<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[MMM-PIR-SENSOR Module GPIO-Settings]]></title><description><![CDATA[<p dir="auto">Hello,<br />
finally got my MagicMirror running (will add some photos in the next few days) - next step is to activate the MMM-PIR-Module - but it seems that there is a small problem with my setup.</p>
<p dir="auto">As I did not want to see any electronics with my mirror on the wall I needed to hide the PIR Sensor. I decided not to use a PIR Sensor. Instead I got a microwave motion detector that is mounted behind the glass. It works perfectly through the glass regarding to the indicator LED on the board.</p>
<p dir="auto">Now the problem is:<br />
The output signal of the motion sensor is high if there is <strong>no</strong> motion detected and is low if motion is detected.</p>
<p dir="auto">I think the MMM-PIR Module switches the monitor on if the GPIO pin becomes high - so my display is always on.</p>
<p dir="auto">is there a way to use my Sensor with the MMM-PIR-Module?</p>
<p dir="auto">Thank you for any help<br />
Jan-Christoph</p>
]]></description><link>https://forum.magicmirror.builders/topic/2318/mmm-pir-sensor-module-gpio-settings</link><generator>RSS for Node</generator><lastBuildDate>Thu, 13 Aug 2026 02:16:48 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/2318.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 14 Apr 2017 20:33:32 GMT</pubDate><ttl>60</ttl></channel></rss>
