<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Admin - Pin a &#x27;Usefull Terminal Commands&#x27; post?]]></title><description><![CDATA[[[topic:post-is-deleted]]]]></description><link>https://forum.magicmirror.builders/topic/2317/admin-pin-a-usefull-terminal-commands-post</link><generator>RSS for Node</generator><lastBuildDate>Wed, 10 Jun 2026 18:31:02 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/2317.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 14 Apr 2017 19:42:18 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Admin - Pin a &#x27;Usefull Terminal Commands&#x27; post? on Fri, 21 Apr 2017 09:36:14 GMT]]></title><description><![CDATA[<p dir="auto">All the <code>sudo apt-get whatever</code> command can be replace by <code>sudo apt whatever</code> apt does the same as apt-get but provide a progress bar in addition.</p>
<p dir="auto">Also you put two point 14. And the first one is missing a step and there is a a space missing.<br />
<code>cd ~/MagicMirror</code> should be <code>cd ~/MagicMirror/modules</code> and <code>~MagicMirror/modules/ $ gitclone https://github.com/NAMEOFMODULE</code> should become <code>~MagicMirror/modules/ $ git clone https://github.com/NAMEOFMODULE</code><br />
But maybe instead of <a href="https://github.com/NAMEOFMODULE" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/NAMEOFMODULE</a> maybe it would be easier to say moduleUrl or something ? because the url doesn’t onlt content the url of the module but also who did it. So if somebody who never used git before try to write <a href="https://github.com/MMM-AlexaPi" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/MMM-AlexaPi</a> for example, it will fail. because part of the url is missing.</p>
]]></description><link>https://forum.magicmirror.builders/post/20077</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/20077</guid><dc:creator><![CDATA[romain]]></dc:creator><pubDate>Fri, 21 Apr 2017 09:36:14 GMT</pubDate></item><item><title><![CDATA[Reply to Admin - Pin a &#x27;Usefull Terminal Commands&#x27; post? on Wed, 19 Apr 2017 11:29:07 GMT]]></title><description><![CDATA[<p dir="auto">When this first came out I installed it blindly… I had NO idea what I was doing.  I was getting all kinds of errors and I would take one at a time, go out on the internet and read what the error was, what it meant and how to fix it.   Then I would fix it.  I did this until I got MM working.</p>
<p dir="auto">Like any other ‘project’ the person assumes the responsibility to have some knowledge or the ability to go find that knowledge.  The people that created this understood what it all meant and yes newbies may not but they must also be prepared to learn to expand their own knowledge base.</p>
]]></description><link>https://forum.magicmirror.builders/post/19945</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/19945</guid><dc:creator><![CDATA[cowboysdude]]></dc:creator><pubDate>Wed, 19 Apr 2017 11:29:07 GMT</pubDate></item><item><title><![CDATA[Reply to Admin - Pin a &#x27;Usefull Terminal Commands&#x27; post? on Tue, 18 Apr 2017 21:47:30 GMT]]></title><description><![CDATA[<p dir="auto">Alot of these aren’t just MM terminal commands they are Linux commands and go out and read how to run Linux and it will clear most of that right up for you ;)</p>
]]></description><link>https://forum.magicmirror.builders/post/19916</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/19916</guid><dc:creator><![CDATA[cowboysdude]]></dc:creator><pubDate>Tue, 18 Apr 2017 21:47:30 GMT</pubDate></item><item><title><![CDATA[Reply to Admin - Pin a &#x27;Usefull Terminal Commands&#x27; post? on Tue, 18 Apr 2017 17:17:26 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/johnnyboy" aria-label="Profile: johnnyboy">@<bdi>johnnyboy</bdi></a> Thanks for this one ;-)</p>
]]></description><link>https://forum.magicmirror.builders/post/19887</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/19887</guid><dc:creator><![CDATA[michael24h]]></dc:creator><pubDate>Tue, 18 Apr 2017 17:17:26 GMT</pubDate></item></channel></rss>
