────<br />
│ 0  │ mm                 │ fork     │ 1    │ online    │ 0%       │ 2.4mb</p>
]]></description><link>https://forum.magicmirror.builders/post/81099</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/81099</guid><dc:creator><![CDATA[Plainbroke 0]]></dc:creator><pubDate>Wed, 02 Sep 2020 01:33:33 GMT</pubDate></item><item><title><![CDATA[Reply to After reboot RPI no changes are saved? on Wed, 02 Sep 2020 01:30:51 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/plainbroke-0" aria-label="Profile: Plainbroke-0">@<bdi>Plainbroke-0</bdi></a> are u accidentally running two instances</p>
<p dir="auto">pm2 status</p>
]]></description><link>https://forum.magicmirror.builders/post/81098</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/81098</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Wed, 02 Sep 2020 01:30:51 GMT</pubDate></item><item><title><![CDATA[Reply to After reboot RPI no changes are saved? on Wed, 02 Sep 2020 01:29:42 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a><br />
Magic Mirror on Pi4 2gb  version 2.12</p>
]]></description><link>https://forum.magicmirror.builders/post/81097</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/81097</guid><dc:creator><![CDATA[Plainbroke 0]]></dc:creator><pubDate>Wed, 02 Sep 2020 01:29:42 GMT</pubDate></item><item><title><![CDATA[Reply to After reboot RPI no changes are saved? on Wed, 02 Sep 2020 00:59:30 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/plainbroke-0" aria-label="Profile: Plainbroke-0">@<bdi>Plainbroke-0</bdi></a> are u using docker or MagicMirrorOS</p>
]]></description><link>https://forum.magicmirror.builders/post/81089</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/81089</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Wed, 02 Sep 2020 00:59:30 GMT</pubDate></item><item><title><![CDATA[Reply to After reboot RPI no changes are saved? on Wed, 02 Sep 2020 00:26:21 GMT]]></title><description><![CDATA[<p dir="auto">Having the same issue,  if I  “sudo reboot”  or  “sudo shutdown now -r”  I loose the changes in my config.js and my custom.css they will not save for some reason.  Problem JUST started Monday.<br />
Anyone have a solution?</p>
]]></description><link>https://forum.magicmirror.builders/post/81087</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/81087</guid><dc:creator><![CDATA[Plainbroke 0]]></dc:creator><pubDate>Wed, 02 Sep 2020 00:26:21 GMT</pubDate></item><item><title><![CDATA[Reply to After reboot RPI no changes are saved? on Tue, 01 Sep 2020 18:03:06 GMT]]></title><description><![CDATA[<p dir="auto">I am having this problem of any config changes do not stay after reboot.<br />
]]></description><link>https://forum.magicmirror.builders/post/81061</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/81061</guid><dc:creator><![CDATA[Plainbroke 0]]></dc:creator><pubDate>Tue, 01 Sep 2020 18:03:06 GMT</pubDate></item><item><title><![CDATA[Reply to After reboot RPI no changes are saved? on Sat, 13 Jun 2020 14:25:36 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/blackmirror" aria-label="Profile: Blackmirror">@<bdi>Blackmirror</bdi></a> i would try sudo shutdown now -r (r=reboot)</p>
<p dir="auto">I have worried about sudo reboot not saving files, but it has never happened to me… (on 8 different systems with MM running)</p>
]]></description><link>https://forum.magicmirror.builders/post/77019</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/77019</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sat, 13 Jun 2020 14:25:36 GMT</pubDate></item><item><title><![CDATA[Reply to After reboot RPI no changes are saved? on Sat, 13 Jun 2020 14:03:47 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/wizz" aria-label="Profile: wizz">@<bdi>wizz</bdi></a><br />
Have you found a solution?</p>
<p dir="auto">I have the same problem now.</p>
]]></description><link>https://forum.magicmirror.builders/post/77018</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/77018</guid><dc:creator><![CDATA[Blackmirror]]></dc:creator><pubDate>Sat, 13 Jun 2020 14:03:47 GMT</pubDate></item><item><title><![CDATA[Reply to After reboot RPI no changes are saved? on Fri, 07 Apr 2017 18:28:04 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/wizz" aria-label="Profile: wizz">@<bdi>wizz</bdi></a> I have the same problema. When sudo reboot my config.txt is lost. I have to edit it everytime I shutdown too.</p>
]]></description><link>https://forum.magicmirror.builders/post/19206</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/19206</guid><dc:creator><![CDATA[daenick]]></dc:creator><pubDate>Fri, 07 Apr 2017 18:28:04 GMT</pubDate></item></channel></rss>
