<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Calendar Holiday issue]]></title><description><![CDATA[<p dir="auto">Hi,</p>
<p dir="auto">i have an issue with the screening of the holidays. the calendar module show them 1 day before there are really are.<br />
has someone an idea or the same troubleshoot ?!<br />
On the picture you can see the German holidays “Karfreitag” which is on the next Friday. In my case it’s on Thursday in 4 days.<img src="/assets/uploads/files/1491739317176-bildschirmfoto-2017-04-09-um-13.59.36.jpeg" alt="0_1491739315966_Bildschirmfoto 2017-04-09 um 13.59.36.jpg" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.magicmirror.builders/topic/2265/calendar-holiday-issue</link><generator>RSS for Node</generator><lastBuildDate>Sun, 12 Jul 2026 17:40:41 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/2265.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 09 Apr 2017 12:02:13 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Calendar Holiday issue on Mon, 10 Apr 2017 20:03:28 GMT]]></title><description><![CDATA[<p dir="auto">Download the calender, nothing to found.<br />
Then i import the calender to my office outlook and every entry is correct.<br />
So i think in my calendar configuration is something wrong…</p>
]]></description><link>https://forum.magicmirror.builders/post/19439</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/19439</guid><dc:creator><![CDATA[christophehlert]]></dc:creator><pubDate>Mon, 10 Apr 2017 20:03:28 GMT</pubDate></item><item><title><![CDATA[Reply to Calendar Holiday issue on Mon, 10 Apr 2017 13:23:17 GMT]]></title><description><![CDATA[<p dir="auto">first you should controll the date and time on your raspberyy pi, not only the TimeZone.<br />
You should download your calender and control, if the Dates are correctly stored there or if is there a time difference.<br />
When everything is right, I cannot help you.</p>
]]></description><link>https://forum.magicmirror.builders/post/19397</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/19397</guid><dc:creator><![CDATA[Peter_van_Evert]]></dc:creator><pubDate>Mon, 10 Apr 2017 13:23:17 GMT</pubDate></item><item><title><![CDATA[Reply to Calendar Holiday issue on Mon, 10 Apr 2017 12:43:36 GMT]]></title><description><![CDATA[<p dir="auto">ok, this morning i looked on my mirror, everthing was correct.<br />
I take a look again past 10 minutes from now, the entries are wrong again ?!?!<br />
the holiday entries coming from a provider called <a href="http://www.webcal.fi" target="_blank" rel="noopener noreferrer nofollow ugc">http://www.webcal.fi</a> …<br />
i take the url and paste it in a new calendar config line. Here i have no possibilities to change anything at the timezone settings. and the Page is for German holidays. What can it be !?</p>
]]></description><link>https://forum.magicmirror.builders/post/19389</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/19389</guid><dc:creator><![CDATA[christophehlert]]></dc:creator><pubDate>Mon, 10 Apr 2017 12:43:36 GMT</pubDate></item><item><title><![CDATA[Reply to Calendar Holiday issue on Mon, 10 Apr 2017 12:36:32 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/peter_van_evert" aria-label="Profile: Peter_van_Evert">@<bdi>Peter_van_Evert</bdi></a></p>
<p dir="auto">The Pi has the TimeZone Berlin. That is correct.</p>
]]></description><link>https://forum.magicmirror.builders/post/19388</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/19388</guid><dc:creator><![CDATA[christophehlert]]></dc:creator><pubDate>Mon, 10 Apr 2017 12:36:32 GMT</pubDate></item><item><title><![CDATA[Reply to Calendar Holiday issue on Mon, 10 Apr 2017 06:09:02 GMT]]></title><description><![CDATA[<p dir="auto">which time and date shows your raspberry pi ?</p>
]]></description><link>https://forum.magicmirror.builders/post/19373</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/19373</guid><dc:creator><![CDATA[Peter_van_Evert]]></dc:creator><pubDate>Mon, 10 Apr 2017 06:09:02 GMT</pubDate></item></channel></rss>
