<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Problem with my pir sensor]]></title><description><![CDATA[<p dir="auto">Hi</p>
<p dir="auto">I have a pir installed but unfortunately the screen never goes into standby,</p>
<p dir="auto">The module MMMpirSsensor is nevertheless well installed I use the output gpio 22<br />
If it comes from the pir or elsewhere?<br />
thank you in advance</p>
]]></description><link>https://forum.magicmirror.builders/topic/2266/problem-with-my-pir-sensor</link><generator>RSS for Node</generator><lastBuildDate>Wed, 20 May 2026 07:53:03 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/2266.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 09 Apr 2017 16:24:44 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Problem with my pir sensor on Sun, 30 Apr 2017 14:48:41 GMT]]></title><description><![CDATA[<p dir="auto">Hi,</p>
<p dir="auto">I tested my pir with my multimetre I just disconnected the output and testing directly on the pine I saw that my output always remained high.<br />
I changed my pir now all works perfectly</p>
]]></description><link>https://forum.magicmirror.builders/post/20806</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/20806</guid><dc:creator><![CDATA[Fonfon]]></dc:creator><pubDate>Sun, 30 Apr 2017 14:48:41 GMT</pubDate></item><item><title><![CDATA[Reply to Problem with my pir sensor on Sun, 30 Apr 2017 10:25:00 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/fonfon" aria-label="Profile: Fonfon">@<bdi>Fonfon</bdi></a> I’m in the same case of you, my screen don’t turn off.<br />
I was wondering if my PIR wasn’t broken but I wanted to check it before.</p>
<p dir="auto">So before changing your PIR you can test it by a simple python script. I found this (in french) : <a href="http://mycoolpizza.blogspot.fr/2013/05/raspberry-pi-utiliser-un-capteur-de_29.html?m=1" target="_blank" rel="noopener noreferrer nofollow ugc">http://mycoolpizza.blogspot.fr/2013/05/raspberry-pi-utiliser-un-capteur-de_29.html?m=1</a></p>
]]></description><link>https://forum.magicmirror.builders/post/20786</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/20786</guid><dc:creator><![CDATA[maxtone66]]></dc:creator><pubDate>Sun, 30 Apr 2017 10:25:00 GMT</pubDate></item><item><title><![CDATA[Reply to Problem with my pir sensor on Sun, 16 Apr 2017 14:49:58 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/fonfon" aria-label="Profile: Fonfon">@<bdi>Fonfon</bdi></a> Did you try to adjust the resistance of the PIR?</p>
]]></description><link>https://forum.magicmirror.builders/post/19740</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/19740</guid><dc:creator><![CDATA[bberg115]]></dc:creator><pubDate>Sun, 16 Apr 2017 14:49:58 GMT</pubDate></item><item><title><![CDATA[Reply to Problem with my pir sensor on Mon, 10 Apr 2017 15:57:35 GMT]]></title><description><![CDATA[<p dir="auto">HI</p>
<p dir="auto">thanks for your answering i put a ferrite bead near gpio connector but my output 15 gpio 22 is always high<br />
so my screen is always turn on .<br />
i don’t why …<br />
Perhaps my pir is broken because the first time I plugged in I reversed the power supply…</p>
]]></description><link>https://forum.magicmirror.builders/post/19415</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/19415</guid><dc:creator><![CDATA[Fonfon]]></dc:creator><pubDate>Mon, 10 Apr 2017 15:57:35 GMT</pubDate></item><item><title><![CDATA[Reply to Problem with my pir sensor on Sun, 09 Apr 2017 17:12:38 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/fonfon" aria-label="Profile: Fonfon">@<bdi>Fonfon</bdi></a> I don’t have a PIR sensor for my Magic Mirror yet, but I was just reading yesterday about problems with the PIR and Raspberry Pi 3</p>
<p dir="auto">Apparently, the PIR gets interference from the Wireless chip on the Raspberry Pi 3 and it causes it to give bad readings, even the Adafruit site has a note about it:</p>
<p dir="auto"><a href="https://www.adafruit.com/product/189" target="_blank" rel="noopener noreferrer nofollow ugc">https://www.adafruit.com/product/189</a></p>
<p dir="auto">“PIR sensors and the Raspberry Pi 3 sometimes don’t get along - if you’re having false trigger reports, make sure the PIR Sensor is far away from the Pi 3”</p>
<p dir="auto">Here is another possible solution - this guy used some kind of interference blocker on the wire, check it out:</p>
<p dir="auto"><a href="https://helentronica.com/2016/01/11/magic-mirror-with-motion-detector/" target="_blank" rel="noopener noreferrer nofollow ugc">https://helentronica.com/2016/01/11/magic-mirror-with-motion-detector/</a></p>
]]></description><link>https://forum.magicmirror.builders/post/19326</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/19326</guid><dc:creator><![CDATA[rchase]]></dc:creator><pubDate>Sun, 09 Apr 2017 17:12:38 GMT</pubDate></item></channel></rss>
