<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Brightness]]></title><description><![CDATA[<p dir="auto">Hello,</p>
<p dir="auto">I don’t know if this is the correct place to discuss this, but here I go.</p>
<p dir="auto">There’s a way to increase brightness on the modules?</p>
<p dir="auto">Can this be done with css or something?</p>
<p dir="auto">Thanks!</p>
]]></description><link>https://forum.magicmirror.builders/topic/2280/brightness</link><generator>RSS for Node</generator><lastBuildDate>Fri, 17 Jul 2026 05:36:12 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/2280.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 11 Apr 2017 11:46:37 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Brightness on Wed, 12 Apr 2017 18:27:17 GMT]]></title><description><![CDATA[<p dir="auto">Thanks! I totally forgot the brightness control on MMM-Remote-Control, thank you <a class="plugin-mentions-user plugin-mentions-a" href="/user/anhalter42" aria-label="Profile: Anhalter42">@<bdi>Anhalter42</bdi></a></p>
]]></description><link>https://forum.magicmirror.builders/post/19561</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/19561</guid><dc:creator><![CDATA[daenick]]></dc:creator><pubDate>Wed, 12 Apr 2017 18:27:17 GMT</pubDate></item><item><title><![CDATA[Reply to Brightness on Wed, 12 Apr 2017 16:39:16 GMT]]></title><description><![CDATA[<p dir="auto">Have a look at <a href="https://github.com/Jopyth/MMM-Remote-Control" target="_blank" rel="noopener noreferrer nofollow ugc">MMM-Remote-Control</a>. With this you can increase/decrease the overall brightness.</p>
<p dir="auto">I didn’t implement it, but as far as I can see, it basically changes the <code>color</code> property of <code>body</code>, <code>.dimmed</code>, <code>.normal</code>, <code>.bright</code> and <code>header</code> in <code>main.css</code> using grayscale-values.<br />
Actually, it also uses an partially opaque overlay to imitate darker brightness values, but I guess, setting the <code>color</code> property itself or just using the existing module should be sufficient. (You can send notifications to MMM-Remote-Control to set the brightness at runtime)</p>
]]></description><link>https://forum.magicmirror.builders/post/19549</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/19549</guid><dc:creator><![CDATA[Anhalter42]]></dc:creator><pubDate>Wed, 12 Apr 2017 16:39:16 GMT</pubDate></item></channel></rss>
