<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Autostart Issue and No Interface]]></title><description><![CDATA[<p dir="auto">Hello,</p>
<p dir="auto">I am trying to build my MagicMirror and I am having trouble getting the Raspberry Pi 2 Model B set up.</p>
<p dir="auto">I used the automatic installation and followed the instructions but I can’t get the interface started somehow.</p>
<p dir="auto">I get this error message:</p>
<pre><code>MagicMirror installation successful!
&gt; magicmirror@2.1.1 start /home/pi/MagicMirror
&gt; sh run-start.sh
npm ERR! Linux 4.4.50-v7+
npm ERR! argv "/usr/bin/nodejs" "/usr/bin/npm" "start"
npm ERR! node v6.10.2
npm ERR! npm  v3.10.10
npm ERR! code ELIFECYCLE
npm ERR! magicmirror@2.1.1 start: `sh run-start.sh`
npm ERR! Exit status 1
npm ERR!
npm ERR! Failed at the magicmirror@2.1.1 start script 'sh run-start.sh'.
npm ERR! If you do, this is most likely a problem with the magicmirror package,
npm ERR! not with npm itself.
npm ERR!     sh run-start.sh
npm ERR!     npm bugs magicmirror
npm ERR! Or if that isn't available, you can get their info via:
npm ERR!     npm owner ls magicmirror
<p dir="auto">When I reboot the Pi, it gets me to the login screen. And when I want to start it manually, the error message above is shown.</p>
<p dir="auto">Thank you in advance for helping me.</p>
<p dir="auto">Dapandam</p>
]]></description><link>https://forum.magicmirror.builders/topic/2256/autostart-issue-and-no-interface</link><generator>RSS for Node</generator><lastBuildDate>Tue, 18 Aug 2026 09:12:46 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/2256.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 08 Apr 2017 01:21:41 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Autostart Issue and No Interface on Sat, 08 Apr 2017 12:45:36 GMT]]></title><description><![CDATA[<p dir="auto">I think I found the problem ! It was a problem with Electron. I followed some advice giving in this thread: <a href="https://github.com/MichMich/MagicMirror/issues/145" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/MichMich/MagicMirror/issues/145</a></p>
<p dir="auto">“running “sudo npm install electron” (after the error message) in the terminal on the gui it worked starting in the terminal on the gui.”</p>
]]></description><link>https://forum.magicmirror.builders/post/19247</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/19247</guid><dc:creator><![CDATA[dapandam]]></dc:creator><pubDate>Sat, 08 Apr 2017 12:45:36 GMT</pubDate></item><item><title><![CDATA[Reply to Autostart Issue and No Interface on Sat, 08 Apr 2017 11:18:33 GMT]]></title><description><![CDATA[<pre><code>
npm WARN prefer global coffee-script@1.10.0 should be installed with -g
npm WARN prefer global jsonlint@1.6.2 should be installed with -g
npm WARN prefer global colorguard@1.2.0 should be installed with -g
<p dir="auto">I have also this code showing up when I want to install MagicMirror, thoughts ?</p>
]]></description><link>https://forum.magicmirror.builders/post/19245</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/19245</guid><dc:creator><![CDATA[dapandam]]></dc:creator><pubDate>Sat, 08 Apr 2017 11:18:33 GMT</pubDate></item><item><title><![CDATA[Reply to Autostart Issue and No Interface on Sat, 08 Apr 2017 08:47:24 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/hartattack" aria-label="Profile: hartattack">@<bdi>hartattack</bdi></a> yes I have, I even launched the automatic installation couple times to be sure.</p>
<pre><code>
Check current Node installation ...
Node currently installed. Checking version number.
Minimum Node version: v5.1.0
Installed Node version: v6.10.2
No Node.js upgrade nessecery.
It seems like MagicMirror is already installed.
To prevent overwriting, the installer will be aborted.
Please rename the ~/MagicMirror folder and try again.
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/gshimself" aria-label="Profile: gshimself">@<bdi>gshimself</bdi></a> thanks for your help, here is the code i got from the debug log</p>
<pre><code>0 info it worked if it ends with ok
1 verbose cli [ '/usr/bin/nodejs', '/usr/bin/npm', 'start' ]
2 info using npm@3.10.10
3 info using node@v6.10.2
5 info lifecycle magicmirror@2.1.1~prestart: magicmirror@2.1.1
6 silly lifecycle magicmirror@2.1.1~prestart: no script for prestart, continuing
7 info lifecycle magicmirror@2.1.1~start: magicmirror@2.1.1
8 verbose lifecycle magicmirror@2.1.1~start: unsafe-perm in lifecycle true
9 verbose lifecycle magicmirror@2.1.1~start: PATH: /usr/lib/node_modules/npm/bin/node-gyp-bin:/home/pi/MagicMirror/node_modules/.bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/local/games:/usr/games
10 verbose lifecycle magicmirror@2.1.1~start: CWD: /home/pi/MagicMirror
11 silly lifecycle magicmirror@2.1.1~start: Args: [ '-c', 'sh run-start.sh' ]
12 silly lifecycle magicmirror@2.1.1~start: Returned: code: 1  signal: null
13 info lifecycle magicmirror@2.1.1~start: Failed to exec start script
14 verbose stack Error: magicmirror@2.1.1 start: `sh run-start.sh`
14 verbose stack Exit status 1
14 verbose stack     at EventEmitter. (/usr/lib/node_modules/npm/lib/utils/lifecycle.js:255:16)
14 verbose stack     at emitTwo (events.js:106:13)
14 verbose stack     at EventEmitter.emit (events.js:191:7)
14 verbose stack     at ChildProcess. (/usr/lib/node_modules/npm/lib/utils/spawn.js:40:14)
14 verbose stack     at ChildProcess.emit (events.js:191:7)
14 verbose stack     at maybeClose (internal/child_process.js:886:16)
14 verbose stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:226:5)
15 verbose pkgid magicmirror@2.1.1
16 verbose cwd /home/pi/MagicMirror
17 error Linux 4.4.50-v7+
18 error argv "/usr/bin/nodejs" "/usr/bin/npm" "start"
19 error node v6.10.2
20 error npm  v3.10.10
21 error code ELIFECYCLE
22 error magicmirror@2.1.1 start: `sh run-start.sh`
22 error Exit status 1
23 error Failed at the magicmirror@2.1.1 start script 'sh run-start.sh'.
23 error Make sure you have the latest version of node.js and npm installed.
23 error If you do, this is most likely a problem with the magicmirror package,
23 error not with npm itself.
23 error Tell the author that this fails on your system:
23 error     sh run-start.sh
23 error You can get information on how to open an issue for this project with:
23 error     npm bugs magicmirror
23 error Or if that isn't available, you can get their info via:
23 error     npm owner ls magicmirror
23 error There is likely additional logging output above.
24 verbose exit [ 1, true ]
]]></description><link>https://forum.magicmirror.builders/post/19239</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/19239</guid><dc:creator><![CDATA[dapandam]]></dc:creator><pubDate>Sat, 08 Apr 2017 08:47:24 GMT</pubDate></item><item><title><![CDATA[Reply to Autostart Issue and No Interface on Sat, 08 Apr 2017 06:24:03 GMT]]></title><description><![CDATA[<p dir="auto">Hi. Can you do</p>
<p dir="auto">sudo cat /home/pi/MagicMirror/npm-debug.log</p>
<p dir="auto">and post some of that code?</p>
]]></description><link>https://forum.magicmirror.builders/post/19234</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/19234</guid><dc:creator><![CDATA[gshimself]]></dc:creator><pubDate>Sat, 08 Apr 2017 06:24:03 GMT</pubDate></item><item><title><![CDATA[Reply to Autostart Issue and No Interface on Sat, 08 Apr 2017 05:08:05 GMT]]></title><description><![CDATA[<p dir="auto">Did you install the latest version of node.js?</p>
]]></description><link>https://forum.magicmirror.builders/post/19232</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/19232</guid><dc:creator><![CDATA[hartattack]]></dc:creator><pubDate>Sat, 08 Apr 2017 05:08:05 GMT</pubDate></item></channel></rss>
