<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[I&#x27;m new and need help]]></title><description><![CDATA[<p dir="auto">Hi! I’d been looking for the answer to my question in the forum but I couldn’t find it.<br />
How do I logout from the mirror when I start it?<br />
How can I download my own repository? I customizes the codes and did some changes to the download code but it doesn’t wor.<br />
Thanks</p>
]]></description><link>https://forum.magicmirror.builders/topic/2331/i-m-new-and-need-help</link><generator>RSS for Node</generator><lastBuildDate>Fri, 15 May 2026 22:57:09 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/2331.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 16 Apr 2017 15:34:11 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to I&#x27;m new and need help on Sun, 16 Apr 2017 15:48:45 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/enith2478" aria-label="Profile: enith2478">@<bdi>enith2478</bdi></a> Going to give you a quick reply here … I’m on my way to my families as it’s Easter Holiday… so here goes…</p>
<p dir="auto">If you’re using a Raspberry pi just hit the ALT key and a menu will pop up at the top…  “File-&gt;exit”<br />
you can exit that way…</p>
<p dir="auto">“How can I download my own repository?”  -&gt;  go read up on github that will help you… it’s usually git clone or you can just use a browser to go to github and choose ‘download’.</p>
<p dir="auto">As for changes… I wouldn’t suggest that because if there’s an update to MM all your changes will be gone.  Not really sure what you’re trying to do here your information is very vague.</p>
<p dir="auto">At any rate, hope that helps… I’m off to eat dinner with the family.</p>
]]></description><link>https://forum.magicmirror.builders/post/19746</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/19746</guid><dc:creator><![CDATA[cowboysdude]]></dc:creator><pubDate>Sun, 16 Apr 2017 15:48:45 GMT</pubDate></item><item><title><![CDATA[Reply to I&#x27;m new and need help on Sun, 16 Apr 2017 15:47:18 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/johnnyboy" aria-label="Profile: johnnyboy">@<bdi>johnnyboy</bdi></a> Thank you very much! I’ll try that :-)</p>
]]></description><link>https://forum.magicmirror.builders/post/19745</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/19745</guid><dc:creator><![CDATA[enith2478]]></dc:creator><pubDate>Sun, 16 Apr 2017 15:47:18 GMT</pubDate></item></channel></rss>
