<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Formatting the MMM-EFA Module]]></title><description><![CDATA[<p dir="auto">There are a few who want to use the MMM-EFA Module (a local Transport departure Monitor, including real-time data)<br />
<a href="https://github.com/Dom1n1c/MMM-EFA-departures" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/Dom1n1c/MMM-EFA-departures</a></p>
<p dir="auto">Maybe there is someone who can help me to avoid the overwritten section:<br />
<img src="/assets/uploads/files/1491654592768-1488184566581-efa.png" alt="0_1491654593772_1488184566581-efa.png" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.magicmirror.builders/topic/2259/formatting-the-mmm-efa-module</link><generator>RSS for Node</generator><lastBuildDate>Mon, 20 Apr 2026 00:41:13 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/2259.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 08 Apr 2017 12:31:27 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Formatting the MMM-EFA Module on Sat, 15 Jul 2017 17:46:20 GMT]]></title><description><![CDATA[<p dir="auto">Hi all.<br />
MVV-EFA does not work iin the magic Mirror. (after hours still “loading”…)<br />
<a href="http://efa.vrr.de/standard/XSLT_DM_REQUEST" target="_blank" rel="noopener noreferrer nofollow ugc">http://efa.vrr.de/standard/XSLT_DM_REQUEST</a> does work with stopIDs from MVV-Area, and sorry Hawking, i don’t know the ID of your station. My one is a “S-Bahn”-Station and its stopID was in the VRR-List.</p>
<p dir="auto">Thanks Dominic for the Module and i hope, somebody still finds a direct way to the MVV München with all Stop- and Line-IDs.</p>
]]></description><link>https://forum.magicmirror.builders/post/25368</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/25368</guid><dc:creator><![CDATA[wegar]]></dc:creator><pubDate>Sat, 15 Jul 2017 17:46:20 GMT</pubDate></item><item><title><![CDATA[Reply to Formatting the MMM-EFA Module on Thu, 11 May 2017 22:47:25 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/dom1n1c" aria-label="Profile: Dom1n1c">@<bdi>Dom1n1c</bdi></a><br />
But I don’t find smaller (bus) stations like the “Friedrich-Hebbel-Straße” I mentioned before in the VRR<br />
<a href="http://efa.vrr.de/standard/XSLT_DM_REQUEST" target="_blank" rel="noopener noreferrer nofollow ugc">http://efa.vrr.de/standard/XSLT_DM_REQUEST</a><br />
at all. So I don’t know how I could even use it for static departure times.</p>
<p dir="auto">You mentioned 80000760, however the same number was posted by me before for  “München Marienplatz”. Did you maybe mixed something or misunderstood me?</p>
]]></description><link>https://forum.magicmirror.builders/post/21504</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/21504</guid><dc:creator><![CDATA[Hawking]]></dc:creator><pubDate>Thu, 11 May 2017 22:47:25 GMT</pubDate></item><item><title><![CDATA[Reply to Formatting the MMM-EFA Module on Thu, 11 May 2017 20:35:56 GMT]]></title><description><![CDATA[<p dir="auto">Maybe you can get in touch with the MVV developers. They might be able to tell you, which api endpoint you can use.<br />
Using the vrr endpoint might be a workaround since vrr and mvv worked together with mentz in the past.<br />
Regarding the mvv, there were some changes on the webpage. Changing the URL parameter to the one used by vrr will redirect you to the ‘mobile’ homepage of the mvv.<br />
Regarding the invisible stop ID:<br />
mvv seems to work with cookies, so you are not able to find your stop id, since the conversion is done in the background.<br />
I’m not sure if the mvv offers real time data, so if you are happy with the scheduled departures, you can consider using the vrr endpoint.</p>
]]></description><link>https://forum.magicmirror.builders/post/21497</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/21497</guid><dc:creator><![CDATA[Dom1n1c]]></dc:creator><pubDate>Thu, 11 May 2017 20:35:56 GMT</pubDate></item><item><title><![CDATA[Reply to Formatting the MMM-EFA Module on Thu, 11 May 2017 20:27:25 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/dom1n1c" aria-label="Profile: Dom1n1c">@<bdi>Dom1n1c</bdi></a><br />
thanks for your quick reply.</p>
<p dir="auto">I took the efaUrl from the description of<br />
<a href="https://github.com/Dom1n1c/MMM-EFA-departures" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/Dom1n1c/MMM-EFA-departures</a><br />
If it is not working (I am not able to tell) you might update the link.</p>
<p dir="auto">Via <a href="http://efa-alt.mvv-muenchen.de/mvv/XSLT_DM_REQUEST" target="_blank" rel="noopener noreferrer nofollow ugc">http://efa-alt.mvv-muenchen.de/mvv/XSLT_DM_REQUEST</a> I can find the " Friedrich-Hebbel-Straße" bus stop. However, in the source code I don’t see a valid stop id.</p>
]]></description><link>https://forum.magicmirror.builders/post/21496</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/21496</guid><dc:creator><![CDATA[Hawking]]></dc:creator><pubDate>Thu, 11 May 2017 20:27:25 GMT</pubDate></item><item><title><![CDATA[Reply to Formatting the MMM-EFA Module on Thu, 11 May 2017 04:59:25 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/hawking" aria-label="Profile: Hawking">@<bdi>Hawking</bdi></a> I Think, that the API Endpoint is not correct.<br />
You can try using:<br />
<a href="http://efa.mvv-muenchen.de/mobile/XSLT_DM_REQUEST" target="_blank" rel="noopener noreferrer nofollow ugc">http://efa.mvv-muenchen.de/mobile/XSLT_DM_REQUEST</a> //seems to be wrong<br />
<a href="http://efa-alt.mvv-muenchen.de/mvv/XSLT_DM_REQUEST" target="_blank" rel="noopener noreferrer nofollow ugc">http://efa-alt.mvv-muenchen.de/mvv/XSLT_DM_REQUEST</a></p>
<p dir="auto">I can find the following stop-ID and line-IDs when using the VRR endpoint.</p>
<pre><code>80000760
<p dir="auto">lines:</p>
<pre><code>DDB:92M01: :H
DDB:92M01: :R
DDB:92M02: :H
DDB:92M02: :R
DDB:92M03: :H
DDB:92M03: :R
DDB:92M04: :H
DDB:92M04: :R
DDB:92M06: :H
DDB:92M06: :R
DDB:92M08: :H
DDB:92M08: :R
]]></description><link>https://forum.magicmirror.builders/post/21444</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/21444</guid><dc:creator><![CDATA[Dom1n1c]]></dc:creator><pubDate>Thu, 11 May 2017 04:59:25 GMT</pubDate></item><item><title><![CDATA[Reply to Formatting the MMM-EFA Module on Wed, 10 May 2017 21:45:55 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/dom1n1c" aria-label="Profile: Dom1n1c">@<bdi>Dom1n1c</bdi></a><br />
thanks for your reply.</p>
<p dir="auto">If I look at <a href="http://efa.vrr.de/standard/XSLT_DM_REQUEST" target="_blank" rel="noopener noreferrer nofollow ugc">http://efa.vrr.de/standard/XSLT_DM_REQUEST</a> for trains departing from “München Marienplatz” I find in the code<br />
<code>nameInfo_dm=80000760</code><br />
which works fine as a stop ID.</p>
<p dir="auto">However, if I e.g. search for München - Friedrich-Hebbel-Straße as a stop it is not found at <a href="http://efa.vrr.de/standard/XSLT_DM_REQUEST" target="_blank" rel="noopener noreferrer nofollow ugc">http://efa.vrr.de/standard/XSLT_DM_REQUEST</a> (as it is only a bus stop?).</p>
<p dir="auto">If I look via<br />
<a href="http://efa.mvv-muenchen.de/mobile/XSLT_DM_REQUEST" target="_blank" rel="noopener noreferrer nofollow ugc">http://efa.mvv-muenchen.de/mobile/XSLT_DM_REQUEST</a><br />
I find the Friedrich-Hebbel-Straße stop. However, I don’t find a valid ID in the source code.</p>
<p dir="auto">Is this station simply to small or is there a way to also include it in the EFA Module?</p>
<p dir="auto">Thanks for your support!</p>
]]></description><link>https://forum.magicmirror.builders/post/21424</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/21424</guid><dc:creator><![CDATA[Hawking]]></dc:creator><pubDate>Wed, 10 May 2017 21:45:55 GMT</pubDate></item><item><title><![CDATA[Reply to Formatting the MMM-EFA Module on Wed, 10 May 2017 12:13:22 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/hawking" aria-label="Profile: Hawking">@<bdi>Hawking</bdi></a> I run the EFA departure monitor in the browser and then have a look in the source, this could easily be done with chrome (view-source:url)</p>
<p dir="auto">Then you have the station and line ids, without running the crawler.</p>
]]></description><link>https://forum.magicmirror.builders/post/21387</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/21387</guid><dc:creator><![CDATA[Dom1n1c]]></dc:creator><pubDate>Wed, 10 May 2017 12:13:22 GMT</pubDate></item><item><title><![CDATA[Reply to Formatting the MMM-EFA Module on Fri, 14 Apr 2017 23:31:00 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/dom1n1c" aria-label="Profile: Dom1n1c">@<bdi>Dom1n1c</bdi></a><br />
thanks for taking care about the broken MMM-EFA module. At the moment I’ve some more general problems  using MMM but I’m looking forward to use the module.<br />
I already have one question: How do I get the station ID?<br />
On github you link to <a href="http://www.eg-blog.de/?p=822" target="_blank" rel="noopener noreferrer nofollow ugc">http://www.eg-blog.de/?p=822</a> however, their dropbox files seem to be down (and anyway incomplete). I think it makes little sense if we now all start scanning the complete number range?<br />
Is there a way I can extract the number e.g. from the <a href="http://efa.mvv-muenchen.de/mobile/XSLT_DM_REQUEST" target="_blank" rel="noopener noreferrer nofollow ugc">http://efa.mvv-muenchen.de/mobile/XSLT_DM_REQUEST</a> run?</p>
]]></description><link>https://forum.magicmirror.builders/post/19673</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/19673</guid><dc:creator><![CDATA[Hawking]]></dc:creator><pubDate>Fri, 14 Apr 2017 23:31:00 GMT</pubDate></item><item><title><![CDATA[Reply to Formatting the MMM-EFA Module on Sat, 08 Apr 2017 19:25:17 GMT]]></title><description><![CDATA[<p dir="auto">Thanks to <a class="plugin-mentions-user plugin-mentions-a" href="/user/joda92" aria-label="Profile: joda92">@<bdi>joda92</bdi></a><br />
Now the indentation works as expected.</p>
<p dir="auto">Feel free to pull the Module from GitHub:<br />
]]></description><link>https://forum.magicmirror.builders/post/19255</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/19255</guid><dc:creator><![CDATA[Dom1n1c]]></dc:creator><pubDate>Sat, 08 Apr 2017 19:25:17 GMT</pubDate></item></channel></rss>
