<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Cowboysdude&#x27;s Mirror]]></title><description><![CDATA[<p dir="auto">Here’s a picture of mine.  Needs to be painted but it’s working!</p>
<p dir="auto"><img src="https://scontent-ord1-1.xx.fbcdn.net/v/t1.0-9/13413685_1167188633315247_3003307420107196162_n.jpg?oh=60f33f591b099fb89861ffebf5e1b378&amp;oe=57C5CCC2" alt="alt text" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.magicmirror.builders/topic/232/cowboysdude-s-mirror</link><generator>RSS for Node</generator><lastBuildDate>Thu, 14 May 2026 23:06:33 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/232.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 13 Jun 2016 12:23:57 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Cowboysdude&#x27;s Mirror on Wed, 02 Nov 2016 21:17:46 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/cowboysdude" aria-label="Profile: cowboysdude">@<bdi>cowboysdude</bdi></a> oh so cool for sharing! let’s try this! wow that’s a thing i should have thought about before lol but currently i can’t put it too much far away as my cables are only few cm long…</p>
]]></description><link>https://forum.magicmirror.builders/post/7486</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/7486</guid><dc:creator><![CDATA[bibi]]></dc:creator><pubDate>Wed, 02 Nov 2016 21:17:46 GMT</pubDate></item><item><title><![CDATA[Reply to Cowboysdude&#x27;s Mirror on Wed, 02 Nov 2016 21:10:04 GMT]]></title><description><![CDATA[<p dir="auto">Mine is set just like this right out of the box…</p>
<p dir="auto">The sensitivity sensor is set to half way as is the Time Delay Adjust  so what you do is turn it all the way to the right then back 1/2 turn on both :)</p>
<p dir="auto">The Jumper is L Single trigger…</p>
<p dir="auto">OH by the way PIR sensors and the Pi 3 sometimes don’t get along - if you’re having false triggers, make sure the PIR Sensor is far away from the Pi 3…   So get it as far away as you can :)  I would try that first before making anymore adjustments!</p>
<p dir="auto"><img src="/uploads/files/1478120773576-25xhk.png" alt="0_1478120770619_25xHk.png" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.magicmirror.builders/post/7485</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/7485</guid><dc:creator><![CDATA[cowboysdude]]></dc:creator><pubDate>Wed, 02 Nov 2016 21:10:04 GMT</pubDate></item><item><title><![CDATA[Reply to Cowboysdude&#x27;s Mirror on Wed, 02 Nov 2016 20:40:54 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/cowboysdude" aria-label="Profile: cowboysdude">@<bdi>cowboysdude</bdi></a> Cool! my modified .sh files are working well in interactive mode :) but… there is always a but lol,  when .py file is run it switches well the screen off after the amount of time set and wakes up when hand is waved BUT suddently and without detection the screen wakes up again! this is really irrating… so close to my goal :(<br />
i believe it’s the <strong>physical settings</strong> on the sensor itself making this behavior… would you mind to send me a pic or tell me how your sensor is set?  =&gt; jumper and the knobs? thx mate for this (i hope) final demand! :)))</p>
]]></description><link>https://forum.magicmirror.builders/post/7483</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/7483</guid><dc:creator><![CDATA[bibi]]></dc:creator><pubDate>Wed, 02 Nov 2016 20:40:54 GMT</pubDate></item><item><title><![CDATA[Reply to Cowboysdude&#x27;s Mirror on Wed, 02 Nov 2016 10:55:02 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/cowboysdude" aria-label="Profile: cowboysdude">@<bdi>cowboysdude</bdi></a> said in <a href="/post/7458">Cowboysdude's Mirror</a>:</p>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/bibi" aria-label="Profile: bibi">@<bdi>bibi</bdi></a> said in <a href="/post/7451">Cowboysdude's Mirror</a>:</p>
<p dir="auto">sudo chvt 9 &amp;&amp; sudo chvt 7</p>
<p dir="auto">Open up the monitor_on.sh and delete everything add:</p>
<p dir="auto">Save it and that should work for you :)</p>
<p dir="auto">yep that’s exactly what i wanted to later today :))<br />
nevertheless, I found on the forum another way to avoid using sudo… i assume it’s better practice but i am not able to confirm this.<br />
fyi:<br />
the link :  <a href="https://forum.magicmirror.builders/topic/208/pir-sensor-put-your-mirror-to-sleep-if-not-used/64">https://forum.magicmirror.builders/topic/208/pir-sensor-put-your-mirror-to-sleep-if-not-used/64</a></p>
]]></description><link>https://forum.magicmirror.builders/post/7473</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/7473</guid><dc:creator><![CDATA[bibi]]></dc:creator><pubDate>Wed, 02 Nov 2016 10:55:02 GMT</pubDate></item><item><title><![CDATA[Reply to Cowboysdude&#x27;s Mirror on Wed, 02 Nov 2016 01:47:18 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/bibi" aria-label="Profile: bibi">@<bdi>bibi</bdi></a> said in <a href="/post/7451">Cowboysdude's Mirror</a>:</p>
]]></description><link>https://forum.magicmirror.builders/post/7458</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/7458</guid><dc:creator><![CDATA[cowboysdude]]></dc:creator><pubDate>Wed, 02 Nov 2016 01:47:18 GMT</pubDate></item><item><title><![CDATA[Reply to Cowboysdude&#x27;s Mirror on Tue, 01 Nov 2016 22:41:11 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/cowboysdude" aria-label="Profile: cowboysdude">@<bdi>cowboysdude</bdi></a> <a class="plugin-mentions-user plugin-mentions-a" href="/user/bhepler" aria-label="Profile: bhepler">@<bdi>bhepler</bdi></a> Thx for spending time to help me. i understand if you can’t help anymore.<br />
but here my update : i installed Xscreensaver and disabled it but it’s working. the monitor switches off with /opt/vc/bin/tvservice -o properly but with<br />
/opt/vc/bin/tvservice -p  the screen stays black (backlight)<br />
just for info im doing all this via SSH… maybe something to do with X forwarding and this message : xset:  unable to open display “”…</p>
<p dir="auto">Edit: i have found a command that allows to bring back the screen ! sudo chvt 9 &amp;&amp; sudo chvt 7. :)))<br />
i have to check out how to implement this in an elegant way</p>
]]></description><link>https://forum.magicmirror.builders/post/7451</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/7451</guid><dc:creator><![CDATA[bibi]]></dc:creator><pubDate>Tue, 01 Nov 2016 22:41:11 GMT</pubDate></item><item><title><![CDATA[Reply to Cowboysdude&#x27;s Mirror on Tue, 01 Nov 2016 14:00:31 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/bibi" aria-label="Profile: bibi">@<bdi>bibi</bdi></a> <a href="https://forum.magicmirror.builders/topic/785/autostart-turning-off-powersave/8">This thread may help you</a>.</p>
]]></description><link>https://forum.magicmirror.builders/post/7428</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/7428</guid><dc:creator><![CDATA[bhepler]]></dc:creator><pubDate>Tue, 01 Nov 2016 14:00:31 GMT</pubDate></item><item><title><![CDATA[Reply to Cowboysdude&#x27;s Mirror on Tue, 01 Nov 2016 11:28:08 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/bibi" aria-label="Profile: bibi">@<bdi>bibi</bdi></a> said in <a href="/post/7423">Cowboysdude's Mirror</a>:</p>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/cowboysdude" aria-label="Profile: cowboysdude">@<bdi>cowboysdude</bdi></a> aha ok I will check install xscreensaver this evening. Any specific options or settings that I should apply?</p>
<p dir="auto">Yes “Disable”  :)</p>
]]></description><link>https://forum.magicmirror.builders/post/7424</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/7424</guid><dc:creator><![CDATA[cowboysdude]]></dc:creator><pubDate>Tue, 01 Nov 2016 11:28:08 GMT</pubDate></item><item><title><![CDATA[Reply to Cowboysdude&#x27;s Mirror on Tue, 01 Nov 2016 09:17:04 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/cowboysdude" aria-label="Profile: cowboysdude">@<bdi>cowboysdude</bdi></a> aha ok I will check install xscreensaver this evening. Any specific options or settings that I should apply?</p>
]]></description><link>https://forum.magicmirror.builders/post/7423</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/7423</guid><dc:creator><![CDATA[bibi]]></dc:creator><pubDate>Tue, 01 Nov 2016 09:17:04 GMT</pubDate></item><item><title><![CDATA[Reply to Cowboysdude&#x27;s Mirror on Tue, 01 Nov 2016 03:03:04 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/bibi" aria-label="Profile: bibi">@<bdi>bibi</bdi></a> said in <a href="/post/7410">Cowboysdude's Mirror</a>:</p>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/cowboysdude" aria-label="Profile: cowboysdude">@<bdi>cowboysdude</bdi></a> Apperently i could get ride off this xset message now the monitor is turning on but the screen stays black… screensaver issue maybe.</p>
<p dir="auto">Yes that’s why I gave you the new one to try… I believe you’re having a screen saver issue.</p>
<p dir="auto">The way I handled mine was to install xscreensaver and disable it :)</p>
]]></description><link>https://forum.magicmirror.builders/post/7418</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/7418</guid><dc:creator><![CDATA[cowboysdude]]></dc:creator><pubDate>Tue, 01 Nov 2016 03:03:04 GMT</pubDate></item><item><title><![CDATA[Reply to Cowboysdude&#x27;s Mirror on Mon, 31 Oct 2016 22:29:50 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/cowboysdude" aria-label="Profile: cowboysdude">@<bdi>cowboysdude</bdi></a> Apperently i could get ride off this xset message now the monitor is turning on but the screen stays black… screensaver issue maybe.</p>
]]></description><link>https://forum.magicmirror.builders/post/7410</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/7410</guid><dc:creator><![CDATA[bibi]]></dc:creator><pubDate>Mon, 31 Oct 2016 22:29:50 GMT</pubDate></item><item><title><![CDATA[Reply to Cowboysdude&#x27;s Mirror on Mon, 31 Oct 2016 21:22:53 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/bibi" aria-label="Profile: bibi">@<bdi>bibi</bdi></a> go here:</p>
<p dir="auto"><a href="https://github.com/cowboysdude/Pir-Sensor" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/cowboysdude/Pir-Sensor</a></p>
<p dir="auto">download the monitor_on.sh and try running it again.</p>
]]></description><link>https://forum.magicmirror.builders/post/7407</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/7407</guid><dc:creator><![CDATA[cowboysdude]]></dc:creator><pubDate>Mon, 31 Oct 2016 21:22:53 GMT</pubDate></item><item><title><![CDATA[Reply to Cowboysdude&#x27;s Mirror on Mon, 31 Oct 2016 18:24:01 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/cowboysdude" aria-label="Profile: cowboysdude">@<bdi>cowboysdude</bdi></a> that’s exactly what i did all 3 files are located in Pi home directory as well as wiringPi.<br />
sudo chmod there too &amp; crontab too…<br />
but not working… there should be something else.<br />
i try to run your .sh file so the outcome is that monitor_off file works well but the monitor_on file displays the following message:<br />
<img src="/uploads/files/1477938102788-capture-d-e-cran-2016-10-31-a-19.19.42.png" alt="0_1477938102221_Capture d’écran 2016-10-31 à 19.19.42.png" class=" img-fluid img-markdown" /><br />
would you mind to share with me YOUR following files plssssss =&gt;<br />
<img src="/uploads/files/1477938144974-capture-d-e-cran-2016-10-31-a-19.20.01-resized.png" alt="0_1477938144578_Capture d’écran 2016-10-31 à 19.20.01.png" class=" img-fluid img-markdown" /><br />
thx you!</p>
]]></description><link>https://forum.magicmirror.builders/post/7391</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/7391</guid><dc:creator><![CDATA[bibi]]></dc:creator><pubDate>Mon, 31 Oct 2016 18:24:01 GMT</pubDate></item><item><title><![CDATA[Reply to Cowboysdude&#x27;s Mirror on Sun, 30 Oct 2016 17:37:04 GMT]]></title><description><![CDATA[<p dir="auto">First make sure your wiring is correct… use the pin in the <a href="http://pir.py" target="_blank" rel="noopener noreferrer nofollow ugc">pir.py</a>…</p>
<p dir="auto">Then…</p>
<p dir="auto">I put the <a href="http://pir.py" target="_blank" rel="noopener noreferrer nofollow ugc">pir.py</a> and both sh files in the pi root directly</p>
<p dir="auto">pi/pir.py<br />
pi/monitor_off.sh<br />
pi/monitor_on.sh</p>
<p dir="auto">sudo chmod +x <a href="http://pir.py" target="_blank" rel="noopener noreferrer nofollow ugc">pir.py</a></p>
<p dir="auto">sudo chmod +x monitor_off.sh</p>
<p dir="auto">sudo chmod +x monitor_on.sh</p>
<p dir="auto">sudo crontab -e</p>
<p dir="auto">On the last line enter:</p>
<p dir="auto">@reboot python /home/pi/pir.py &amp;</p>
<p dir="auto">Hit CRTL-O to save then exit</p>
<p dir="auto">Reboot your pi</p>
]]></description><link>https://forum.magicmirror.builders/post/7339</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/7339</guid><dc:creator><![CDATA[cowboysdude]]></dc:creator><pubDate>Sun, 30 Oct 2016 17:37:04 GMT</pubDate></item><item><title><![CDATA[Reply to Cowboysdude&#x27;s Mirror on Sun, 30 Oct 2016 17:26:01 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/cowboysdude" aria-label="Profile: cowboysdude">@<bdi>cowboysdude</bdi></a> oh that’s really really awesome!<br />
so what i have done is git Pir-Sensor &amp; wiringPi into root? =&gt;<br />
<img src="/uploads/files/1477847789784-capture-d-e-cran-2016-10-30-a-18.15.31-resized.png" alt="0_1477847789347_Capture d’écran 2016-10-30 à 18.15.31.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">edit with nano <a href="http://pir.py" target="_blank" rel="noopener noreferrer nofollow ugc">pir.py</a> =&gt;<br />
<img src="/uploads/files/1477847960025-capture-d-e-cran-2016-10-30-a-18.18.45.png" alt="0_1477847957260_Capture d’écran 2016-10-30 à 18.18.45.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">chmod all 3 files at pi@raspberrypi:~ $</p>
<p dir="auto">and crontab also at pi@raspberrypi:~ $</p>
<p dir="auto"><img src="/uploads/files/1477848117689-capture-d-e-cran-2016-10-30-a-18.21.35.png" alt="0_1477848117253_Capture d’écran 2016-10-30 à 18.21.35.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">the jumper on PIR sensor in on H and the knobs are both set at minimum level</p>
]]></description><link>https://forum.magicmirror.builders/post/7338</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/7338</guid><dc:creator><![CDATA[bibi]]></dc:creator><pubDate>Sun, 30 Oct 2016 17:26:01 GMT</pubDate></item><item><title><![CDATA[Reply to Cowboysdude&#x27;s Mirror on Sun, 30 Oct 2016 17:13:12 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/bibi" aria-label="Profile: bibi">@<bdi>bibi</bdi></a> said in <a href="/post/7334">Cowboysdude's Mirror</a>:</p>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/cowboysdude" aria-label="Profile: cowboysdude">@<bdi>cowboysdude</bdi></a> Hi! would you mind helping me to install/debug your module please? i am not able to make it work even tho i followed your instructions :( thx if you can do this favor.<br />
let me know what should i share (command to run etc) to make it easy to “debug”</p>
<p dir="auto">Sure I will help you all I can :)</p>
]]></description><link>https://forum.magicmirror.builders/post/7337</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/7337</guid><dc:creator><![CDATA[cowboysdude]]></dc:creator><pubDate>Sun, 30 Oct 2016 17:13:12 GMT</pubDate></item><item><title><![CDATA[Reply to Cowboysdude&#x27;s Mirror on Sun, 30 Oct 2016 17:04:15 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/cowboysdude" aria-label="Profile: cowboysdude">@<bdi>cowboysdude</bdi></a> Hi! would you mind helping me to install/debug your module please? i am not able to make it work even tho i followed your instructions :( thx if you can do this favor.<br />
]]></description><link>https://forum.magicmirror.builders/post/7334</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/7334</guid><dc:creator><![CDATA[bibi]]></dc:creator><pubDate>Sun, 30 Oct 2016 17:04:15 GMT</pubDate></item><item><title><![CDATA[Reply to Cowboysdude&#x27;s Mirror on Mon, 26 Sep 2016 20:23:56 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ostfilinchen" aria-label="Profile: ostfilinchen">@<bdi>ostfilinchen</bdi></a> said in <a href="/post/5336">Cowboysdude's Mirror</a>:</p>
<p dir="auto">ERROR</p>
<p dir="auto">Run the mirror in dev mode</p>
<p dir="auto">npm start dev</p>
<p dir="auto">Then see what errors you’re getting :)</p>
]]></description><link>https://forum.magicmirror.builders/post/5342</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/5342</guid><dc:creator><![CDATA[cowboysdude]]></dc:creator><pubDate>Mon, 26 Sep 2016 20:23:56 GMT</pubDate></item><item><title><![CDATA[Reply to Cowboysdude&#x27;s Mirror on Mon, 26 Sep 2016 19:37:30 GMT]]></title><description><![CDATA[<p dir="auto">Hi <a class="plugin-mentions-user plugin-mentions-a" href="/user/cowboysdude" aria-label="Profile: cowboysdude">@<bdi>cowboysdude</bdi></a>,</p>
<p dir="auto">i have an issue with the MMM-Voice-Module. I had install all with the <a href="http://dependencies.sh" target="_blank" rel="noopener noreferrer nofollow ugc">dependencies.sh</a>. The Installscript says i must use mic 1 in the config.js. But it doesn’t work. The Module in the Mirror says: Initialize… and then ERROR. What can i do to resolve the Problem?</p>
<p dir="auto">Regards, Daniel</p>
]]></description><link>https://forum.magicmirror.builders/post/5336</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/5336</guid><dc:creator><![CDATA[ostfilinchen]]></dc:creator><pubDate>Mon, 26 Sep 2016 19:37:30 GMT</pubDate></item><item><title><![CDATA[Reply to Cowboysdude&#x27;s Mirror on Fri, 02 Sep 2016 12:51:48 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mitchfarino" aria-label="Profile: Mitchfarino">@<bdi>Mitchfarino</bdi></a> said in <a href="/post/4301">Cowboysdude's Mirror</a>:</p>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/cowboysdude" aria-label="Profile: cowboysdude">@<bdi>cowboysdude</bdi></a> Looks great!</p>
<p dir="auto">I need to get back in to things now, and get mine built!!</p>
<p dir="auto">Thank you!!  Post pics for us!</p>
]]></description><link>https://forum.magicmirror.builders/post/4304</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/4304</guid><dc:creator><![CDATA[cowboysdude]]></dc:creator><pubDate>Fri, 02 Sep 2016 12:51:48 GMT</pubDate></item><item><title><![CDATA[Reply to Cowboysdude&#x27;s Mirror on Fri, 02 Sep 2016 10:12:12 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/cowboysdude" aria-label="Profile: cowboysdude">@<bdi>cowboysdude</bdi></a> Looks great!</p>
]]></description><link>https://forum.magicmirror.builders/post/4301</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/4301</guid><dc:creator><![CDATA[Mitchfarino]]></dc:creator><pubDate>Fri, 02 Sep 2016 10:12:12 GMT</pubDate></item><item><title><![CDATA[Reply to Cowboysdude&#x27;s Mirror on Thu, 01 Sep 2016 22:35:50 GMT]]></title><description><![CDATA[<p dir="auto">Here is the voice module I am using…</p>
<p dir="auto"><a href="https://github.com/fewieden/MMM-voice" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/fewieden/MMM-voice</a></p>
<p dir="auto">Here’s a link to a very small video testing it!</p>
<p dir="auto"><a href="http://www.dallascowboyschat.com/temp/IMG_1617.MOV" target="_blank" rel="noopener noreferrer nofollow ugc">http://www.dallascowboyschat.com/temp/IMG_1617.MOV</a></p>
]]></description><link>https://forum.magicmirror.builders/post/4290</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/4290</guid><dc:creator><![CDATA[cowboysdude]]></dc:creator><pubDate>Thu, 01 Sep 2016 22:35:50 GMT</pubDate></item><item><title><![CDATA[Reply to Cowboysdude&#x27;s Mirror on Thu, 01 Sep 2016 16:21:20 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mitchfarino" aria-label="Profile: Mitchfarino">@<bdi>Mitchfarino</bdi></a> I will post it later tonight.  The mirror working that is and I’ll post the voice git hub info as well.    I didn’t do the software strawberry did.  But it’s working great</p>
]]></description><link>https://forum.magicmirror.builders/post/4272</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/4272</guid><dc:creator><![CDATA[cowboysdude]]></dc:creator><pubDate>Thu, 01 Sep 2016 16:21:20 GMT</pubDate></item></channel></rss>
